pi-anazazi
Raspbian (latest) - tigerVNC not working?
Mon Jun 24, 2019 3:38 pm
Hi!
I started installing latest Raspbian (Buster with GUI) on a raspi 2. Removed the VNC coming with the image, rebooted and installed TigerVNC from the "install and remove software" tool in the GUI.
I can start the VNCserver:
vncserver -localhost no
Cleaning stale pidfile '/home/pi/.vnc/raspberrypi:1.pid'!
New 'raspberrypi:1 (pi)' desktop at :1 on machine raspberrypi
Starting applications specified in /home/pi/.vnc/xstartup
Log file is /home/pi/.vnc/raspberrypi:1.log
Use xtigervncviewer -SecurityTypes VncAuth,TLSVnc -passwd /home/pi/.vnc/passwd raspberrypi:1 to connect to the VNC server.
but when I do on client:
vncviewer -SecurityTypes VncAuth,TLSVnc -passwd /home/pi/.vnc/passwd IP_raspi:1
I get on the client "opening password file failed":
TigerVNC Viewer 64-bit v1.9.80
Copyright (C) 1999-2019 TigerVNC Team and many others (see README.rst)
See https://www.tigervnc.org for information on TigerVNC.
Mon Jun 24 17:33:47 2019
 DecodeManager: Detected 6 CPU core(s)
 DecodeManager: Creating 4 decoder thread(s)
 CConn:       Connected to host 10.0.0.5 port 5901
 CConnection: Server supports RFB protocol version 3.8
 CConnection: Using RFB protocol version 3.8
 CConnection: Choosing security type VeNCrypt(19)
 CVeNCrypt:   Choosing security type VncAuth (2)
[b] CConn:       Opening password file failed[/b]
The server says in the log:
 Connections: accepted: IP_client::36308
 SConnection: Client needs protocol version 3.8
 SConnection: Client requests security type VeNCrypt(19)
 SVeNCrypt:   Client requests security type VncAuth (2)
terminate called after throwing an instance of 'rdr::EndOfStream'
terminate called recursively
(EE)
(EE) Backtrace:
(EE)
(EE)
Fatal server error:
(EE) Caught signal 6 (Aborted). Server aborting
(EE)
syswrite() on closed filehandle WH at /usr/bin/vncserver line 912.
I only found this here:
https://github.com/TigerVNC/tigervnc/issues/800
...which gives me little hope.
Has anybody managed to get TigerVNC up and running on raspbian? :-)
Kind regards
anazazi
pi-anazazi
Re: Raspbian (latest) - tigerVNC not working?
Mon Jun 24, 2019 5:46 pm
PS: I tried the built-in tightVNC server, but that requires tightVNC viewer and is not compatible to tigerVNC I have installed on all my machines. :-(
So: Any way to get tigerVNC server to work on raspbian?
Kind regards
anazazi
pi-anazazi
Fri Jun 28, 2019 2:03 pm
Really? Nobody running TigerVNC?
Kind regards
anazazi
mattmiller
Fri Jun 28, 2019 2:26 pm
Nope -we all all use the standard RealVNC server that comes as standard
acavalin
Mon Aug 12, 2019 11:47 am
Hello I found that this is a problem related to libunwind8 and the function _Unwind_RaiseException that overrides the one supplied in libgcc_s.so.1.
See https://bugs.debian.org/cgi-bin/bugrepo ... =932499#47
It works if you run the server like this:
LD_PRELOAD=/lib/.../libgcc_s.so.1 Xtigervnc ...
but this is only a hack... the bug is fixed in tigervnc/1.9.0+dfsg-1 but in raspbian we only have tigervnc/1.9.0+dfsg-3.
Does someone knows how to tell the raspbian devs about this problem and bugfix?
Mon Aug 12, 2019 1:35 pm
The package is provided by Debian, you need to contact the package maintainers:
https://packages.debian.org/stable/source/tigervnc
raspphibian
Thu Dec 05, 2019 4:44 pm
I think the raspberry pi foundation makes deals with some non-free software vendors to include their software in the raspbian repo or NOOBS, and they get paid for including their limited trial versions. RealVNC is one of these. It is non-free software which doesn't allow you to use it commercially or with more than 5 computers or something. There might be some more restrictions on it, I didn't fully read their license. The point it is that it's not free and so it is better to learn the free and open source TigerVNC, which seems to be the best FOSS VNC software right now.
Here are my notes on how to set it up. This works fine for me on my LAN.
debian:
sudo apt install tigervnc-scraping-server tigervnc-common
for config:
tigervncpasswd
run local display mirror vnc server:
x0vncserver -rfbauth ~/.vnc/passwd
arch:
sudo pacman -S tigervnc
for initial config config:
$ vncserver
If at any stage one needs to change the previously defined password, the vncpasswd tool can be called:
$ vncpasswd
$ x0vncserver -rfbauth ~/.vnc/passwd
Running vncserver for virtual (headless) sessions:
https://wiki.archlinux.org/index.php/Ti ... )_sessions
connect with
$ vncviewer <ip address>
wildfire
Thu Dec 05, 2019 5:40 pm
Really, where did you get those thoughts from?
