kotovasii wrote: ↑Wed Jul 03, 2019 7:00 pm
chipace wrote: ↑Wed Jul 03, 2019 6:36 pm
Removed previous config.txt changes and tried with heterogeneous monitors (DELL U2412M and DELL 1905FP). No problems booting, but the second display was blank, but did report settings from "tvservice -s -v 7".
Is there a config file for the monitor configuration that I can clear (delete) so that previous configurations do not interfere when I connect different monitors?
I have been having many issues with Pi4 4GB RAM when changing the GPU_MEMORY setting in the raspi-config and thus the config.txt file. I find that the User Guide is very poor in relation to GPU memory and does not relate clearly how to set it up and what settings to choose. I found that with any settings the quality of resolution is rather "choppy" as if I were back in windows 3.1 /DOS era... I look at my Mac here and Win10 desktops where graphics is smooth, Pi4 display is almost pixelated... I found that changing to 512 MB GPU stops black screen (3 berries or rainbow then hang). The resolution is still awful, despite a good Dell monitor
You should not need to change any memory settings at all - just leave them alone. They do not affect the display at all.
In fact to get the max resolution a monitor exposes, you should just need to plug it in. It should automatically go up to 4kp30. If you specifically want 4kp60 then you can set the hdmi_enable_4k=1 in config.txt.
Note, 4kp60 will only work in HDMI port 0.
That said, there do appear to be some issues with some monitors, and perhaps some Pi4's, which we have been looking in to. For those who are able to try it without worrying about a broken install, rpi-update may have some changes in that will help.
If after all that there are still issues, something weird is going on we need to figure out. Often this is the monitor failing to supply a EDID, or a valid EDID. They should be able to supply something sane even when of, but sometimes they don't work as hoped.
