terraspace
gksudo deprecated
Tue Jul 16, 2019 2:51 pm
gksudo has been deprecated in Debian and thus in Buster.. what is the proposed alternative for example to run pcmanfm ?
Re: gksudo deprecated
Tue Jul 16, 2019 3:28 pm
https://itsfoss.com/gksu-replacement-ubuntu/
terraspace
Wed Jul 17, 2019 9:03 am
I had seen that link and tried those options, but neither pkexec or admin: style ports seems viable.
pkexec pcmanfm gives cannot open display and there isn't a valid admin: URI to just open the app without a file ref ?
jojopi
Wed Jul 17, 2019 10:26 am
"sudo sudo -V" shows that DISPLAY and XAUTHORITY variables are preserved by default, and I cannot find any evidence that gksudo was ever really needed in Debian/Raspbian:
sudo pcmanfm
I do notice that "ssh -X" sessions first require:
export XAUTHORITY=~/.Xauthority
klricks
Wed Jul 17, 2019 12:27 pm
What's wrong with just sudo?
sudo pcmanfm
HawaiianPi
Wed Jul 17, 2019 6:44 pm
sudo pcmanfm
It doesn't protect files in your /home directory and some configuration files may end up owned by root (see link above).
andylh
Wed Jul 17, 2019 11:05 pm
I added the stretch repository to the sources.list in /etc/apt. Just copied the line for buster replacing "buster" with "stretch"
Updated the cache, and installed gksu with "sudo apt-get install gksu".
After installing gksu I recommend commenting out the line added in sources.list to avoid future problems of wrong versions being incorporated.
Used main menu editor to create a menu item for "gksudo pcmanfm"
Have still to find a way to successfully add a menu item into the pcmanfm's list of commands to open as root - notwithstanding finding several such ways documented on the www - unfortunately, none have worked.
ksharindam
Thu Jul 18, 2019 5:10 pm
The only proper alternative for gksu I found is lxqt-sudo.
sudo apt install lxqt-sudo
jojopi
Thu Jul 18, 2019 11:00 pm
gksudo does nothing to reduce that risk, compared with regular sudo. The only file it treats specially is .Xauthority, and that file is never written to by normal clients.
The reason for copying the cookie to /tmp is that that is the only way it will be readable when the target user is not root, or the home filesystem is on NFS or FUSE, or any MAC scheme is in force. None of these are typical in Raspbian.
I do not recommend running any GUI application as root. But if you must, plain "sudo" should be fine.
(As for menu-based root-launching, that is an even worse idea. The complaint presumably is that plain sudo fails in those contexts, rather than that it damages the home directory.)
PaPaTheGMan
Mon Aug 12, 2019 2:30 pm
Would like to explore. I installed it, but have no clue how to use. Could not find examples. Help would be greatly appreciated.
thagrol
Mon Aug 12, 2019 7:02 pm
I imagine something like
lxqt-sudo [command [arguments]]
is all you need. Though if you're not familiar with what sudo/gksudo/lxqt-sudo do I'd advise against random experimentation.
You could try reading the man page for it:
man lxqt-sudo
Attempts to contact me outside of these forums will be ignored unless signed in triplicate, sent in, sent back, queried, lost, found, subjected to public enquiry, lost again, and finally buried in soft peat for three months and recycled as firelighters
Return to “Raspberry Pi OS”
