What's with all the shouting?
Nothing missing there that most of us need.
Can't wait to get my hands on a few with all that 64 bit 4GB lovelyness.
Re: Raspberry Pi 4 Thread - general discussion
I'm woundering if this opens up to getting more programs something like Blender 3d software, VirtualBox, newer browsers to use and more.
VirtualBox and Blender3D require x86 CPU Architecture.
Web browsers, what is wrong with chromium-browser version 74 in Raspbian Buster ?
My other Linux machines are a ChromeBox & Intel CoreDuo Desktop
Well done -- I am impressed.
Is there a commandline player in the works? I prefer ssh and omxplayer ATM over Kodi, as it's a lot quicker...
Stunningly good news about the extra UART and I2C macroblocks you've got multiplexed on the GPIO pins. Really looking forward to using those for work projects.
As it is apparently board policy to disallow any criticism of anything, as it appears to criticise something is to criticise all the users of that something, I will no longer be commenting in threads which are not directly relevant to my uses of the Pi.
Yeah, that would be nice. With the old Raspberrys, maximum useable number of Atheros 9271 wifi sticks is three and in general usb was subject to timing issues.
It's odd that they are telling people to use NOOBS to do the system install. I would that anyone who doesn't just directly flash an OS to their card wouldn't even be looking at overclocking.
It will in the near future. It's been mentioned a number of times in this thread that it will require a patch to the boot EEPROM, which can be done easily. As it is, the boards are available now instead of 9 months from now, so a little patience is a pretty small thing to ask.DarkPlatinum wrote: ↑Mon Jun 24, 2019 6:30 pmIs there a way to do USB boot at all? This might be a problem for me as I keep my OS storage on a 1TB HDD...
blender runs fine on a rasberry pi 3 with the opengl driver activated and it even is in the raspbian repository. (i just needed to change some settings regarding the opengl selection method in blender's preferences.)fruitoftheloom wrote: ↑Mon Jun 24, 2019 7:20 pm
on a raspberry pi 4 it should run even better with 4gb of ram and the other improvements.
edit: i am not sure about the upcoming blender 2.8 though since its opengl requirements are much higher.
- mikronauts
- Contact: Website
Great news indeed!
I ordered two boards - a 1GB, and a 2GB board, however I cannot find a 4GB board in stock in Canada, US, or UK.
Please post here if you know any place eith 4GB in stock.
Btw the additional i2c and uarts are great for my purposes.
http://Mikronauts.com - home of EZasPi, RoboPi, Pi Rtc Dio and Pi Jumper @Mikronauts on Twitter
Advanced Robotics, I/O expansion and prototyping boards for the Raspberry Pi
Last I check, the 4GB models won't be available till almost end of July. I ordered the 2GB but won't ship till July 5th.mikronauts wrote: ↑Mon Jun 24, 2019 7:52 pmGreat news indeed!
It's strange that they would have different memory size versions. They should have made different form factors instead, like the Pi Zero and A+.
It's an xHCI controller - number of endpoints is no longer the limit, number of device slots is.
HCSPARAMS1 = 0x05000420 -> 0x20 for number of slot IDs -> 32 simultaneous devices (with an arbitrary number of endpoints within those devices).
Rockets are loud.
https://astro-pi.org
Did anybody complain about the M2.5 mounting holes (same as on previous models) yet? I can do that if you want
M2.5 standoffs are horribly expensive compared to M3 or M2, what were you thinking??
(Ok, I spare you the huge font...)
Nah. I think Pi4 looks really promising. It impresses me like Pi 2 did in its day. And once again an elegantly designed case, too.
Well done, well done.
- mikronauts
- Contact: Website
In low quantities, yes.
Personally I ordered a few thousand nylon washers, nuts, screws and various height standoffs from a manufacturer for my boards. Price was ok. Shipping took a while.
epoch1970 wrote: ↑Mon Jun 24, 2019 8:02 pmDid anybody complain about the M2.5 mounting holes (same as on previous models) yet? I can do that if you want
- Contact: Website Facebook Twitter YouTube
Some DVB-T TV channels use MP2 (e.g. in Sweden) and this could mean that playback is worse on Pi 4 B than on Pi 3 B+. I have not bought a license key for MP2 so I'm not using the hardware decoder anyway. I use e.g. VLC to watch TV using TVHAT on Pi 3 B. Denmark, which is close to where I live, uses MP4 for DVB-T and that runs much smother in VLC.
https://www.raspberrypi.org/products/ra ... pi-tv-hat/
Have Pi0&1A&1B&1B+&2B&3B&4B w/ rasPiOS. Started w/ BASIC on ABC80&ZX81 then Forth, Z80… https://scratch.mit.edu/users/mobluse/ https://github.com/mobluse/ https://twitter.com/mobluse/ https://YouTube.com/MOBiL4u/
But 3mm drill bits are cheap, takes 2 minutes to drill the holes to M3
Awesome. Being able to run four or more Atheros sticks is a very big plus for my kind of application.
