I've created a page in the wiki how to install and run the C64 emulator VICE on the RPi:
http://elinux.org/RPi_VICE_C64_Emulator
Tested in the VM, would be cool if someone with the real hardware could test it.
I was thinking about doing the same... Nice!carl_retrotext wrote:Hi,Thanks with you help, I have started to fit my Pi to a C64
How did you manage to get your joysticks working?carl_retrotext wrote:I have managed to get the joysticks working today too.
No, you can't use a serial to USB adapter. Carl used this one: http://www.vesalia.de/d_keyrah.htm But should be easy to patch VICE to use the GPIO pins, then you could solder just some wires to s subd connector.pe7er wrote:Is it possible to connect the old C64 joystick with an USB to Serial RS-232 DB9 Adapter like this?
deb http://ftp.uk.debian.org/debian/ wheezy main contrib
wget http://www.frank-buss.de/raspberrypi/vice_2.3.dfsg-4_armhf.deb
dpkg -i vice_2.3.dfsg-4_armhf.deb
wget http://www.zimmers.net/anonftp/pub/cbm/crossplatform/emulators/VICE/old/vice-1.5-roms.tar.gz
tar -xvzf vice-1.5-roms.tar.gz
cp -a vice-1.5-roms/data/* /usr/lib/vice/
