gordon77
RPI.GPIO and Pi4 issue ?
Tue Jul 02, 2019 8:19 am
I can't pull-up all the inputs, and it errors above pin 26...what's wrong ?
import RPi.GPIO as GPIO
GPIO.setmode(GPIO.BOARD)
GPIO.setwarnings(False)
pins = (3,5,7,8,10,11,12,13,15,16,18,19,21,22,23,24,26,29,31,32,33,35,36,37,38,40)
for pin in range (0,26):
    GPIO.setup(pins[pin], GPIO.IN, pull_up_down=GPIO.PUD_UP)
    print ('pin: '+ str(pins[pin]), GPIO.input(pins[pin]))
gives..
pin: 3 1
pin: 5 1
pin: 7 1
pin: 8 1
pin: 10 1
pin: 11 0
pin: 12 0
pin: 13 0
pin: 15 0
pin: 16 0
pin: 18 0
pin: 19 0
pin: 21 0
pin: 22 0
pin: 23 0
pin: 24 1
pin: 26 1
  File "/home/pi/pins1.py", line 8, in <module>
ValueError: The channel sent is invalid on a Raspberry Pi
works on a Pi3B
pin: 3 1
pin: 5 1
pin: 7 1
pin: 8 1
pin: 10 1
pin: 11 1
pin: 12 1
pin: 13 1
pin: 15 1
pin: 16 1
pin: 18 1
pin: 19 1
pin: 21 1
pin: 22 1
pin: 23 1
pin: 24 1
pin: 26 1
pin: 29 1
pin: 31 1
pin: 32 1
pin: 33 1
pin: 35 1
pin: 36 1
pin: 37 1
pin: 38 1
pin: 40 1
croston
Re: RPI.GPIO and Pi4 issue ?
Tue Jul 02, 2019 8:25 am
I am the maintainer and am working on this.
gordon77
Tue Jul 02, 2019 9:19 am
gordon77
Thu Jul 04, 2019 8:44 am
Any news on the fix ?
croston
Thu Jul 04, 2019 6:56 pm
I'm looking at a fix being available on Sunday.
gordon77
Thu Jul 04, 2019 7:03 pm
Thanks for the info.
croston
Mon Jul 08, 2019 5:13 pm
You can now install the alpha release (for testing purposes):
$ pip3 install --upgrade --pre rpi.gpio
Let me know if it works or not.
gordon77
Mon Jul 08, 2019 6:44 pm
Thanks, That seems to work fine.
jinksto
Sat Jul 13, 2019 12:21 am
This resolved my problem with RPi.GPIO as well.
https://www.raspberrypi.org/forums/view ... 7#p1498777
InnoHub
Mon Aug 26, 2019 5:48 am
Facing problems with GPIO on Pi 4.
Tried the update provided by @croston. But the pip3 install --upgrade --pre rpi.gpio command said that the rpi.gpio is already the latest version and did not upgrade anything.
Are there any further updates or steps to be followed? Have been struggling with this issue for the past couple of days.
Any help would be appreciated.
mattmiller
Mon Aug 26, 2019 10:33 am
Hi and welcome to the forum :)
Unless your problem's identical to this one - best idea is to start your own thread and explain what problem your having
croston
Mon Aug 26, 2019 11:25 pm
This fix is now in Raspbian Buster if you run an update:
sudo apt update && sudo apt full-upgrade
InnoHub
Tue Aug 27, 2019 8:09 am
Thank you!!
I thought the issues I am facing are related to this thread.
As suggested I will start a new thread anyway!
InnoHub
Tue Aug 27, 2019 8:13 am
Thanks for the suggestion.
It did not solve the issue though.
