678GUY
Netflix on raspberry pi 3 B+
Thu Oct 04, 2018 11:20 pm
I hope its the right place to post this but i can't seem to be able to get netflix working i tried 3 articles and 2 videos and i still can't get it to work.
i don't know if im doing somthing wrong or my what but i would appreciate some help, i only need netflix and don't care about other stuff that it will play, if you have netflix working i would really like help.
mooblie
Re: Netflix on raspberry pi 3 B+
Thu Oct 04, 2018 11:28 pm
Search "Kodi" on the Pi?
Thu Oct 04, 2018 11:37 pm
https://www.raspberrypi.org/forums/view ... p?t=222954
adieu
klricks
Thu Oct 04, 2018 11:40 pm
Douglas6
Fri Oct 05, 2018 12:07 am
2 cents from one who has lurked on this forum for years. Forget about using the Pi for Netflix or other DRM providers like Amazon, Hulu, etc. If it works, it won't for long. Other options exist, similarly priced to the Pi.
Use the Pi for what it was intended: learning to write your own code.
678GUY
Fri Oct 05, 2018 3:04 pm
kodi didnt work for me not addons seemed to work
678GUY
Fri Oct 05, 2018 3:05 pm
didnt work for me as well
678GUY
This thread may be of interest: https://www.raspberrypi.org/forums/view ... p?t=223305
just tried it, didnt work
Rascas
Fri Oct 05, 2018 3:24 pm
It does work, at least for me and another guy, just follow the instructions on the Netflix addon github page. If you have any doubts, please post in the Kodi 18 forum topic.
Atton
Wed Oct 10, 2018 1:36 pm
The plugin is broken even when Kodi is installed correctly.
Rascas
Wed Oct 10, 2018 5:56 pm
It was working just fine on weekend. Did you followed the instructions on the plugin github page ? You need to install kodi-inpustream-adaptive from the repo and also python-cryptodomex (with "pip install pycryptodomex", as the user which is going to run Kodi). Restart Kodi after that. If it still doesn't work after that, post your Kodi log in Kodi 18 testbuilds topic, following this:
https://kodi.wiki/view/Log_file
Atton
Thu Oct 11, 2018 1:17 pm
Did that the end result was a green screen with random pixels.
Rascas
Thu Oct 11, 2018 1:26 pm
I tested Netflix yesterday and it worked just fine. Just complaining with little to no information is hard to help you... The Kodi debug log will help us identify your problem.
Atton
Fri Oct 12, 2018 2:30 pm
This is the log Kodi produces when I try to play violet ever-garden using the netflix addon. The audio works however the video is like LSD gone bad. I haven't a clue when it comes to python so I haven't a clue how to fix this.
https://puu.sh/BJPSk/33babb492f.log
Rascas
Fri Oct 12, 2018 6:51 pm
We need a debug log, not a normal one, please follow the instructions on my previous post.
In the meantime, on video settings, make sure you have the default settings, so MMAL enabled and OMXPlayer disabled.
dom
Tue Oct 23, 2018 12:35 pm
If you want netflix and amazon prime then kodi 18 is what you want.
Kodi 18 is currently beta so you want a nightly milhouse build.
Read the "Amazon Prime / Netflix / inputstream.adaptive" instructions on the first post of this thread.
Kodi 18 should be reaching release in the next couple of months so you may want to wait for that (although the beta has been stable for me for months).
Rascas
Tue Oct 23, 2018 12:54 pm
We were talking about Kodi 18 but on Raspbian and Netflix and Amazon Prime works just fine, no need to install a separate OS just for that. Atton problem was most likely that he had OMXPlayer enabled.
zelozelos
Wed Jan 09, 2019 11:35 pm
what we all need to do is plea, beg, bargain, insist that netflix supports raspbian with a browser. If you remember while ago, netflix would not work with linux , not officially, and getting it to work was hard, keeping it working was even more hard. its all the same thing. same issues. we try and trick netflix into seeing a compatible browser, hack it in some way whatever, then something breaks it...just ask netflix, the more people that ask the more inclined they will do it.
Drakkhis
Mon Jan 21, 2019 12:04 am
I have been trying to deal with this and I have found Using SteamLink and using the Steam Browser works well, the only problem is it requires a base computer on the same network to stream from
ventz
Fri Jul 19, 2019 7:06 am
Here are easy directions for doing this in 3 steps:
https://blog.vpetkov.net/2019/07/12/net ... -chromium/
oss001
Sun Jul 28, 2019 7:49 am
I just ran this guide with OSMC setup. Super simple and works great. I did set the max resolution in the InputStreamAdaptive addon to 720p as 1080p stuttered. Other then that works perfectly.
https://makingstuffwork.net/technology/ ... rime-kodi/
Return to “Media centres”
