In which Basic should the conversion tool be written and could it convert itself?DavidS wrote: ↑Sat Jul 20, 2019 3:28 pmI think someone could probably write a program to convert source that uses the extensions between your BBC BASIC and Steves extensions if they so wished. I do not think it would be to difficult.RichardRussell wrote: ↑Sat Jul 20, 2019 2:15 pmIf that were ever to happen it would make the rift between the Wilson and Russell strands of BBC BASIC unbreachable, because whatever the merits of Steve's extensions, and of mine, they are fundamentally incompatible (not even similar, in most cases). Not surprisingly, I would rather support the moves to incorporate my extensions in ARM BASIC, as exemplified by Jonathan Harston's BASICPlus. Sadly development of that stalled several years ago, despite Jonathan having already implemented several of my extensions, and as his modifications were made to a version of ARM BASIC which has long been superseded it might be difficult to transfer them to a newer version.
Re: Introduction to BBC BASIC
- RichardRussell
Don't you need two conversion tools, one for each direction?! In all seriousness an 'integrated' BasAlt would probably need to have significantly greater functionality than Steve's existing bolt-on extensions do to support full conversion from my BASIC, for example in respect of new data types (e.g. 64-bit integers which as far as I know BasAlt doesn't currently support). I have tried to locate an up-to-date set of BasAlt documentation but all I can find is in Acorn StrongHelp format which is gobbledegook when viewed in something like WordPad. If there's an HTML or PDF version I'd appreciate a link.
Try viewing the BasAlt documentation with StrongHelp (it is a StrongHelp manual). Just an idea.RichardRussell wrote: ↑Sat Jul 20, 2019 5:50 pmDon't you need two conversion tools, one for each direction?! In all seriousness an 'integrated' BasAlt would probably need to have significantly greater functionality than Steve's existing bolt-on extensions do to support full conversion from my BASIC, for example in respect of new data types (e.g. 64-bit integers which as far as I know BasAlt doesn't currently support). I have tried to locate an up-to-date set of BasAlt documentation but all I can find is in Acorn StrongHelp format which is gobbledegook when viewed in something like WordPad. If there's an HTML or PDF version I'd appreciate a link.
I do not think Steve ever wrote a different version of the manual.
RPi = The best ARM based RISC OS computer around
More than 95% of posts made from RISC OS on RPi 1B/1B+ computers. Most of the rest from RISC OS on RPi 2B/3B/3B+ computers
Is there a version of StrongHelp that works on my Android phone? I tried the Play Store but all it said was "Did you mean: StrongHold."DavidS wrote: ↑Sun Jul 21, 2019 1:29 amTry viewing the BasAlt documentation with StrongHelp (it is a StrongHelp manual). Just an idea.RichardRussell wrote: ↑Sat Jul 20, 2019 5:50 pmDon't you need two conversion tools, one for each direction?! In all seriousness an 'integrated' BasAlt would probably need to have significantly greater functionality than Steve's existing bolt-on extensions do to support full conversion from my BASIC, for example in respect of new data types (e.g. 64-bit integers which as far as I know BasAlt doesn't currently support). I have tried to locate an up-to-date set of BasAlt documentation but all I can find is in Acorn StrongHelp format which is gobbledegook when viewed in something like WordPad. If there's an HTML or PDF version I'd appreciate a link.
For the preservation of significant digital artifacts, it might be reasonable to create a copy that is readable using existing web standards. Alternatively, could a StrongHelp browser be written in JavaScript?
Using the web standards, google, I cannot find any specification for the StrongHelp format.
Can you post that file here perhaps we can work something out from it.
- RichardRussell
Is there a StrongHelp reader for Windows? I certainly don't have one. All documentation should be available in a standard format that everybody can read, and you can't get more standard than HTML or PDF (or even plain text as a fallback).
- RichardRussell
Turns out there is an attempt at a StrongHelp reader for WIndows, "StrawHelp"
https://heyrick.eu/software/strawhelp/
Source code in Visual Basic here:
https://heyrick.eu/software/strawhelp/download.html
You beat me to it.Heater wrote: ↑Sun Jul 21, 2019 9:37 amTurns out there is an attempt at a StrongHelp reader for WIndows, "StrawHelp"
Make sure to download the dependencies first. Install them and skip any warnings.
Download the Basalt manual zip file from http://kappa.me.uk/StrongHelp/shBasalt175.zip
Copy the file in the zip to Program Files (86)/Heyrick/StrawHelp/Manuals and give it an extension .3d6.