My program works perfectly on Pi 3B+ but not on Pi4 :(
pcmanbob
Tue Aug 27, 2019 8:30 am
Seeing as you have not actually told us what the problem is I don't see what more help we can offer,
we can only provide help based on the information you provide.
dony71
Fri May 22, 2020 5:59 pm
@croston : I have RPi4 and install "pip install RPi.GPIO" and get error below
pi@pi64 ~ $ pip install --user RPi.GPIO
Collecting RPi.GPIO
Using cached RPi.GPIO-0.7.0.tar.gz (30 kB)
Installing collected packages: RPi.GPIO
Running setup.py install for RPi.GPIO ... error
ERROR: Command errored out with exit status 1:
command: /usr/bin/python3.6 -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp /pip-install-8a6ado6k/RPi.GPIO/setup.py'"'"'; __file__='"'"'/tmp/pip-install-8a6ado6k/RPi.GPIO/se tup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'" '"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record /tmp /pip-record-0fg28_61/install-record.txt --single-version-externally-managed --user --prefix= --co mpile --install-headers /home/pi/.local/include/python3.6m/RPi.GPIO
cwd: /tmp/pip-install-8a6ado6k/RPi.GPIO/
Complete output (85 lines):
running install
running build
running build_py
creating build
creating build/lib.linux-aarch64-3.6
creating build/lib.linux-aarch64-3.6/RPi
copying RPi/__init__.py -> build/lib.linux-aarch64-3.6/RPi
creating build/lib.linux-aarch64-3.6/RPi/GPIO
copying RPi/GPIO/__init__.py -> build/lib.linux-aarch64-3.6/RPi/GPIO
running build_ext
building 'RPi._GPIO' extension
creating build/temp.linux-aarch64-3.6
creating build/temp.linux-aarch64-3.6/source
aarch64-unknown-linux-gnu-gcc -pthread -fPIC -I/usr/include/python3.6m -c source/py_gpio.c -o build/temp.linux-aarch64-3.6/source/py_gpio.o
aarch64-unknown-linux-gnu-gcc -pthread -fPIC -I/usr/include/python3.6m -c source/c_gpio.c -o build/temp.linux-aarch64-3.6/source/c_gpio.o
source/c_gpio.c: In function ‘setup’:
source/c_gpio.c:130:9: warning: cast from pointer to integer of different size [-Wpointer-to- int-cast]
130 | if ((uint32_t)gpio_mem % PAGE_SIZE)
source/c_gpio.c:131:34: warning: cast from pointer to integer of different size [-Wpointer-to -int-cast]
131 | gpio_mem += PAGE_SIZE - ((uint32_t)gpio_mem % PAGE_SIZE);
aarch64-unknown-linux-gnu-gcc -pthread -fPIC -I/usr/include/python3.6m -c source/cpuinfo.c -o build/temp.linux-aarch64-3.6/source/cpuinfo.o
source/cpuinfo.c: In function ‘get_rpi_info’:
source/cpuinfo.c:139:28: warning: format ‘%llx’ expects argument of type ‘long long unsigned int *’, but argument 3 has type ‘uint64_t *’ {aka ‘long unsigned int *’} [-Wformat=]
139 | sscanf(revision, "%llx", &rev);
| | uint64_t * {aka long unsigned int *}
| %lx
aarch64-unknown-linux-gnu-gcc -pthread -fPIC -I/usr/include/python3.6m -c source/event_gpio.c -o build/temp.linux-aarch64-3.6/source/event_gpio.o
aarch64-unknown-linux-gnu-gcc -pthread -fPIC -I/usr/include/python3.6m -c source/soft_pwm.c - o build/temp.linux-aarch64-3.6/source/soft_pwm.o
aarch64-unknown-linux-gnu-gcc -pthread -fPIC -I/usr/include/python3.6m -c source/py_pwm.c -o build/temp.linux-aarch64-3.6/source/py_pwm.o
