I even took the time to design & 3D print a nice system around it.
Is there any reason you think we are not looking this stuff? No need to ask, we do know what is needed. We have plenty of stuff to fix, as happens with all new releases, but this is close if not at the top of the list.
This is called tearing, and without making X double buffer (!) will be difficult to mitigate against. And changes to X are not generally something we do.
It's not the way X does things, therefore is almost a complete rewrite of the whole windowing system.hardwaremack-orginal wrote: ↑Tue Jul 16, 2019 9:30 pmif double buffer is what you need to make it not look bad... then why wouldn't you do it?
*p30 (or worse *p24) is a slide show. That's just the way it is.
It's not only your eyes. (almost) all people perceive it that way.
Even wayland on the pi has screen tearing however. Weston will go nuts with screen tearing. I wasn't able to test plasma 5.16 wayland (not on raspbian) because it had all kinds of artifacts. I really hope the graphics drivers get sorted out in a few months, as at the moment they have quite a few issues. Tearing even with compositing is really horrible on the pi 4.
Hello!
x server/chromium doesnt double buffer. vlc does double buffer.riccetto80 wrote: ↑Mon Sep 02, 2019 9:30 pmHello!
sadly i experience tearing in any youtube video, windowed or full screen and is driving me insane.
but i dont understand:
Usually tearing is not present when refresh rate is the same or less then the monitor refresh!
for example my tv/monitor is set up at 60hz, so 60 frame for second, the youtube video is less (24/30 ps, i dont remember), or at max, the 60 fps (so the same at the monitors refresh), so why happen the tearing?
also, i cannot find option to force or turn on, v-sync, is not possible in raspbian last version?
and why in vlc the tearing is not happen? while in chromium with youtube, happen so badly?
im a confused noob, lol.
thanks for reply!
It may also depend on your specific monitor. Either than or I am totally insensitive to the issue. A Pi 3B+ certainly had artifacts and had issues playing YouTube, for me on the same monitor. A fully up to date 4B 4GB model does not have screen tearing issues for me when viewing YouTube using the standard Chromium (no tweaks and tuning) that is included in Raspbian Buster. This is on a fairly generic HP monitor (HP 22fw 21.5" FHD IPSGaming Monitor with AMD FreeSync Technology, 1920 x 1080, 75Hz, 5ms). VLC also plays movies with any issues.riccetto80 wrote: ↑Tue Sep 03, 2019 10:08 amthere is a way to install something, a utility (compton? i dont know if is applicable on raspbian, im a total noob i try to learn now, after i buy a pi 4, just searched google) to fix the tearing issue on the raspberry pi 4?
really drive me insane, you cannot look youtube content and keep have horizontal line on the video.![]()
use kodi or open youtube links in vlc. i dont think any browser will fix the issue.riccetto80 wrote: ↑Tue Sep 03, 2019 10:08 amthanks for reply!
Fireofx or other browser have double buffer?
I've tried it on three different monitors from different manufacturers. All three had tearing. A HP, Dell, and Samsung 1080p monitor. The dell supports up to 144hz too. None of my computers get tearing connected up, so it's certainly the pi having issues. Perhaps your specific monitor doesn't have tearing issues, or you are truly insensitive to tearing.bjtheone wrote: ↑Tue Sep 03, 2019 1:38 pmIt may also depend on your specific monitor. Either than or I am totally insensitive to the issue. A Pi 3B+ certainly had artifacts and had issues playing YouTube, for me on the same monitor. A fully up to date 4B 4GB model does not have screen tearing issues for me when viewing YouTube using the standard Chromium (no tweaks and tuning) that is included in Raspbian Buster. This is on a fairly generic HP monitor (HP 22fw 21.5" FHD IPSGaming Monitor with AMD FreeSync Technology, 1920 x 1080, 75Hz, 5ms). VLC also plays movies with any issues.riccetto80 wrote: ↑Tue Sep 03, 2019 10:08 amthere is a way to install something, a utility (compton? i dont know if is applicable on raspbian, im a total noob i try to learn now, after i buy a pi 4, just searched google) to fix the tearing issue on the raspberry pi 4?
It's not the monitors. It's the software not being double buffered. Tearing occurs when the frame being viewed on the display is changed whilst on the display. Double buffering means changes are drawn on another frame, and that is switched on to the display at frame sync time, and the old frame is then used to draw on.aberts10 wrote: ↑Wed Sep 04, 2019 12:34 amI've tried it on three different monitors from different manufacturers. All three had tearing. A HP, Dell, and Samsung 1080p monitor. The dell supports up to 144hz too. None of my computers get tearing connected up, so it's certainly the pi having issues. Perhaps your specific monitor doesn't have tearing issues, or you are truly insensitive to tearing.bjtheone wrote: ↑Tue Sep 03, 2019 1:38 pmIt may also depend on your specific monitor. Either than or I am totally insensitive to the issue. A Pi 3B+ certainly had artifacts and had issues playing YouTube, for me on the same monitor. A fully up to date 4B 4GB model does not have screen tearing issues for me when viewing YouTube using the standard Chromium (no tweaks and tuning) that is included in Raspbian Buster. This is on a fairly generic HP monitor (HP 22fw 21.5" FHD IPSGaming Monitor with AMD FreeSync Technology, 1920 x 1080, 75Hz, 5ms). VLC also plays movies with any issues.riccetto80 wrote: ↑Tue Sep 03, 2019 10:08 amthere is a way to install something, a utility (compton? i dont know if is applicable on raspbian, im a total noob i try to learn now, after i buy a pi 4, just searched google) to fix the tearing issue on the raspberry pi 4?
