Athena
Red Battery icon - Discharging%
Wed Jan 09, 2019 8:01 pm
On my desktop, the battery icon is red and when I hover over it I see "discharging". What is this icon for? Which battery is this icon referring to? I have RPi -2 Model B. Thank you.
pcmanbob
Re: Red Battery icon - Discharging%
Wed Jan 09, 2019 8:06 pm
Which OS are you running ? As I don't ever remember seeing a battery symbol on raspbian.
Imperf3kt
Contact: Twitter
Wed Jan 09, 2019 8:47 pm
There are two battery monitors accessible in the taskbar (is it called a taskbar on Linux?)
One is standard to Linux, the other is specialised to the Pi Top.
They don't show by default, but it sounds like you have enabled one or them.
The Pi has no battery.
55:55:44:44:4C
52:4C:52:42:41
Rose tinted glasses are difficult to see through.
Athena
Wed Jan 09, 2019 8:51 pm
Raspbian GNU/Linux 9 (stretch)
Athena
Wed Jan 09, 2019 8:59 pm
Yes, I know. That's the reason for the question. What is this icon showing with a message "Discharging %"?. I am not aware of discharging of a battery. If there were a battery in RPi, the icon could have displayed the state of charging, but not discharging. So, this is new to me.
Again, the OS is "Raspbian GNU/Linux 9 (stretch)" running on Pi 2, Model B.
neilgl
Wed Jan 09, 2019 9:01 pm
Maybe look at: right click on the top menu bar and Add/Remove Panel items. There are battery monitoring applets there under Add...
Imperf3kt
Contact: Twitter
Wed Jan 09, 2019 9:44 pm
It likely shows discharging because it's not configured properly. Raspbian was not intended for use from a battery powered device, so it's development was ignored.
The battery monitor is just there because it is, not because it works.
55:55:44:44:4C
52:4C:52:42:41
HawaiianPi
Wed Jan 09, 2019 9:52 pm
I have seen that on recent Raspbian builds, so it seems it may be there by default now. That puzzles me, because I can't imagine there are enough PiTop users to have that as a default. I just remove it from the task bar since I don't need it.
Athena
Thu Jan 10, 2019 2:52 am
After these discussions made it clear, this is exactly what I did; removed it from the taskbar. Thank you all for clarifying.
chiques
Sun Aug 11, 2019 5:54 pm
A voltage indicator would be more useful.
drgeoff
Sun Aug 11, 2019 6:03 pm
An indicator is already provided - the yellow lightning bolt when voltage is low.
Quis custodiet ipsos custodes?
BogoMax
Sun Aug 11, 2019 7:03 pm
I recently booted into my Pi4B and saw an icon in the panel - an empty red battery outline.
After a momentary panic I realised it had to be an error so I just removed the indicator from the panel.
I'm not sure how this came about as I haven't messed with the panel, but I assume it happened after a apt-get upgrade
Did I mention that I love my Raspberry Pi(s) :D. Amazing power from a tiny device.
MisterEd
Mon Aug 26, 2019 6:16 pm
The same thing happened to me. I only saw the battery icon after the first boot of the day. I did like you said and removed it from the taskbar panel.
