Thanks in advance
How are you measuring wireless network speed?
sudo iwlist wlan0 scan | egrep "Cell|ESSID|Signal|Channel|Rates"
Hi neilgl,neilgl wrote: ↑Sun Jan 13, 2019 4:59 pmWhat happens if you log in to the router as admin and disable the wireless "Smart Connect" and the 2.4GHz, leaving only the 5GHz running?
And what do you get fromCode: Select all
Hi HawaiianPi,
sudo apt install speedtest-cli
speedtest-cli
~ $ speedtest-cli --share
Retrieving speedtest.net configuration...
Testing from Frontier Communications (...)...
Retrieving speedtest.net server list...
Selecting best server based on ping...
Hosted by Fibersphere Communications (Portland, OR) [14.45 km]: 21.199 ms
Testing download speed................................................................................
Download: 96.99 Mbit/s
Testing upload speed....................................................................................................
Upload: 86.63 Mbit/s
Share results: http://www.speedtest.net/result/7956354249.png
Excellent, thanks for the input, I'll give it a go.HawaiianPi wrote: ↑Mon Jan 14, 2019 3:08 pmInternet speed tests are a terrible way to judge network performance.
Thanks for the input bensimmo, much appreciated. I will find someone with an ac router and give it a try.
Just curious if you retested with speedtest-cli and what were your results?
Hi HawaiianPi,HawaiianPi wrote: ↑Wed Jan 16, 2019 1:50 amJust curious if you retested with speedtest-cli and what were your results?
Wiphy phy0
Band 2:
Capabilities: 0x1062
HT20/HT40
Static SM Power Save
RX HT20 SGI
RX HT40 SGI
No RX STBC
Max AMSDU length: 3839 bytes
DSSS/CCK HT40
Maximum RX AMPDU length 65535 bytes (exponent: 0x003)
Minimum RX AMPDU time spacing: 16 usec (0x07)
HT TX/RX MCS rate indexes supported: 0-7
VHT Capabilities (0x00001020):
Max MPDU length: 3895
Supported Channel Width: neither 160 nor 80+80
short GI (80 MHz)
SU Beamformee
VHT RX MCS set:
1 streams: MCS 0-9
2 streams: not supported
3 streams: not supported
4 streams: not supported
5 streams: not supported
6 streams: not supported
7 streams: not supported
8 streams: not supported
VHT RX highest supported: 0 Mbps
VHT TX MCS set:
1 streams: MCS 0-9
VHT TX highest supported: 0 Mbps
Bitrates (non-HT):
* 6.0 Mbps
* 9.0 Mbps
* 12.0 Mbps
* 18.0 Mbps
* 24.0 Mbps
* 36.0 Mbps
* 48.0 Mbps
* 54.0 Mbps
Frequencies:
* 5170 MHz [34] (disabled)
* 5180 MHz [36] (20.0 dBm)
* 5190 MHz [38] (disabled)
* 5200 MHz [40] (20.0 dBm)
* 5210 MHz [42] (disabled)
* 5220 MHz [44] (20.0 dBm)
* 5230 MHz [46] (disabled)
* 5240 MHz [48] (20.0 dBm)
* 5260 MHz [52] (20.0 dBm) (no IR, radar detection)
* 5280 MHz [56] (20.0 dBm) (no IR, radar detection)
* 5300 MHz [60] (20.0 dBm) (no IR, radar detection)
* 5320 MHz [64] (20.0 dBm) (no IR, radar detection)
* 5500 MHz [100] (20.0 dBm) (no IR, radar detection)
* 5520 MHz [104] (20.0 dBm) (no IR, radar detection)
* 5540 MHz [108] (20.0 dBm) (no IR, radar detection)
* 5560 MHz [112] (20.0 dBm) (no IR, radar detection)
* 5580 MHz [116] (20.0 dBm) (no IR, radar detection)
* 5600 MHz [120] (20.0 dBm) (no IR, radar detection)
* 5620 MHz [124] (20.0 dBm) (no IR, radar detection)
* 5640 MHz [128] (20.0 dBm) (no IR, radar detection)
* 5660 MHz [132] (20.0 dBm) (no IR, radar detection)
* 5680 MHz [136] (20.0 dBm) (no IR, radar detection)
* 5700 MHz [140] (20.0 dBm) (no IR, radar detection)
* 5720 MHz [144] (disabled)
* 5745 MHz [149] (disabled)
* 5765 MHz [153] (disabled)
* 5785 MHz [157] (disabled)
* 5805 MHz [161] (disabled)
* 5825 MHz [165] (disabled)
ADDR AID CHAN TXRATE RXRATE RSSI MINRSSI MAXRSSI IDLE TXSEQ RXSEQ CAPS ACAPS ERP STATE MAXRATE(DOT11) HTCAPS ASSOCTIME IEs MODE PSMODE RXNSS TXNSS
b8:27:eb:XX:XX:XX 1 100 433M 390M 54 51 56 15 0 65535 EP 0 b 0 AWQS 00:03:28 RSN WME IEEE80211_MODE_11AC_VHT80 0 1 1
I have no problem connecting my RPi3B+ to 5GHz AC only. As far as I remember AC mode always worked for me.
