PeterO
Re: Buster bug report thread
Wed Jul 31, 2019 6:25 am
I just installed "xmag" to look at an icon , and the rubber band leaves a trail behind.
PeterO
algorithm
Wed Jul 31, 2019 8:38 am
jamesh wrote:
Tue Jul 30, 2019 2:10 pm
Instead of that HDMI stuff, try
framebuffer_width=1920
framebuffer_height=1080
#dtoverlay=vc4-fkms-v3d   <--- May  or may not need this.
Alas, I tried all sorts of combinations with & without hdmi/framebuffer/overlay, but it either gives no window (VNC error "unable to connect to console" or s/t like that which is fixed by hdmi_force_hotplug=1) or that same 1024x768 resolution every time.
AzureDrgn
Wed Jul 31, 2019 7:26 pm
So I downloaded the torrent for Raspbian Buster w/ desktop and recommended software version 4.19 and the zip file size is 734 PB (807,167,553,260,822 KB) what did i just download?
scottme
Thu Aug 01, 2019 2:52 pm
Is there a problem with the package python3-ws4py on the Buster repository? I'm using a Pi 3B+ running what I believe is a pretty standard Raspbian image, including Python 3.7.3. but I am unable to install that package, even after doing a complete dist-upgrade. I get the following errors from apt-get:
[email protected]:~ $ sudo apt-get install python3-ws4py
Reading package lists... Done
Building dependency tree
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
 python3-ws4py : Depends: python3:any (>= 3.3.2-2~)
E: Unable to correct problems, you have held broken packages.
There are no held packages. I have tried to install using aptitude also, but it reports the same dependency error, in a slightly different way, thus:
[email protected]:~ $ sudo aptitude install python3-ws4py
The following NEW packages will be installed:
  python3-ws4py
0 packages upgraded, 1 newly installed, 0 to remove and 92 not upgraded.
Need to get 39.7 kB of archives. After unpacking 170 kB will be used.
 python3.7 : Breaks: python3-ws4py (<= 0.4.2+dfsg1-2) but 0.4.2+dfsg1-2 is to be installed
The following actions will resolve these dependencies:
     Keep the following packages at their current version:
1)     python3-ws4py [Not Installed]
Accept this solution? [Y/n/q/?] q
Abandoning all efforts to resolve these dependencies.
Abort.
The message confuses me - it seems to be saying that it can't install ws4py because needs to be at a level no higher than the one it's trying to install - which makes no sense.
As background, I'm trying to use a recipe I found at https://github.com/waveform80/pistreaming to stream video from a bird box that I'm building.
Massaguana
Sat Aug 03, 2019 9:37 am
Raspbian Buster lite @Raspberry Pi (First Generation)
When i wood like to Update the System this happens:
[email protected]:~ $ sudo apt-get update && apt-get upgrade
Hit:1 http://archive.raspberrypi.org/debian buster InRelease
Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
E: Could not open lock file /var/lib/dpkg/lock-frontend - open (13: Permission denied)
E: Unable to acquire the dpkg frontend lock (/var/lib/dpkg/lock-frontend), are you root?
ShiftPlusOne
Sat Aug 03, 2019 9:39 am
You forgot a sudo after the &&
Massaguana
Sat Aug 03, 2019 9:41 am
Thanks...
Massaguana
Sat Aug 03, 2019 10:33 am
Having problems with "DHCP fixed lease" IP Adress for my Pi1
Without fixed is see this (Network is working)
[email protected]:~ $ ifconfig
eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet 192.168.2.95  netmask 255.255.255.0  broadcast 192.168.2.255
        inet6 fe80::4119:56b8:dfdd:b271  prefixlen 64  scopeid 0x20<link>
        ether b8:27:eb:0d:92:e4  txqueuelen 1000  (Ethernet)
        RX packets 310  bytes 62600 (61.1 KiB)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 331  bytes 85363 (83.3 KiB)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 65536
        inet 127.0.0.1  netmask 255.0.0.0
        inet6 ::1  prefixlen 128  scopeid 0x10<host>
        loop  txqueuelen 1000  (Local Loopback)
        RX packets 0  bytes 0 (0.0 B)
        TX packets 0  bytes 0 (0.0 B)
When i set an fixed lease IP for the Raspi MAC Adress in my IPFire Router the Raspi don´t use it. No Network Access
hippy
Sat Aug 03, 2019 12:37 pm
It would probably help if you could demonstrate this is a Buster bug and not an issue of configuration or user error. That something appears not be working as desired does not automatically make it a Buster bug.