aarch64-unknown-linux-gnu-gcc -pthread -fPIC -I/usr/include/python3.6m -c source/common.c -o build/temp.linux-aarch64-3.6/source/common.o
aarch64-unknown-linux-gnu-gcc -pthread -fPIC -I/usr/include/python3.6m -c source/constants.c -o build/temp.linux-aarch64-3.6/source/constants.o
aarch64-unknown-linux-gnu-gcc -pthread -shared -Wl,-O1 -Wl,--as-needed -L. -Wl,-O1 -Wl,--as-n eeded -L. build/temp.linux-aarch64-3.6/source/py_gpio.o build/temp.linux-aarch64-3.6/source/c_gpi o.o build/temp.linux-aarch64-3.6/source/cpuinfo.o build/temp.linux-aarch64-3.6/source/event_gpio. o build/temp.linux-aarch64-3.6/source/soft_pwm.o build/temp.linux-aarch64-3.6/source/py_pwm.o bui ld/temp.linux-aarch64-3.6/source/common.o build/temp.linux-aarch64-3.6/source/constants.o -L/usr/ lib64 -lpython3.6m -o build/lib.linux-aarch64-3.6/RPi/_GPIO.cpython-36m-aarch64-linux-gnu.so
/usr/lib/gcc/aarch64-unknown-linux-gnu/10.1.0/../../../../aarch64-unknown-linux-gnu/bin/ld: b uild/temp.linux-aarch64-3.6/source/soft_pwm.o:(.bss+0x0): multiple definition of `threads'; build /temp.linux-aarch64-3.6/source/event_gpio.o:(.bss+0x10): first defined here
/usr/lib/gcc/aarch64-unknown-linux-gnu/10.1.0/../../../../aarch64-unknown-linux-gnu/bin/ld: b uild/temp.linux-aarch64-3.6/source/py_pwm.o:(.data.rel.local+0x0): multiple definition of `PWMTyp e'; build/temp.linux-aarch64-3.6/source/py_gpio.o:(.bss+0x0): first defined here
/usr/lib/gcc/aarch64-unknown-linux-gnu/10.1.0/../../../../aarch64-unknown-linux-gnu/bin/ld: b uild/temp.linux-aarch64-3.6/source/py_pwm.o:(.bss+0x0): multiple definition of `gpio_mode'; build /temp.linux-aarch64-3.6/source/py_gpio.o:(.bss+0x218): first defined here
/usr/lib/gcc/aarch64-unknown-linux-gnu/10.1.0/../../../../aarch64-unknown-linux-gnu/bin/ld: b uild/temp.linux-aarch64-3.6/source/py_pwm.o:(.rodata+0x30): multiple definition of `pin_to_gpio_r ev1'; build/temp.linux-aarch64-3.6/source/py_gpio.o:(.rodata+0x30): first defined here
/usr/lib/gcc/aarch64-unknown-linux-gnu/10.1.0/../../../../aarch64-unknown-linux-gnu/bin/ld: b uild/temp.linux-aarch64-3.6/source/py_pwm.o:(.rodata+0xd8): multiple definition of `pin_to_gpio_r ev2'; build/temp.linux-aarch64-3.6/source/py_gpio.o:(.rodata+0xd8): first defined here
/usr/lib/gcc/aarch64-unknown-linux-gnu/10.1.0/../../../../aarch64-unknown-linux-gnu/bin/ld: b uild/temp.linux-aarch64-3.6/source/py_pwm.o:(.rodata+0x180): multiple definition of `pin_to_gpio_ rev3'; build/temp.linux-aarch64-3.6/source/py_gpio.o:(.rodata+0x180): first defined here
/usr/lib/gcc/aarch64-unknown-linux-gnu/10.1.0/../../../../aarch64-unknown-linux-gnu/bin/ld: b uild/temp.linux-aarch64-3.6/source/py_pwm.o:(.bss+0x8): multiple definition of `pin_to_gpio'; bui ld/temp.linux-aarch64-3.6/source/py_gpio.o:(.bss+0x220): first defined here
/usr/lib/gcc/aarch64-unknown-linux-gnu/10.1.0/../../../../aarch64-unknown-linux-gnu/bin/ld: b uild/temp.linux-aarch64-3.6/source/py_pwm.o:(.bss+0x10): multiple definition of `gpio_direction'; build/temp.linux-aarch64-3.6/source/py_gpio.o:(.bss+0x228): first defined here
/usr/lib/gcc/aarch64-unknown-linux-gnu/10.1.0/../../../../aarch64-unknown-linux-gnu/bin/ld: b uild/temp.linux-aarch64-3.6/source/py_pwm.o:(.bss+0xe8): multiple definition of `rpiinfo'; build/ temp.linux-aarch64-3.6/source/py_gpio.o:(.bss+0x300): first defined here
/usr/lib/gcc/aarch64-unknown-linux-gnu/10.1.0/../../../../aarch64-unknown-linux-gnu/bin/ld: b uild/temp.linux-aarch64-3.6/source/py_pwm.o:(.bss+0x510): multiple definition of `setup_error'; b uild/temp.linux-aarch64-3.6/source/py_gpio.o:(.bss+0x728): first defined here
/usr/lib/gcc/aarch64-unknown-linux-gnu/10.1.0/../../../../aarch64-unknown-linux-gnu/bin/ld: b uild/temp.linux-aarch64-3.6/source/py_pwm.o:(.bss+0x514): multiple definition of `module_setup'; build/temp.linux-aarch64-3.6/source/py_gpio.o:(.bss+0x72c): first defined here
/usr/lib/gcc/aarch64-unknown-linux-gnu/10.1.0/../../../../aarch64-unknown-linux-gnu/bin/ld: b uild/temp.linux-aarch64-3.6/source/common.o:(.data+0x0): multiple definition of `gpio_mode'; buil d/temp.linux-aarch64-3.6/source/py_gpio.o:(.bss+0x218): first defined here
/usr/lib/gcc/aarch64-unknown-linux-gnu/10.1.0/../../../../aarch64-unknown-linux-gnu/bin/ld: b uild/temp.linux-aarch64-3.6/source/common.o:(.rodata+0x0): multiple definition of `pin_to_gpio_re v1'; build/temp.linux-aarch64-3.6/source/py_gpio.o:(.rodata+0x30): first defined here
/usr/lib/gcc/aarch64-unknown-linux-gnu/10.1.0/../../../../aarch64-unknown-linux-gnu/bin/ld: b uild/temp.linux-aarch64-3.6/source/common.o:(.rodata+0xa8): multiple definition of `pin_to_gpio_r ev2'; build/temp.linux-aarch64-3.6/source/py_gpio.o:(.rodata+0xd8): first defined here
/usr/lib/gcc/aarch64-unknown-linux-gnu/10.1.0/../../../../aarch64-unknown-linux-gnu/bin/ld: b uild/temp.linux-aarch64-3.6/source/common.o:(.rodata+0x150): multiple definition of `pin_to_gpio_ rev3'; build/temp.linux-aarch64-3.6/source/py_gpio.o:(.rodata+0x180): first defined here
/usr/lib/gcc/aarch64-unknown-linux-gnu/10.1.0/../../../../aarch64-unknown-linux-gnu/bin/ld: b uild/temp.linux-aarch64-3.6/source/common.o:(.bss+0x0): multiple definition of `pin_to_gpio'; bui ld/temp.linux-aarch64-3.6/source/py_gpio.o:(.bss+0x220): first defined here
/usr/lib/gcc/aarch64-unknown-linux-gnu/10.1.0/../../../../aarch64-unknown-linux-gnu/bin/ld: b uild/temp.linux-aarch64-3.6/source/common.o:(.bss+0x8): multiple definition of `gpio_direction'; build/temp.linux-aarch64-3.6/source/py_gpio.o:(.bss+0x228): first defined here
/usr/lib/gcc/aarch64-unknown-linux-gnu/10.1.0/../../../../aarch64-unknown-linux-gnu/bin/ld: b uild/temp.linux-aarch64-3.6/source/common.o:(.bss+0xe0): multiple definition of `rpiinfo'; build/ temp.linux-aarch64-3.6/source/py_gpio.o:(.bss+0x300): first defined here
/usr/lib/gcc/aarch64-unknown-linux-gnu/10.1.0/../../../../aarch64-unknown-linux-gnu/bin/ld: b uild/temp.linux-aarch64-3.6/source/common.o:(.bss+0x508): multiple definition of `setup_error'; b uild/temp.linux-aarch64-3.6/source/py_gpio.o:(.bss+0x728): first defined here
