dancytron
Has anyone tested how the Raspi 4 does with Netflix?
Mon Jun 24, 2019 8:08 pm
I am thinking I could set it up for my 80+ year old mother to substitute for the kind of crappy first gen Roku dongle she is using now. She has trouble using it, but with a Raspberry I could control the interface and make it easy and also set it up so I could login with rdesktop or vlc to do stuff for her remotely. Also, it would work with her tablet, which the Roku kind of, but not really, does.
But it has to work well with Netflix, since that is her main source of TV and she already can use it.
Re: Has anyone tested how the Raspi 4 does with Netflix?
Tue Jun 25, 2019 3:47 am
Netflix requires DRM and a Raspberry Pi is not classed as a Secure Platform.
There are work-arounds to install Widevine DRM in chromium-browser, but not "officially" supported.
RPi 4B 4GB (SSD Boot)..
dancytron
Tue Jun 25, 2019 3:55 am
Okay, thanks. I knew that it wouldn't run on rooted android devices, so I guess they put the Pi is in the same category.
I wonder how is the Raspberry Pi less secure than an x86 computer for DRM purposes, but Netflix is going to do what they are going to do.
Tue Jun 25, 2019 4:32 am
https://en.wikipedia.org/wiki/Widevine
Maybe try Vivaldi Browser:
https://help.vivaldi.com/article/raspberry-pi/
G160
Fri Jul 05, 2019 12:24 pm
If u use LibreELEC , or any other Kodi then Netflix works however due to widevine and the fact that it has to decode through software, the max resolution is 720p unfortunately.
ventz
Mon Jul 22, 2019 7:43 am
Here is a 3 step process that should take you less than a few minutes:
https://blog.vpetkov.net/2019/07/12/net ... -chromium/
oss001
Sat Jul 27, 2019 4:10 am
I am curious out this too. You can get Netflix and Amazon Prime streaming in Kodi by using this guide.
https://makingstuffwork.net/technology/ ... rime-kodi/
The 720p max was because the 3B+ didn't have the power to stream/decode/play any higher but the 4 should be a big improvement. If anyone has a model 4 and would like to try I would be interested in the results...
Beckyilkerson
Thu Jun 18, 2020 3:34 am
I don't think I will try it yet with netflix because I think it will not work. Has anyone done that.
BeauSlim
Thu Jun 18, 2020 6:35 pm
Netflix works fine on Pi4 and LibreELEC. I use the addon from https://github.com/CastagnaIT
I *think* it gets you 1080p, but I just reformatted that SD card to play with the new Raspberry Pi OS, so I can't verify.
dorian-ny
Fri Jun 19, 2020 6:08 am
Kodi on rasberry OS works fine with Neflix 1080p. You just have to install the "inputstream.adaptive" add-on. Go to the plugin configuration and it will install wivedevine for you.
Netflix for Kodi is not a sanction plugin and it is nowhere near as polished as Netflix on Roku. Might want to install Kodi with Netflix on your PC (it runs on windows just fine) to test it out and see if it is something your Grandma can get used to.
Fri Jun 19, 2020 6:11 am
Return to “Media centres”
