tgwena
Buster won't boot headless with the Sense Hat attached
Fri Jun 28, 2019 12:49 pm
Hello all,
I have a raspberry Pi 3B+ with a sense hat attached. I installed buster on a new card (enabled ssh) and it boots up with no problems if it is attached to a display. When I try to boot headlessly the Hat just lights up the rainbow and stays that way. The Pi does not seem to boot up. With the Hat off it boots headlessly and is accessible via ssh.
I have repeated this with a second sd card and on the Pi 3B+ and 2B. I have tried disabling the splash screen and graphical boot to no avail.
How can I fix this? Thanks.
pista24
Re: Buster won't boot headless with the Sense Hat attached
Sat Jun 29, 2019 10:31 am
I have RPI 4 and have the same problem with Sense Hat. I spent hours on it.
Why there is no testing before launch?
TaseG
Mon Jul 01, 2019 7:57 pm
Same thing here - I'm using a RPi 3B+ with a SenseHat attached. It won't boot Buster in headless mode, it'll only boot with a display connected. Also tried disabling splash screen and using the legacy OpenGL driver, to no avail - the Sense LED Matrix stays lit up, just like it would if I would not have any SD card inserted.
This is really annoying, I'm hoping a future packaging of Buster will fix this.
Josema
Mon Jul 01, 2019 10:40 pm
Same thing here with Sense Hat + RPi 3B+ :(
PawelJalocha
Sun Jul 14, 2019 4:11 pm
Exactly same issue with the first (single-core) Raspberry PI, flashed SD card with Buster Lite, created ssh in boot and not able to login with ssh: connection refused.
Sun Jul 14, 2019 5:05 pm
Which sounds like a completely different issue. If the Pi hadn't booted you would get "No route to host", not "Connection refused". That sounds more like the Pi has booted and got stuck - or ssh isn't enabled for some reason.
Do you have a Sense HAT attached to the Pi?
Heimetli
Wed Jul 17, 2019 7:27 pm
Same problem here: buster does not start with sensehat and no hdmi monitor.
The sensehat shows the colored startup image forever and I can't connect with ssh.
Setup: Raspberry 3 and a recent sensehat
A previous version of Raspbian starts without a hitch.
pbp
Wed Jul 24, 2019 10:15 am
I had the same problem with buster RPi 4B. Doing:
$raspi-config
7 Advanced Options
A5 Resolution
DMT Mode 4 640x480 60Hz 4:3
solves the problem. Tested with:
- RPi4B
- 2019-07-10-raspbian-buster
- 2019-07-10-raspbian-buster-lite
Source: https://github.com/RPi-Distro/python-se ... /issues/96
FL00DY
Sun Jul 28, 2019 7:30 pm
I just updated to Buster with the SenseHat. Tried this resolution fix, still not display. Is there any other fix out there?
ByteYourLife
Sat Aug 31, 2019 7:00 am
Hi all,
same problem here with a Raspberry Pi 4 and a Sense HAT. I am using the latest buster image "2019-07-10-raspbian-buster-full.img".
My solution was to edit the /boot/config.txt.
I removed the "#" in front of the line "hdmi_force_hotplug=1" and now the Raspberry Pi is booting attached with the SenseHAT.
Best,
ByteYourLife
My project I am working on: An autonomous driving car with the Raspberry Pi and a lot of sensors.
ppl4world
Thu Sep 05, 2019 9:01 am
Hi, I tried all posted remedies (setting screen size in raspi-config and changing changing config.txt) yet to no avail (tried all the usual checks like I2C turned on etc)
Using RPi3 B+ and Sense Hat.
The boot process gets stuck with the rainbow color pattern on the Sense Hat.
I tried two different Pi's and two different Sense Hats.
Same problem.
Any further ideas?
ppl4world
Fri Sep 06, 2019 11:58 pm
[SOLVED for me]
I had set-up the Pi with a WaveShare TFT display. I started from a fresh build without installing the touch screen drivers or setting the screen display ratio.
When using the previous Raspbian version it works now. Will try with Buster maybe later and see if that works also.
TaseG
Sun Sep 08, 2019 9:48 pm
This seems to be working with the July 2019 version of Buster (SHA-256:9e5cf24ce483bb96e7736ea75ca422e3560e7b455eee63dd28f66fa1825db70e)
