miky94
best compromise quality/size for time-lapse camera
Sun Jun 09, 2019 2:56 pm
I'm working on a onboard motorbike time-lapse camera for holidays, I'm using the picamera python module and I did a test looking for the best compromise quality/size.
excluding the unusable image with quality 1, I didn't find significant quality differences (not even by zooming) between quality 10 and quality 100 images, but a size difference of 1/8.
however it seems strange to me and I'm afraid of getting worse results under different conditions.
now I'm using Camera Module v1 (3€) and I'm wondering if is worth to buy the v2 (20€) to get better quality images, since I'll use 1920x1080 resolution for video conversion.
also is there a way to auto-improve the camera settings or is it already done automatically by the module?
quality 1
quality 10
quality 100
HermannSW
Re: best compromise quality/size for time-lapse camera
Sun Jun 09, 2019 8:29 pm
If you are only interested in 1920x1080 resolution, then v2 seems not to bring new value over v1 camera. Considering the reduced FoV of v2 over v1 maybe v2 is even worse than v1 (1920x1080 is 2MP, with v1 you get 2MP/5MP=40% of full view, with v2 you get only 25%):
https://picamera.readthedocs.io/en/rele ... 2/fov.html
⇨https://stamm-wilbrandt.de/en/Raspberry_camera.html
https://stamm-wilbrandt.de/github_repo_i420toh264
https://twitter.com/HermannSW
miky94
Sun Jun 09, 2019 10:18 pm
from what I read here https://www.raspberrypi.org/documentati ... re/camera/ the difference in resolution is greater than the difference in FoV, if I understood that means that at 1920x1080 v2 has better definition but worse FoV, right?
anyway seeing comparisons on the internet, in some v2 looks better in other v2 looks worse, so the difference is not so clear, surely not so clear to be worth that price difference.
regarding the quality parameter, I see no reason to use a value higher than 10, I can't figure out why the default is 85.
HermannSW
Mon Jun 10, 2019 6:58 am
I am sure there are scenes where 10 and 85 make a great difference, but if for your application there is none, go with 10.
From my main interests (global external shutter capturing and high framerate capturing), there are differences between v1 and v2 camera.
Only v1 camera has "global reset" feature, allowing to build your own external shutter and do global external shutter captures (without the nasty rolling shutter effect for fast moving objects). This is a 2MP multiple exposure capturing of an airgun pellet flying with 109m/s two times in same frame:
viewtopic.php?f=43&t=241418&p=1477441#p1477441
v2 camera allows for up to 1007fps framerate capturing (v1 can to up to 665fps ) with raspiraw (raspivid is limited to 200fps by GPU), this is 1007fps framerate animation playing at 1fps, of a mouse trap bar closing in 10ms:
In general you get double framerate for v2 over v1 when comparing same frame size:
viewtopic.php?f=43&t=212518&p=1310445#p1320034
While maximal framerate for v1/v2 cameras is 665fps/1007fps because of needed frame data transfer from image sensor to Pi after each frame capture, you can do much higher "exposures per second" capturings with global external shutter capturing. The frame shown above was taken with strobe pulses of 8.33µs length at 3kHz PWM frequency, so it is a 3000eps frame. I did take 12000eps frame as well in same posting referenced above, up to 100,000eps captures seem to be possible.
miky94
Mon Jun 10, 2019 7:19 am
Ok @HermannSW but I guess on a Pi Zero you can't get such high frame rate right? how do you capture at multiple exposure? that probably would improve the quality
I did the quality/size test only on that scene, I'll try on other scenes to see if it is worth using a higher quality
HermannSW
Mon Jun 10, 2019 7:29 am
I just mentioned global external shutter and high framerate capturing in previous posting as general v1/v2 comparison features, not specific to your application scenario.
If you look eg. into 640x64 tool you see that it captures with 665fps for Non-PiZero and 500fps for PiZero, so yes, a bit slower, but not that much:
https://github.com/Hermann-SW/raspiraw/ ... /640x64#L8
For your application raspiraw high framerate capturing is unlikely to help, since you can capture only 8s of video at 500fps on PiZero and then the needed /dev/shm ramdisk is full.
Please find the details here:
https://github.com/Hermann-SW/Raspberry ... al_shutter
Global external shutter capturing requires dark scene and very bright (5000lm) leds, so it will not help for your current application.
miky94
Wed Jun 19, 2019 10:49 pm
and how can I detect darkness using picamera to trigger a shutdown?
how do I read the image and see if most of pixels are beyond a threshold close to black?
HermannSW
Thu Jun 20, 2019 12:34 am
I don't use picamera, but you can use picamera Array API.