Straw help does not completely parse all that StrongHelp can, and my manuals do exploit everything. So the result might appear a little odd. All the words will be there, but maybe not in the original layout. ;-(
You found that, but I have not pointed to it. It was an attempt to parse the StrongHelp manual into HTML, but failed. It is very out of date anyway.RichardRussell wrote: ↑Sun Jul 21, 2019 9:31 amThe official BasAlt website appears to be here but the links all point back to the same page or lead to a 404![]()
It is Basalt not BasAlt.
The StrongHelp format is described somewhere here: http://www.riscos.info/downloads/stronghelp/manuals/
… but in true RISC OS fashion, the files themselves are stored in the proprietary StrongHelp format, so you can only read them in using StrongHelp. You can't print a StrongHelp manual (!!!), you can't export, and the files are binary (of course).
Sometimes, RISC OS seems as interoperable as Krikkit robots …
‘Remember the Golden Rule of Selling: “Do not resort to violence.”’ — McGlashan.
Pronouns: he/him
Pronouns: he/him
Yep, I found those StongHelp format manuals.
It's hopeless. I give up.
I believe that someone made a StrongHelp viewer for other systems. I think it was for Linux if memory serves me.ejolson wrote: ↑Sun Jul 21, 2019 2:19 amIs there a version of StrongHelp that works on my Android phone? I tried the Play Store but all it said was "Did you mean: StrongHold."DavidS wrote: ↑Sun Jul 21, 2019 1:29 amTry viewing the BasAlt documentation with StrongHelp (it is a StrongHelp manual). Just an idea.RichardRussell wrote: ↑Sat Jul 20, 2019 5:50 pm
Though there is a tool to extract the contents of strong help manuals to text files (you will loose the links, and have some weard styling here and there for what would be image, style, and link references). This later is available as part of the RISC OS SDK for Linux based systems.
And you know that I dislike Java Script.
The StrongHelp files are just an imageFS. In other words like a disk image that can be mounted on other OS's. The files inside these FS images are either text or Sprites (RISC OS Raster graphics Files).scruss wrote: ↑Sun Jul 21, 2019 4:30 pmThe StrongHelp format is described somewhere here: http://www.riscos.info/downloads/stronghelp/manuals/
You can get the text files out in RISC OS from StrongHelp, very easily. Just open the manual, then middle click in the window, select "Open Directory" and it will open the manuals ImageFS in a normal filer window.
See my post above for info on how to get to them on Linux
I dissagree with sticking to a "current standard" of any kind. My reasoning is that we have lost just as many long standing standard file formats as we still have. There is no way to know for sure that a given file format will be easily accessable in 20 years time (and software can last a lot longer than that).RichardRussell wrote: ↑Sun Jul 21, 2019 9:05 amIs there a StrongHelp reader for Windows? I certainly don't have one. All documentation should be available in a standard format that everybody can read, and you can't get more standard than HTML or PDF (or even plain text as a fallback).
And as mentioned above there are multiple ways to get at the data in StrongHelp files.
A format designated as suitable for digital archival comes with a guarantee to still be accessible after 20 years. While it could still happen that a digital apocalypse puts an end to the world as we know it, barring that, those archival formats really will be available for a long time.DavidS wrote: ↑Sun Jul 21, 2019 8:53 pmI dissagree with sticking to a "current standard" of any kind. My reasoning is that we have lost just as many long standing standard file formats as we still have. There is no way to know for sure that a given file format will be easily accessable in 20 years time (and software can last a lot longer than that).RichardRussell wrote: ↑Sun Jul 21, 2019 9:05 amIs there a StrongHelp reader for Windows? I certainly don't have one. All documentation should be available in a standard format that everybody can read, and you can't get more standard than HTML or PDF (or even plain text as a fallback).
On the other hand, since StrongHelp has already become quite difficult for people running popular operating systems to read, it seems of immediate practical importance to convert anything of value to a more accessible format.
How hard would it be for you to extract the documentation for Basalt as a subdirectory of text files and images?
- RichardRussell
You have to be kidding. There's no way I am going to risk installing a dozen or so ancient DLLs and OCXs, especially if I am expected to do so by running an unsigned Setup.exe which may request elevation under UAC! The author of that StrawHelp utility could have written it in BBC BASIC for Windows which has no dependencies whatever, other than what comes as standard with Windows. Indeed I would have thought that was the obvious choice of language for a tool designed to read RISC OS help files in Windows, but what do I know?Steve Drain wrote: ↑Sun Jul 21, 2019 11:04 amMake sure to download the dependencies first. Install them and skip any warnings.
