thank you for the comments and thats great. also thanks for the fallover-failover thing
isit possible you could help me add it to the code, im new and learning and if could see the differnce between my original code and one with the option of what i asked above this would really help me so i could continue to modify this script with this. appreciated in advance.
my current script is as follows
#!/usr/bin/env python
import pigpio, csv, os
os.system("pigpiod")
FILE_TO_READ = '/home/pi/furniss/database/database.csv'
CSV_ID_KEY = 'Number :'
CSV_NAME_KEY = 'Name :'
CSV_TEL_KEY = 'Tel No :'
class decoder:
A class to read Wiegand codes of an arbitrary length.
The code length and value are returned.
EXAMPLE
import time
import pigpio
import wiegand
def callback(bits, code):
print("bits={} code={}".format(bits, code))
pi = pigpio.pi()
w = wiegand.decoder(pi, 14, 15, callback)
while True:
time.sleep(60)
w.cancel()
pi.stop()
def __init__(self, pi, gpio_0, gpio_1, callback, bit_timeout=5):
Instantiate with the pi, gpio for 0 (green wire), the gpio for 1
(white wire), the callback function, and the bit timeout in
milliseconds which indicates the end of a code.
The callback is passed the code length in bits and the value.
self.pi = pi
self.gpio_0 = gpio_0
self.gpio_1 = gpio_1
self.callback = callback
self.bit_timeout = bit_timeout
self.in_code = False
self.pi.set_mode(gpio_0, pigpio.INPUT)
self.pi.set_mode(gpio_1, pigpio.INPUT)
self.pi.set_pull_up_down(gpio_0, pigpio.PUD_UP)
self.pi.set_pull_up_down(gpio_1, pigpio.PUD_UP)
self.cb_0 = self.pi.callback(gpio_0, pigpio.FALLING_EDGE, self._cb)
self.cb_1 = self.pi.callback(gpio_1, pigpio.FALLING_EDGE, self._cb)
def _cb(self, gpio, level, tick):
Accumulate bits until both gpios 0 and 1 timeout.
if level < pigpio.TIMEOUT:
if self.in_code == False:
self.bits = 1
self.num = 0
self.in_code = True
self.code_timeout = 0
self.pi.set_watchdog(self.gpio_0, self.bit_timeout)
self.pi.set_watchdog(self.gpio_1, self.bit_timeout)
else:
self.bits += 1
self.num = self.num << 1
if gpio == self.gpio_0:
self.code_timeout = self.code_timeout & 2 # clear gpio 0 timeout
else:
self.code_timeout = self.code_timeout & 1 # clear gpio 1 timeout
self.num = self.num | 1
else:
if self.in_code:
self.code_timeout = self.code_timeout | 1 # timeout gpio 0
else:
self.code_timeout = self.code_timeout | 2 # timeout gpio 1
if self.code_timeout == 3: # both gpios timed out
self.pi.set_watchdog(self.gpio_0, 0)
self.pi.set_watchdog(self.gpio_1, 0)
self.callback(self.bits, self.num)
def cancel(self):
Cancel the Wiegand decoder.
self.cb_0.cancel()
self.cb_1.cancel()
def readFile(filename):
data = []
with open(filename, 'r') as file:
reader = csv.DictReader(file)
data = [row for row in reader]
return data
def authenticateFromFile(id):
for row in readFile(FILE_TO_READ):
if CSV_ID_KEY in row and row[CSV_ID_KEY] == id:
return row
return False
if __name__ == "__main__":
print (" ")
print ("Furniss.UK ACS - Version 1.1 - TLF")
print (" ")
import time
import datetime
import RPi.GPIO as GPIO
import pigpio
import wiegand
GPIO.setmode(GPIO.BCM)
GPIO.setwarnings(False)
def callback(bits, value):
user = authenticateFromFile('{}'.format(value))
if user:
now = datetime.datetime.now()
print (now.strftime("%Y-%m-%d %H:%M:%S"))
print("User='{}' Tel='{}' Wiegand bits={} Card Number={}".format(user[CSV_NAME_KEY], user[CSV_TEL_KEY], bits, value))
print (" ")
file = open("/home/pi/furniss/html/events.txt", "w")
file.write("Last Access: Wiegand bits={}\n".format(bits))
file.write("\nCard value={}".format(value))
GPIO.setup(18,GPIO.OUT)
print("door released")
GPIO.output(18,GPIO.LOW)
time.sleep(5)
print (" ")
print("door secure")
GPIO.output(18, GPIO.HIGH)
print (" ")
print (" --------------------------------------------")
else:
print (" ")
print("Access Denied = Wiegand bits={} Card Number={}".format(bits, value))
file.write("Access Denied = Wiegand bits={} Card Number={}".format(bits, value))
print (" ")
print (" ")
pi = pigpio.pi()
while True:
time.sleep(60)
w.cancel()
pi.stop()
