I have a fresh install of current Raspbian on RPi 2 B+.
When I connect or disconnect USB drive formatted to ExFAT it will restart immediately.
Is there a way how to let work with USB drives?
A USB hard drive? It sounds like the drive demands more power to spin up then your power supply / Pi can supply.When I connect or disconnect USB drive formatted to ExFAT it will restart immediately.
Yes, I was able to read that drive after that enforced restart.RonR wrote: ↑Wed Aug 21, 2019 11:12 pmDo you have support for exFAT installed?:
apt-get install exfat-fuse exfat-utils
It is small Kensington thumb drive, I doubt it will consume significantly more than SD card.
fruitoftheloom wrote: ↑Thu Aug 22, 2019 6:10 am
There is no RPi 2B+ please clarify model.
The USB Hard Drive any details ?
Power Supply you are using ?
Bobik wrote: ↑Thu Aug 22, 2019 9:39 amfruitoftheloom wrote: ↑Thu Aug 22, 2019 6:10 am
Has Dougie discovered a new phenomenon? Current getting lost in a cable.