/usr/lib/gcc/aarch64-unknown-linux-gnu/10.1.0/../../../../aarch64-unknown-linux-gnu/bin/ld: b uild/temp.linux-aarch64-3.6/source/common.o:(.bss+0x50c): multiple definition of `module_setup'; build/temp.linux-aarch64-3.6/source/py_gpio.o:(.bss+0x72c): first defined here
/usr/lib/gcc/aarch64-unknown-linux-gnu/10.1.0/../../../../aarch64-unknown-linux-gnu/bin/ld: b uild/temp.linux-aarch64-3.6/source/constants.o:(.bss+0x0): multiple definition of `high'; build/t emp.linux-aarch64-3.6/source/py_gpio.o:(.bss+0x190): first defined here
/usr/lib/gcc/aarch64-unknown-linux-gnu/10.1.0/../../../../aarch64-unknown-linux-gnu/bin/ld: b uild/temp.linux-aarch64-3.6/source/constants.o:(.bss+0x8): multiple definition of `low'; build/te mp.linux-aarch64-3.6/source/py_gpio.o:(.bss+0x198): first defined here
/usr/lib/gcc/aarch64-unknown-linux-gnu/10.1.0/../../../../aarch64-unknown-linux-gnu/bin/ld: b uild/temp.linux-aarch64-3.6/source/constants.o:(.bss+0x10): multiple definition of `input'; build /temp.linux-aarch64-3.6/source/py_gpio.o:(.bss+0x1a0): first defined here
/usr/lib/gcc/aarch64-unknown-linux-gnu/10.1.0/../../../../aarch64-unknown-linux-gnu/bin/ld: b uild/temp.linux-aarch64-3.6/source/constants.o:(.bss+0x18): multiple definition of `output'; buil d/temp.linux-aarch64-3.6/source/py_gpio.o:(.bss+0x1a8): first defined here
/usr/lib/gcc/aarch64-unknown-linux-gnu/10.1.0/../../../../aarch64-unknown-linux-gnu/bin/ld: b uild/temp.linux-aarch64-3.6/source/constants.o:(.bss+0x20): multiple definition of `pwm'; build/t emp.linux-aarch64-3.6/source/py_gpio.o:(.bss+0x1b0): first defined here
/usr/lib/gcc/aarch64-unknown-linux-gnu/10.1.0/../../../../aarch64-unknown-linux-gnu/bin/ld: b uild/temp.linux-aarch64-3.6/source/constants.o:(.bss+0x28): multiple definition of `serial'; buil d/temp.linux-aarch64-3.6/source/py_gpio.o:(.bss+0x1b8): first defined here
/usr/lib/gcc/aarch64-unknown-linux-gnu/10.1.0/../../../../aarch64-unknown-linux-gnu/bin/ld: b uild/temp.linux-aarch64-3.6/source/constants.o:(.bss+0x30): multiple definition of `i2c'; build/t emp.linux-aarch64-3.6/source/py_gpio.o:(.bss+0x1c0): first defined here
/usr/lib/gcc/aarch64-unknown-linux-gnu/10.1.0/../../../../aarch64-unknown-linux-gnu/bin/ld: b uild/temp.linux-aarch64-3.6/source/constants.o:(.bss+0x38): multiple definition of `spi'; build/t emp.linux-aarch64-3.6/source/py_gpio.o:(.bss+0x1c8): first defined here
/usr/lib/gcc/aarch64-unknown-linux-gnu/10.1.0/../../../../aarch64-unknown-linux-gnu/bin/ld: b uild/temp.linux-aarch64-3.6/source/constants.o:(.bss+0x40): multiple definition of `unknown'; bui ld/temp.linux-aarch64-3.6/source/py_gpio.o:(.bss+0x1d0): first defined here
/usr/lib/gcc/aarch64-unknown-linux-gnu/10.1.0/../../../../aarch64-unknown-linux-gnu/bin/ld: b uild/temp.linux-aarch64-3.6/source/constants.o:(.bss+0x48): multiple definition of `board'; build /temp.linux-aarch64-3.6/source/py_gpio.o:(.bss+0x1d8): first defined here
/usr/lib/gcc/aarch64-unknown-linux-gnu/10.1.0/../../../../aarch64-unknown-linux-gnu/bin/ld: b uild/temp.linux-aarch64-3.6/source/constants.o:(.bss+0x50): multiple definition of `bcm'; build/t emp.linux-aarch64-3.6/source/py_gpio.o:(.bss+0x1e0): first defined here
/usr/lib/gcc/aarch64-unknown-linux-gnu/10.1.0/../../../../aarch64-unknown-linux-gnu/bin/ld: b uild/temp.linux-aarch64-3.6/source/constants.o:(.bss+0x58): multiple definition of `pud_off'; bui ld/temp.linux-aarch64-3.6/source/py_gpio.o:(.bss+0x1e8): first defined here
/usr/lib/gcc/aarch64-unknown-linux-gnu/10.1.0/../../../../aarch64-unknown-linux-gnu/bin/ld: b uild/temp.linux-aarch64-3.6/source/constants.o:(.bss+0x60): multiple definition of `pud_up'; buil d/temp.linux-aarch64-3.6/source/py_gpio.o:(.bss+0x1f0): first defined here
/usr/lib/gcc/aarch64-unknown-linux-gnu/10.1.0/../../../../aarch64-unknown-linux-gnu/bin/ld: b uild/temp.linux-aarch64-3.6/source/constants.o:(.bss+0x68): multiple definition of `pud_down'; bu ild/temp.linux-aarch64-3.6/source/py_gpio.o:(.bss+0x1f8): first defined here
/usr/lib/gcc/aarch64-unknown-linux-gnu/10.1.0/../../../../aarch64-unknown-linux-gnu/bin/ld: b uild/temp.linux-aarch64-3.6/source/constants.o:(.bss+0x70): multiple definition of `rising_edge'; build/temp.linux-aarch64-3.6/source/py_gpio.o:(.bss+0x200): first defined here
/usr/lib/gcc/aarch64-unknown-linux-gnu/10.1.0/../../../../aarch64-unknown-linux-gnu/bin/ld: b uild/temp.linux-aarch64-3.6/source/constants.o:(.bss+0x78): multiple definition of `falling_edge' ; build/temp.linux-aarch64-3.6/source/py_gpio.o:(.bss+0x208): first defined here
/usr/lib/gcc/aarch64-unknown-linux-gnu/10.1.0/../../../../aarch64-unknown-linux-gnu/bin/ld: b uild/temp.linux-aarch64-3.6/source/constants.o:(.bss+0x80): multiple definition of `both_edge'; b uild/temp.linux-aarch64-3.6/source/py_gpio.o:(.bss+0x210): first defined here
/usr/lib/gcc/aarch64-unknown-linux-gnu/10.1.0/../../../../aarch64-unknown-linux-gnu/bin/ld: b uild/temp.linux-aarch64-3.6/source/constants.o:(.bss+0x88): multiple definition of `gpio_mode'; b uild/temp.linux-aarch64-3.6/source/py_gpio.o:(.bss+0x218): first defined here
/usr/lib/gcc/aarch64-unknown-linux-gnu/10.1.0/../../../../aarch64-unknown-linux-gnu/bin/ld: b uild/temp.linux-aarch64-3.6/source/constants.o:(.rodata+0x0): multiple definition of `pin_to_gpio _rev1'; build/temp.linux-aarch64-3.6/source/py_gpio.o:(.rodata+0x30): first defined here
/usr/lib/gcc/aarch64-unknown-linux-gnu/10.1.0/../../../../aarch64-unknown-linux-gnu/bin/ld: b uild/temp.linux-aarch64-3.6/source/constants.o:(.rodata+0xa8): multiple definition of `pin_to_gpi o_rev2'; build/temp.linux-aarch64-3.6/source/py_gpio.o:(.rodata+0xd8): first defined here
/usr/lib/gcc/aarch64-unknown-linux-gnu/10.1.0/../../../../aarch64-unknown-linux-gnu/bin/ld: b uild/temp.linux-aarch64-3.6/source/constants.o:(.rodata+0x150): multiple definition of `pin_to_gp io_rev3'; build/temp.linux-aarch64-3.6/source/py_gpio.o:(.rodata+0x180): first defined here
/usr/lib/gcc/aarch64-unknown-linux-gnu/10.1.0/../../../../aarch64-unknown-linux-gnu/bin/ld: b uild/temp.linux-aarch64-3.6/source/constants.o:(.bss+0x90): multiple definition of `pin_to_gpio'; build/temp.linux-aarch64-3.6/source/py_gpio.o:(.bss+0x220): first defined here