- John Spikowski
- Contact: Website
Amazon needs to sponsor an archival bank for software that will evaporate if permanent storage isn't found.
StrongHelp is an example of a program that is not written in BBC BASIC on RISC OS.RichardRussell wrote: ↑Sun Jul 21, 2019 9:45 pmYou have to be kidding. There's no way I am going to risk installing a dozen or so ancient DLLs and OCXs, especially if I am expected to do so by running an unsigned Setup.exe which may request elevation under UAC! The author of that StrawHelp utility could have written it in BBC BASIC for Windows which has no dependencies whatever, other than what comes as standard with Windows. Indeed I would have thought that was the obvious choice of language for a tool designed to read RISC OS help files in Windows, but what do I know?Steve Drain wrote: ↑Sun Jul 21, 2019 11:04 amMake sure to download the dependencies first. Install them and skip any warnings.
DavidS,
There is no info on how to get to them on Linux in your post above.See my post above for info on how to get to them on Linux
OK. How? Exactly?The StrongHelp files are just an imageFS. In other words like a disk image that can be mounted on other OS's.
Disagree how you like. But if the format used ASCII and a markup like HTML, SGML, XML, JSON, MD, etc then at least any current computer could open it and display it in an editor. It would be human readable for the next million years, even if impressed as binary dots on clay tablets. We would have time to figure out how all the formatting/linking marks worked.I dissagree with sticking to a "current standard" of any kind. My reasoning is that we have lost just as many long standing standard file formats as we still have. There is no way to know for sure that a given file format will be easily accessable in 20 years time (and software can last a lot longer than that).
As hinted at above perhaps. Please tell in detail how to do this on Raspbian, Debian, any other Linux. Or Windows or Mac will do.And as mentioned above there are multiple ways to get at the data in StrongHelp files.
Read again. I explained where to get the tool to extract the files from the StrongHelp ImageFS.
Sorry missinterpetable wording. It can be mounted in RISC OS, though I was using the analogy of disk images in other OS's that can be mounted.OK. How? Exactly?The StrongHelp files are just an imageFS. In other words like a disk image that can be mounted on other OS's.
ASCII itself is only recently been widely adopted (only about 40 years has it been widely adopted). People expected similar from EBCD text encodings (with multiple of those).Disagree how you like. But if the format used ASCII and a markup like HTML, SGML, XML, JSON, MD, etc then at least any current computer could open it and display it in an editor. It would be human readable for the next million years, even if impressed as binary dots on clay tablets. We would have time to figure out how all the formatting/linking marks worked.I dissagree with sticking to a "current standard" of any kind. My reasoning is that we have lost just as many long standing standard file formats as we still have. There is no way to know for sure that a given file format will be easily accessable in 20 years time (and software can last a lot longer than that).
I do not use the Linux tools for RISC OS development personally, though you can look at the tools for the GCCSDK for RISC OS:As hinted at above perhaps. Please tell in detail how to do this on Raspbian, Debian, any other Linux. Or Windows or Mac will do.And as mentioned above there are multiple ways to get at the data in StrongHelp files.
http://www.riscos.info/index.php/GCCSDK
- John Spikowski
- Contact: Website
David,
It seems you have no interest in Raspbian so I've given up hope you would be the guy to give the Brandy extension module a refresh for RPi users.
It will be interesting to see if you can get ScriptBasic running on RISC OS. ScriptBasic runs great on ReactOS if a Windows alternative excites you.
DavidS,
Whatever "ImageFS" is, it's not a file system that Linux or any other OS knows about.
We managed to decipher Egyptian hieroglyphs from the Rosetta Stone. So I'm sure the simple ASCII representation, or similar, will be no problem.
All we need just now us a clue...
The idea is to get the documentation out to the world in a way they can actually read it.
It's a file right? It's in a format that has some specification right? Can you show us that specification?
I read again. No you did not. No links to anywhere. No instructions. Nothing.Read again. I explained where to get the tool to extract the files from the StrongHelp ImageFS.
Yes. So what?ASCII itself is only recently been widely adopted (only about 40 years has it been widely adopted).
So what?I do not use the Linux tools for RISC OS development personally,
