pidloop
vcgencmd display_power not working in buster
Fri Jul 12, 2019 7:49 pm
Hello!
On my rpi 3 running Stretch I could turn my hdmi power off and on using vcgencmd display_power 0/1. On my new rpi 4 running Buster, with the same display, this no longer works. Whether I give 0 or 1 the display stays on and the command always reports display_power=1.
Thanks for any ways to fix this or an alternate means to control display power.
Thanks.
sapnho
Re: vcgencmd display_power not working in buster
Sat Jul 20, 2019 9:05 am
Yep, same issue here. Buster works fine on the Pi 3 but on the Pi4 the command doesn't work.
www.TheDigitalPictureFrame.com
Build a really great digital picture frame with the Raspberry Pi.
With lots of great tips from this forum.
Iri-dium
Sat Jul 20, 2019 9:14 am
tvservice -o
might work
sapnho
Sat Jul 20, 2019 10:47 am
Yes, that works and
 /opt/vc/bin/tvservice -p; sudo /bin/chvt 6; sudo /bin/chvt 7
to turn it back on.
But I used vcgencmd in many areas and it would be nice to have it back. :?
cfreybergu
Wed Sep 18, 2019 1:34 am
As of noon 18 Sept 2019 NZST, this problem appears to have been fixed by the latest firmware/kernel version ( ?? 4.19.73-v71+#1266 SMP ??) :D
vcgencmd version
returned
Sep 17 2019 21:10:29
Copyright (c) 2012 Broadcom
version 549267a4b69d1c83ccc9cce7f60773831609f208 (clean) (release) (start)
At the time I installed it, that firmware/kernel package was unavailable through apt-get update, but I guess that situation will change fairly soon.
Chris F
sapnho
Thu Sep 19, 2019 2:06 pm
Excellent news for all digital picture frame fans! :D
sapnho
Mon Oct 21, 2019 2:03 pm
I only just got around to checking on the updated vcgencmd in Buster which again allows for turning the hdmi output on/off.
So I updated everything with
sudo apt update && sudo apt full-upgrade
and rebooted. However when I enter sudo
the display doesn't turn off.
Does it work with anybody in the described way?
Firmware is
Linux pi4withpi3d 4.19.79-v7l+ #1273 SMP Fri Oct 11 18:23:45 BST 2019 armv7l GNU/Linux
sapnho
Mon Oct 21, 2019 2:31 pm
Ah, just found out that it actually works in HDMI 0 (I believe that is the left HDMI slot of the two)
Does anybody know how to activate it also for HDMI 1?
Mon Oct 21, 2019 2:48 pm
It should work on both at the same time...not sure what is going on there.
Botspot
Wed Oct 23, 2019 5:00 pm
It hasn't been implemented for the Pi 4 until recently. See here, here, here, and here.
But recently the bootloader and kernel got an update. Just run this and you should be good to go.
sudo apt update
sudo apt full-upgrade -y
Edit: clarified grammar
My doctor told me my brain is as useful as a Raspberry Pi. Is that a compliment?
Return to “Raspbian”