I have some thoughts of my own about your post, unfortunately I'm certain if I post them I'd be in trouble with the mods.
E8 85 A2 40 C9 40 81 94 40 81 95 40 89 84 89 96 A3
Still NF Shirls
mattmiller
Thu Dec 05, 2019 9:58 pm
I'd be much more inclined to believe that RealVNC supply RPi with their "limited" (doesn't affect me at all controlling 10 Pi over my LAN) product as bit of free product placement advertising.
It works really well OOB
It doesn't bother me at all if its not "free" software as there are plenty of "free" alternatives is they ever decided to pull it from Pi
Until that day (ever) comes - I'll just continue to enjoy their largess :)
intgir
Mon Jan 27, 2020 6:14 am
I prefer to use free, open source software like the one OP mentions because it is more secure. Where can I review the source code for RealVNC? How do I know that it isn't compromising my system?
Mon Jan 27, 2020 12:05 pm
https://www.realvnc.com/en/legal/#tandc
pi-anazazi
Mon Jan 27, 2020 1:30 pm
I simply use now headless buster, only access via ssh.
I still miss tigerVNC though...
Kind regards
anazazi
FTrevorGowen
Mon Jan 27, 2020 1:38 pm
with X-forwarding enabled maybe? That's the "simplest" approach Pi (or other box with X-win support) to Pi.
Trev.
Still running Raspbian Jessie or Stretch on some older Pi's (an A, B1, 2xB2, B+, P2B, 3xP0, P0W, 2xP3A+, P3B+, P3B, B+, and a A+) but Buster on the P4B's & P400. See: https://www.cpmspectrepi.uk/raspberry_pi/raspiidx.htm
pi-anazazi
Mon Jan 27, 2020 2:20 pm
headless as in "buster light", i.e. without any GUI installed at all... ;-)
Kind regards
anazazi
tmbdev
Mon May 04, 2020 5:17 am
You need to set both a regular and a view-only password for TigerVNC to work on Raspbian. Yes, that's a bug, but it's fortunately not a big problem once you know about it.
(The reason many people want to run TigerVNC is that RealVNC doesn't play particularly nicely with non-RealVNC clients, like those that are standard on Ubuntu. Also, ssh tunnels are often preferable to RealVNC's protocols.)
bls
Contact: Twitter
Mon May 04, 2020 1:56 pm
Agree most people here use RealVNC, but TigerVNC and TightVNC are viable options.
If you'd prefer to use one of those two VNC servers with virtual displays (rather than controlling the RPi console), have a look at https://github.com/gitbls/RPiVNCHowTo. It shows you how to set up those two VNC servers as being systemd-started on demand without using vncserver at all. It does require a display manager, such as lightdm or xdm, but most systems with X have one of them installed.
Pi tools:
Quickly and easily build customized-just-for-you SD Cards: https://github.com/gitbls/sdm
Easily run your network's DHCP/DNS on a Pi: https://github.com/gitbls/ndm
Easy strongSwan VPN installer/manager: https://github.com/gitbls/pistrong
Lightweight Virtual VNC Config: https://github.com/gitbls/RPiVNCHowTo
strongcoffee
Wed Jul 15, 2020 12:47 pm
by tmbdev » Mon May 04, 2020 5:17 am
Thanks for that tip, I finally got it to work.
I use TigerVNC Viewer 1.10.1 on my Mac to connect to TigerVNCserver running on my raspberry pi 4. I create an ssh tunnel first; replace 192.168.x.x with the IP address of your raspberry pi.
ssh -NTf -L 5901:localhost:5901 192.168.x.x
In the client I specify localhost::5901 and after providing the password a connection is established. Without the ssh tunnel (i.e. connecting directly to rpiIPaddress::5901) does not work for me, but connecting over ssh is more secure so preferable.
wsanders
Wed Jul 15, 2020 7:53 pm
Running Buster (yes it's old.)
TigerVNC doesn't work out of the box because it only opens a socket on localhost.
netstat -nta
Active Internet connections (servers and established)
Proto Recv-Q Send-Q Local Address           Foreign Address         State
tcp        0      0 127.0.0.1:5901          0.0.0.0:*               LISTEN
The aforementioned ssh tunnel technique should work, but the tunnel it creates is on localhost as well:
$ netstat -nta | grep 590
tcp        0      0 127.0.0.1:5902          0.0.0.0:*               LISTEN
tcp6       0      0 ::1:5901                :::*                    LISTEN
tcp6       0      0 ::1:5902                :::*                    LISTEN
I haven't yet figured out how to fix this. (Gpsd behaves the same way, with the -G flag, which is supposed to create a listening socket, but the socket created is on localhost only.) I don't have a firewall running on the host. "Ssh -Y" works though.
The RealVNC that ships is incompatible with TigerVNC, which is the default VNC server present in Fedora.
ilg
Sat Aug 08, 2020 3:57 pm
That's correct, but you can start it with lots of options, including:
