DarkElvenAngel
Running Buildroot on a pi 3B+ [Solved]
Thu Jun 27, 2019 7:07 pm
I'm trying out Buildroot for the first time and I am trying to do this on a RPI 3B+ to build for a RPI 0W.
I'm getting an error that says:
mp-divrem_1.s:158: Error: selected processor does not support `mls r1,r4,r8,r11' in ARM mode
I've googled around and seems like the gcc installed is the issue.
Is there an easy way to install a prebuilt gcc that will work or do I really need to muck about in my apt settings to pull packages from Debian repositories?
I was wondering can't I just downloaded the packages from Debian and install them manually and not mess with the apt.source?If so what package(s) do I need?
Thanks,
Oh I'm running the latest raspbian Buster all upto date.
Last edited by DarkElvenAngel on Tue Jul 02, 2019 3:50 am, edited 1 time in total.
Re: Running Buildroot on a pi 3B+
Thu Jun 27, 2019 8:23 pm
Most Debian packages will not run on a Pi Zero. They do not support the ARMv6 CPU that it has. That's why we have Raspbian.
Unreadable squiggle
DarkElvenAngel
Thu Jun 27, 2019 9:56 pm
I'm running a Pi 3 B+ though my understanding is that the compiler on that system isn't able to compile due to it missing build options( to keep it compatible with earlier Pi's.) I don't know for sure it would install the host version on the target.
procount
Thu Jun 27, 2019 10:35 pm
As this is your first time with buildroot, why not start building something that already exists and is known to work.
One example is noobs. https;//github.com/raspberry pi/noobs..
The initial build will take several hours as it builds all tools and libs, but thereafter it will be much quicker. You will need 6-8GB of free disk space.
Once you get that built and you understand it, you can start using buildroot for other projects.
DarkElvenAngel
Thu Jun 27, 2019 11:07 pm
Could you please explain how that would be different?
All I have done are two actually build commands
make raspberrypi0w_defconfig
make all
That's as far as it goes before erroring out
procount
Fri Jun 28, 2019 12:50 am
Have a look at the noobs readme concerning the pre-requisites you must install first. Like build-essential, etc.
mich181189
Fri Jun 28, 2019 2:35 pm
If you’re using buildroot to produce a root filesystem, Debian packages don’t really come into it. By default, it builds its own toolchain - this should be compatible as long as you make sure you tell it you’re using a Zero (start with the correct defconfig or configure it equivalently)
DarkElvenAngel
Sat Jun 29, 2019 5:19 pm
The problem is the compiler from what I've read you need one that's built for the pi 3 and the Raspbian stock is for pi 1 for maximum compatibility. I've got gcc 9 freshly compiled I'm going to give it shot when I home.
DarkElvenAngel
Mon Jul 01, 2019 8:01 pm
Reporting in I've been a little busy and my pi has been working hard compiling successfully Buildroot.
I tried it out and the base install (without setting anything up) works like I expected. Now I'm rebuilding with wireless network tools and more customization to my build.
I had one issue with my keyboard not being recognized and having to use a different one.
The compile is still going on I keep having small issues with the compile missing something and having to restart it after sorting it out however...
The bottom line is yes you can compile Buildroot on a RPI but it will take days! Just getting menuconfigs to build took 45-60 minutes for busybox and I went to bed waiting for the kernel one so 3 hours plus for that one. Buildroot's menuconfig is not such a wait.
My RPI 3B+ has gcc 9 installed and a 1 GB swap file otherwise nothing really special beyond that.
I'll report back again after my customized version is built.
edit
My last build has finished successfully. I had two problems with it one was running out of space on my drive easy to solve. The other was a missing build library libstdc++6 this was installed didn't have support for LIBCXX_3.4.26 I had to install the package libstdc++6_9.1.0-5_armhf.deb from the Debian Experimental branch. I just used the following command to install and it worked.
sudo dpkg --ignore-depends=gcc-9-base -i libstdc++6_9.1.0-5_armhf.deb
I really want to try this on a PI 4B with 4Gb of ram, swapping is killing the performance.
Return to “Advanced users”