For the time being I've just reverted to having a boot partition on an SD card and root filesystem on my USB hard disk. I can live with that until the USB boot is ready to go.
PeterO
- HawaiianPi
Not sure where you are buying them from, but they cost no more for me. ¯\_(ツ)_/¯
Same price at local hardware stores. Same price from Amazon (USA).
- Raspberry Pi Engineer & Forum Moderator
- Location: ZZ9 Plural Z Alpha, aka just outside Cambridge.
The arm cores on the Pi2 were sufficient for sd mpeg2. The hw mpeg2 and vc1 codec licences were only a real requirement on the 0 and 1, or for HD (which is rare outside the USA).mob-i-l wrote: ↑Mon Jun 24, 2019 8:07 pmSome DVB-T TV channels use MP2 (e.g. in Sweden) and this could mean that playback is worse on Pi 4 B than on Pi 3 B+. I have not bought a license key for MP2 so I'm not using the hardware decoder anyway. I use e.g. VLC to watch TV using TVHAT on Pi 3 B. Denmark, which is close to where I live, uses MP4 for DVB-T and that runs much smother in VLC.
In the UK for free to air dvb-t and dvb-s, sd is all mpeg2, and HD is h264.
One of the things that's really annoying about all ARM single board computers is they cannot boot from USB without jumping through hoops. Would it ever be possible, with firmware update, to download an arm64 iso from X Linux distribution so you can install Linux the sane way? I miss having my encrypted root and home partitions. I miss having separate home partition period. I realize it can still be done, but it's currently a PITA.
I've tested raw BluRay MPEG-2 and VC1 with LibreELEC on Pi4 and both played fine with software decode.mob-i-l wrote: ↑Mon Jun 24, 2019 8:07 pmSome DVB-T TV channels use MP2 (e.g. in Sweden) and this could mean that playback is worse on Pi 4 B than on Pi 3 B+. I have not bought a license key for MP2 so I'm not using the hardware decoder anyway. I use e.g. VLC to watch TV using TVHAT on Pi 3 B. Denmark, which is close to where I live, uses MP4 for DVB-T and that runs much smother in VLC.
Broadcast TV tends to be a much lower bitrate so there shouldn't be a problem.
Another question for the Engineers: I just installed the latest version of Raspberry Pi Desktop ("buster"), and there is a new option in raspi-config for "Raspberry Pi 4 video output" which requires a Raspberry Pi 4. What is this for? (Is this for setting the screen resolutions?)
Thanks for the link, a good read. Seems a modest overclock can give noticeable results, just a question if the boost is worth the possible shorter life??? Mine will stay stock, for now.
When I googled all I got was RPi 3 over clock stories.
I wonder if the ram can be over clocked.
- HawaiianPi
gtechn wrote: ↑Mon Jun 24, 2019 9:03 pmAnother question for the Engineers: I just installed the latest version of Raspberry Pi Desktop ("buster"), and there is a new option in raspi-config for "Raspberry Pi 4 video output" which requires a Raspberry Pi 4. What is this for? (Is this for setting the screen resolutions?)
Pretty sure that has to do with video acceleration on the new Pi 4B, and likely other unique Pi4 features like 4K and dual HDMI.
https://www.raspberrypi.org/blog/raspberry-pi-4-on-sale-now-from-35/ wrote: One notable step forward is that for Raspberry Pi 4, we are retiring the legacy graphics driver stack used on previous models. Instead, we’re using the Mesa “V3D” driver developed by Eric Anholt at Broadcom over the last five years. This offers many benefits, including OpenGL-accelerated web browsing and desktop composition, and the ability to run 3D applications in a window under X. It also eliminates roughly half of the lines of closed-source code in the platform.
Just checked Pimoroni and they seem to be out of stock. But I did order a 4gig from Pimoroni this morning, so were available.nai1ed wrote: ↑Mon Jun 24, 2019 7:57 pmLast I check, the 4GB models won't be available till almost end of July. I ordered the 2GB but won't ship till July 5th.mikronauts wrote: ↑Mon Jun 24, 2019 7:52 pmGreat news indeed!