Sat Aug 03, 2019 12:42 pm
How have you done "DHCP fixed lease"? Is that with strange incantations in /etc/dhcpcd.conf or some strange configuration options on the router at 192.168.2.1 or 192.168.2.254?
This is a doctor free zone.
Aratosh
Sat Aug 03, 2019 2:48 pm
After updating the firmware in Stretch to the Newest one and also when using Buster the Pi 3 B+ wont boot from USB.
Near the same Problem in Arch ARM and Kali Pi, there comes a Kernelpanic After updating the Firmware.
Looks like theres a problem in the bcm2710-rpi-3-b-plus.dtp cause the 3 B will boot.
All Distros with own Bootfiles rund with no Problems, Fedberry, Ubuntu Mate...
jullrey
Sat Aug 03, 2019 11:57 pm
I have the same problem:
[email protected]:~ $ uname -a
Linux raspberrypi 4.19.58-v7l+ #1245 SMP Fri Jul 12 17:31:45 BST 2019 armv7l GNU/Linux
[email protected]:~ $ gpio -v
gpio version: 2.50
Copyright (c) 2012-2018 Gordon Henderson
This is free software with ABSOLUTELY NO WARRANTY.
For details type: gpio -warranty
Raspberry Pi Details:
  Type: Unknown17, Revision: 01, Memory: 0MB, Maker: Sony
  * Device tree is enabled.
  *--> Raspberry Pi 4 Model B Rev 1.1
  * This Raspberry Pi supports user-level GPIO access.
[email protected]:~ $ sudo gpio readall
Oops - unable to determine board type... model: 17
[email protected]:~ $ gpio readall
DirkS
Sun Aug 04, 2019 6:15 am
What problem? There are several problems described in this topic...
Ernst
Sun Aug 04, 2019 6:49 am
gpio version: 2.50
http://wiringpi.com/wiringpi-updated-to ... rry-pi-4b/
The road to insanity is paved with static ip addresses
Massaguana
[Solved ] Buster bug report thread
Sun Aug 04, 2019 8:15 am
Here are some more Informations and test with the Same Raspberry Pi but with another OS
#                   RasPlex                  #
#             http://rasplex.com             #
RasPlex (official) Version: 1.8.0.148-573b6d73
RasPlex git: e2efbe6dff28a97ec76f0db00073fa3d00b45584
Settings IPFire DHCP Server
The Range 192.168.2.2 to 19 are for System Devices like switches, NAS or Pi-Hole
Without fixed lease:
ifconfig
eth0      Link encap:Ethernet  HWaddr B8:27:EB:0D:92:E4
          inet addr:192.168.2.95  Bcast:192.168.2.255  Mask:255.255.255.0
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:4156 errors:0 dropped:0 overruns:0 frame:0
          TX packets:1944 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:5480376 (5.2 MiB)  TX bytes:229780 (224.3 KiB)
With fixed lease:
ifconfig
          inet addr:192.168.2.2  Bcast:192.168.2.255  Mask:255.255.255.0
          RX packets:2806 errors:0 dropped:0 overruns:0 frame:0
          RX bytes:3633496 (3.4 MiB)  TX bytes:261801 (255.6 KiB)
Result:
Raspberry Pi 1 runs "Buster" => Non working DHCP fixed lease
Raspberry Pi 1 runs "RasPlex" => Working DHCP fixed lease
regards
Massaguana
mob-i-l
Contact: Website Facebook Google+ Twitter YouTube
Re: Buster bug report thread: Video on Twitter locked GUI
Sun Aug 04, 2019 7:21 pm
A video on Twitter in Chromium locked/froze the GUI as I clicked to play it. I could not move the mouse pointer and my Raspberry Pi 4 B (4GB RAM, 128MB GPU memory) with 2 screens didn't respond to key-presses. Also the Resource monitors (CPU & RAM usage) and CPU Temperature Monitor stopped. It was this video, but embedded with the other tweets:
https://twitter.com/Rainmaker1973/statu ... 5207631874
I have noticed problems with playing videos embedded in Twitter before with my Pi4B, but then the videos didn't start.