/usr/lib/gcc/aarch64-unknown-linux-gnu/10.1.0/../../../../aarch64-unknown-linux-gnu/bin/ld: b uild/temp.linux-aarch64-3.6/source/constants.o:(.bss+0x98): multiple definition of `gpio_directio n'; build/temp.linux-aarch64-3.6/source/py_gpio.o:(.bss+0x228): first defined here
/usr/lib/gcc/aarch64-unknown-linux-gnu/10.1.0/../../../../aarch64-unknown-linux-gnu/bin/ld: b uild/temp.linux-aarch64-3.6/source/constants.o:(.bss+0x170): multiple definition of `rpiinfo'; bu ild/temp.linux-aarch64-3.6/source/py_gpio.o:(.bss+0x300): first defined here
/usr/lib/gcc/aarch64-unknown-linux-gnu/10.1.0/../../../../aarch64-unknown-linux-gnu/bin/ld: b uild/temp.linux-aarch64-3.6/source/constants.o:(.bss+0x598): multiple definition of `setup_error' ; build/temp.linux-aarch64-3.6/source/py_gpio.o:(.bss+0x728): first defined here
/usr/lib/gcc/aarch64-unknown-linux-gnu/10.1.0/../../../../aarch64-unknown-linux-gnu/bin/ld: b uild/temp.linux-aarch64-3.6/source/constants.o:(.bss+0x59c): multiple definition of `module_setup '; build/temp.linux-aarch64-3.6/source/py_gpio.o:(.bss+0x72c): first defined here
collect2: error: ld returned 1 exit status
error: command 'aarch64-unknown-linux-gnu-gcc' failed with exit status 1
ERROR: Command errored out with exit status 1: /usr/bin/python3.6 -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-8a6ado6k/RPi.GPIO/setup.py'"'"'; __file__='"'"'/tmp /pip-install-8a6ado6k/RPi.GPIO/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__); code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'e xec'"'"'))' install --record /tmp/pip-record-0fg28_61/install-record.txt --single-version-externa lly-managed --user --prefix= --compile --install-headers /home/pi/.local/include/python3.6m/RPi.G PIO Check the logs for full command output.
gordon77
Fri May 22, 2020 6:29 pm
What are you trying to install it in, raspbian ?
Buster should come with it.
sakaki
Fri May 22, 2020 10:01 pm
dony71 wrote:
Fri May 22, 2020 6:48 pm
gentoo
https://github.com/sakaki-/gentoo-on-rpi-64bit
Gentoo now uses gcc v10 unless masked, and this has -fno-common turned on by default (upstream). The old default was -fcommon.
This change causes extern omissions in some (usually legacy) code to throw 'multiple definition' errors (like the ones you report) at link time. More details:
https://gcc.gnu.org/gcc-10/porting_to.html#common
You can quickly check whether this is indeed the root issue here (as it may be something else entirely): just add -fcommon to your CFLAGS and see if the target package compiles OK.
If it does then, per the gcc docs, the issue ought really to be addressed in the upstream target package's source.
hth,
sakaki
dony71
Fri May 22, 2020 10:37 pm
Yeap ... it's compiled fine
Thank's Sakaki
croston
Tue Jun 02, 2020 9:03 pm
Thanks - I'll take a look at this. I've got to check RPi.GPIO behaves properly with the new foundation maintained arm64 distro anyway. I've a couple of compiler warnings with Python 3.9.0b1 to clear up too.
