ggat
Screenly OSE wifi issue
Fri Jul 19, 2019 5:58 pm
I'm working to set up Screenly OSE. After the initial install, I'm presented with a Screenly Splash page that indicates a network can't be found and I should connect a laptop or smartphone to a Screenly SSID (Network, password and the site 'Screenly.io/wifi' ) is provided. That said when I connect the the provided SSID, nothing happens, when I direct my browser to screenly.io/wifi I get a page not found error.
Any advice on how to continue would be great.
Andyroo
Re: Screenly OSE wifi issue
Sat Jul 20, 2019 4:35 pm
Strange address - screenly.io is a web site (and does not have a WiFi page on it).
Are you sure the address is not the Pi running the program?
bnupen
Mon Sep 30, 2019 4:25 pm
Trying to setup the wifi on Screenly OSE. The message that appears on the Raspberry Pi is that "No network connection were found...." then sends me to the site screenly.io/wifi When attempting I get the error on the webpage 404 not found
I had seen a couple others with this issue, has there been any resolution or workaround?
AR Projection
Sun Dec 01, 2019 2:00 am
Hi I am having the same issue, any solution yet?
Return to “Other”