Wiphy phy0
max # scan SSIDs: 10
max scan IEs length: 2048 bytes
max # sched scan SSIDs: 16
max # match sets: 16
max # scan plans: 1
max scan plan interval: 508
max scan plan iterations: 0
Retry short limit: 7
Retry long limit: 4
Coverage class: 0 (up to 0m)
Device supports roaming.
Device supports T-DLS.
Supported Ciphers:
* WEP40 (00-0f-ac:1)
* WEP104 (00-0f-ac:5)
* TKIP (00-0f-ac:2)
* CCMP-128 (00-0f-ac:4)
* CMAC (00-0f-ac:6)
Available Antennas: TX 0 RX 0
Supported interface modes:
* IBSS
* managed
* AP
* P2P-client
* P2P-GO
* P2P-device
Band 1:
HT20/HT40
RX HT20 SGI
RX HT40 SGI
No RX STBC
DSSS/CCK HT40
Bitrates (non-HT):
* 1.0 Mbps
* 2.0 Mbps (short preamble supported)
* 5.5 Mbps (short preamble supported)
* 11.0 Mbps (short preamble supported)
* 6.0 Mbps
* 9.0 Mbps
* 12.0 Mbps
* 18.0 Mbps
* 24.0 Mbps
* 36.0 Mbps
* 48.0 Mbps
* 54.0 Mbps
Frequencies:
* 2412 MHz [1] (20.0 dBm)
* 2417 MHz [2] (20.0 dBm)
* 2422 MHz [3] (20.0 dBm)
* 2427 MHz [4] (20.0 dBm)
* 2432 MHz [5] (20.0 dBm)
* 2437 MHz [6] (20.0 dBm)
* 2442 MHz [7] (20.0 dBm)
* 2447 MHz [8] (20.0 dBm)
* 2452 MHz [9] (20.0 dBm)
* 2457 MHz [10] (20.0 dBm)
* 2462 MHz [11] (20.0 dBm)
* 2467 MHz [12] (20.0 dBm)
* 2472 MHz [13] (20.0 dBm)
* 2484 MHz [14] (disabled)
Band 2:
HT20/HT40
RX HT20 SGI
RX HT40 SGI
No RX STBC
DSSS/CCK HT40
short GI (80 MHz)
SU Beamformee
VHT RX MCS set:
1 streams: MCS 0-9
VHT TX MCS set:
1 streams: MCS 0-9
Bitrates (non-HT):
* 6.0 Mbps
* 9.0 Mbps
* 12.0 Mbps
* 18.0 Mbps
* 24.0 Mbps
* 36.0 Mbps
* 48.0 Mbps
* 54.0 Mbps
Frequencies:
Wiphy phy0
max # scan plans: 1
Retry long limit: 4
Supported Ciphers:
* TKIP (00-0f-ac:2)
* CMAC (00-0f-ac:6)
* IBSS
* managed
* AP
* P2P-client
* P2P-GO
* P2P-device
Band 1:
HT20/HT40
RX HT20 SGI
RX HT40 SGI
No RX STBC
DSSS/CCK HT40
Bitrates (non-HT):
* 1.0 Mbps
* 6.0 Mbps
* 9.0 Mbps
* 12.0 Mbps
* 18.0 Mbps
* 24.0 Mbps
* 36.0 Mbps
* 48.0 Mbps
* 54.0 Mbps
Frequencies:
Band 2:
HT20/HT40
RX HT20 SGI
RX HT40 SGI
No RX STBC
DSSS/CCK HT40
short GI (80 MHz)
SU Beamformee
VHT RX MCS set:
1 streams: MCS 0-9
VHT TX MCS set:
1 streams: MCS 0-9
Bitrates (non-HT):
* 6.0 Mbps
* 9.0 Mbps
* 12.0 Mbps
* 18.0 Mbps
* 24.0 Mbps
* 36.0 Mbps
* 48.0 Mbps
* 54.0 Mbps
Frequencies:
* 5600 MHz [120] (disabled)
* 5620 MHz [124] (disabled)
* 5640 MHz [128] (disabled)
* 5720 MHz [144] (20.0 dBm) (no IR, radar detection)
* 5745 MHz [149] (20.0 dBm)
* 5765 MHz [153] (20.0 dBm)
* 5785 MHz [157] (20.0 dBm)
* 5805 MHz [161] (20.0 dBm)
* 5825 MHz [165] (20.0 dBm)