I have the most upgraded Raspbian Buster. I have not been able to reproduce the bug. I had to log in using SSH from another computer and reboot.
Have Pi0&1A&1B&1B+&2B&3B&4B w/ Raspbian. Started w/ BASIC on ABC80&ZX81 then Forth, Z80… https://scratch.mit.edu/users/mobluse/ https://github.com/mobluse/ https://twitter.com/mobluse/ https://YouTube.com/MOBiL4u/
Spark E
Tue Aug 06, 2019 1:21 am
Apologies if this has been mentioned, I searched and didn't find it listed...
(Raspberry Pi 4 w/4GB Ram, Raspbian Buster)
1) When setting the main Taskbar/Panel/Dock to autohide, maximized windows (or windows dragged to the top of the screen) cover the panel (and also custom panels) and though I can see a sliver of change happening when I hover at the top of the screen ( Panel Drops down) the panel won't stay on top of windows in focus.
I have tried all the permutations in the panel Preferences. I have checked "Make window managers treat the panel as a dock" and "Reserve Space.." to no avail. I have also manually edited the LXDE Panel config file and set the panel to be "above", which I had to do in previous Raspbian Versions, but still no joy. I even created another user and copied my old working LXDE panel configs from Stretch to that user with no success.
Probably an openbox issue, but I still want to bring it to attention.
SOLVED: Created ~/.config/openbox/lxde-pi-rc.xml by using obconf (which I read earlier is not the approved Raspbian method - but I need a working auto-hide panel) file and added:
  <applications>
    <application name="panel">
      <skip_taskbar>yes</skip_taskbar>
      <layer>above</layer>
    </application>
    <application name="panel" type="dock">
    </application>
2) Love the hardware accelerated VLC, however it only renders on certain files, crashes on the majority of webm, wmv, mp4, and avi files I have tested. I get Segfaults on some, "cache_read stream error: AStreamSeekStream: hard seek failed" and segfaults on others. I can play them fine using mplayer or a web browser.
UPDATE: I happen to revert back to the stock "Pi" user login and VLC would open up most of the video formats above without segfaulting. I will troubleshoot permissions and group settings I have for my test user and follow up.
SOLVED: I added my new user to the "video" group and now VLC no longer segfaults. I guess this makes sense, but I've never had to do this for however long VLC has been around.
In general, everything such as video, photos, fonts, and windows render so much more clearly on Buster on rPi 4 than Stretch on a rPi 3+!
This is the Pi that I have been waiting for. My eyes thank you!
plugwash
Tue Aug 06, 2019 1:28 pm
Yes, it's broken :/, specifically it's not compatible with python 3.7. There was a patch, but it seems it never got uploaded for some reason. https://bugs.debian.org/cgi-bin/bugrepo ... bug=903529
It seems Debian removed the package from buster, but I didn't remove it in raspbian. I'm not sure why I didn't pick up the breakage and remove it.
epoch1970
Tue Aug 06, 2019 1:59 pm
Perhaps it has to do with the reservation being "deaktiviert" in the server?
beta-tester
xgps is broken... "TypeError: Couldn't find foreign struct converter for 'cairo.Context'"
Tue Aug 06, 2019 2:22 pm
using the raspbian image (2019-07-10-raspbian-buster.zip) on my RPi3B+ with a GPS device connected,
i couldn't fully use xgps anymore.
the skyview wasn't there/was broken and on the terminal console i got the message
i figured out, that the python module "python-gi-cairo" was missing.
after installing that package everything was working again.
sudo apt install python-gi-cairo
i think it must be a bug in the package management.
normally all dependencies will be solved by installing necessary packages automatically.
sudo apt install gpsd gpsd-clients
i am not sure, if it was an issue with the raspbian image out of the box or if it came from an upgrade afterwards.
RPi B (rev1, 256MB), B (rev2, 512MB), B+, 2B, 3B, 3B+, ZeroW, 4B (4GB), ...
Spark E
Tue Aug 06, 2019 5:51 pm
Is xdg-screensaver broken in Buster?
I see it is installed, but screensaver or lock screen functionality is not working.
issuing command "xdg-screensaver activate" returns nothing, issuing command "xdg-screensaver status" also returns nothing.
I don't see any screensaver settings available in the preferences tools.
SOLVED: I'm an idiot. Should not have assumed that xscreensaver was installed.
sudo apt install xscreensaver
algorithm
Wed Aug 07, 2019 10:08 am
1. "vcgencmd get_mem arm" reports 948 MB (plus 76 MB for gpu makes 1 GB) on a Pi 4 with 4 GB.
2. "vcgencmd get_config sdram_freq" is not implemented
Botspot
Wed Aug 07, 2019 10:32 pm
Also posted here.
I have used a Pi 3B for 2 years now as a full desktop computer. I have found a few annoying bugs within the OS, bugs which I feel are really simple to fix.
First bug is when I enable single click option in pcmanfm.
Since pcmanfm handles the desktop, the desktop also behaves like the file manager, that is, the same single click behavior. Problem is, after right-clicking on one of the desktop icons, the mouse cursor stays stuck in the "hover" state, no matter if it is hovering over a desktop icon or not. Here, see for yourself: Image
The only way I know of to fix the problem is to kill pcmanfm and restart it. I am so bothered by this bug that I have to leave single click off.
Second bug involves Minecraft. When minecraft is "restored", that is, visible but not maximized, it behaves correctly. But when I maximize it, the mouse pointer cannot travel across the whole screen. Instead it is confined to the upper-left side.
I have drawn a red rectangle around the boundaries of where the mouse can go when minecraft is maximized. Why does this bug matter? OK, it is not that big of a deal, but I find it rather bothersome I have to exit full screen every time I want to select a new material after pressing E.
Third bug happens with VLC. This bug is fairly new, and I think it came with the November update to VLC that included MMAL video decoding.
On my Pi 3, playing a video can get pretty laggy when VLC window is "restored". I have found it to be better framerate when in fullscreen. Since the mouse is hidden and no player controls are visible, I am pretty sure this is using some kind of overlay. To enter into fullscreen, I click this button:
Note: for some reason the key F11 enters into a non-overlay fullscreen mode, so make sure to click the button and not push the key.
Once I am in this overlay fullscreen, the video plays much better! To exit fullscreen I push Esc. What's the problem? Exiting fullscreen requires VLC to be the focused window. If VLC somehow loses that focus while in fullscreen, there is no easy way to exit, as the currently focused window will be receiving your Esc command, instead of VLC.
Several times I have had to resort to R-E-I-S-U-B to get out of it, other times repeatedly pushing Alt-F4 until the overlay disappears. Out of these three bugs, I think this one is easiest to fix. Just make VLC ensure it remains focused while in fullscreen, and the problem is solved.
My doctor told me my brain is as useful as a Raspberry Pi. Is that a compliment?
trejan
Wed Aug 07, 2019 10:38 pm
This is normal because GPU can only access a maximum of1GB so from its point of view, the ARM cores only have 948MB.
This is intentional.
Fraoch
Thu Aug 08, 2019 1:48 pm
Can anyone confirm that webkitgtk is broken on Buster on the Pi1?
Whenever I try to run Midori or Web on the Pi1B I get a segmentation fault.
https://www.raspberrypi.org/forums/view ... 6#p1511486
These browsers work fine on the Pi2, the 3B+ and the 4.
An alternative, lightweight browser is needed on the 1 because Chromium is so slow as to be unusable on the 1. The only browser that runs on the 1 is Dillo, and Midori or Web are much better without being overly resource-intensive.
Pencoed-made Model 1B, Samsung memory
2B 1.1
3B+
4B 2GB
Return to “Raspbian”