For black detection you may use PiYUVArray and only look at the Y component:
https://picamera.readthedocs.io/en/rele ... piyuvarray
Or use PiRGBArray:
https://picamera.readthedocs.io/en/rele ... pirgbarray
miky94
Thu Jun 20, 2019 1:18 am
I said picamera just because I'm using it for time lapse, is there another easier solution?
HermannSW
Thu Jun 20, 2019 5:13 pm
If you need more than 200fps, the solution has to be based on raspiraw because GPU limits to 200fps.
In this posting you can see how to intercept raspiraw's frame capturing and control servo for robot camera tilt calibration:
viewtopic.php?t=189661#p1231151
I converted the difficult to access raw10 Bayer data from 640x480 to a 320x240 greyscale image on the fly for further processing.
Otherwise you can get support of GPU by utilizing raspividyuv (that gives easy to access pixel color data, .h264 from raspivid is not helpful).
This is the line in raspividyuv callback where you can add your own code to detect darkness:
https://github.com/6by9/userland/blob/m ... YUV.c#L865
You can access the width×height 8bit/px chromatic Y plane of YUV only and do your black detection based on that.
viewtopic.php?f=43&t=241110&p=1479262#p1479262
miky94
Tue Jun 25, 2019 9:50 pm
I think that PiYUVArray could do the work, but I don't understand how to read the array and count the pixels beyond a threshold that I could consider "darkness"
HermannSW
Wed Jun 26, 2019 12:40 am
The example on picamera doc is wrong (misses 3rd argument ":1"), but it explains YUV:
https://picamera.readthedocs.io/en/late ... yuv-format
This code takes a frame and extracts the 2592*1944 bytes of Y plane (for v1 camera):
$ cat PYA.py
#!/usr/bin/env python
import picamera
import picamera.array
import numpy as np
from time import sleep
with picamera.PiCamera() as camera:
    with picamera.array.PiYUVArray(camera) as output:
        camera.resolution = (2592, 1944)
        camera.start_preview()
        sleep(2)
        camera.capture(output, 'yuv')
        print('Captured %dx%d image' % (
                output.array.shape[1], output.array.shape[0]))
        y_data = np.empty((1944, 2592), dtype=np.uint8)
        print('%d' % (y_data.size))
        y_data = output.array[:1944, :2592, :1]
        print((y_data.size))
This is generated output:
$ ./PYA.py
/usr/lib/python2.7/dist-packages/picamera/encoders.py:544: PiCameraResolutionRounded: frame size rounded up from 2592x1944 to 2592x1952
  width, height, fwidth, fheight)))
Captured 2592x1944 image
5038848
5038848
Per the doc y_data contains 1 byte of luminance for each pixel, from left to right per row, from top row to bottom row. Just check if each value is less than eg. 20 to consider it as dark.
miky94
Wed Jun 26, 2019 6:39 am
I don't understand in your code how do you loop each pixel and which is the luminance byte, so its value would be between 0-255 right?
HermannSW
Wed Jun 26, 2019 8:01 am
I had to learn myself, and my concerns on picamera have been confirmed.
This is the diff to iterate (and only count for now) the pixels of the frame:
[email protected]:~ $ diff PYA.py.old PYA.py
20a21,27
>         c=0
>         for y in y_data:
>             for x in y_data[y]:
>                 c+=1
>         print(c)
But the runtime is soooo bad (on Pi3A+):
$ time ./PYA.py
5038848
5038848
5038848
real	1m5.213s
user	0m42.283s
sys	0m20.117s
I did caterpillar robot camera tilt calibration code in C/C++ and the performance was orders of magnitude better. You can look in my code how I determined the black bar on front of robot with grey2b+w conversion first and then checking for all 0s:
https://www.raspberrypi.org/forums/view ... 1#p1231151
P.S:
I would do
raspividyuv -md 2 -w 2592 -h 1944 -t 0 -o - | ./yourCcode
and in yourCcode.c I would read input in chunks of 2592*1952*3/2=7589376 bytes (rows have to be a multiple of 16, columns a multiple of 32). And only use the first 2592*1944 bytes of the chunks for the Y plane:
https://www.raspberrypi.org/forums/view ... 2#p1479262
unsigned char p;
for(p=buffer+2592*1944-1; (p>=buffer) && (*p<20); --p) {}
p==(buffer-1) if and only if image is "dark".
miky94
Wed Jun 26, 2019 8:22 am
Thank you, I guess in my use case I could use a 400x300 image to elaborate 120.000 pixels instead of 5M decreasing in theory the runtime from 65s to 1.5s, also other improvements can be done, I have to test a bit.
so my question is:
	for y in y_data:
		for x in y_data[y]:
			#how to detect darkness here?
HermannSW
Wed Jun 26, 2019 10:01 am
numpy arrays are weird, I had to use flatten to get a 1-dimensional array of 400*300=120000 bytes:
$ cat PYA.py
import picamera
import numpy as np
        camera.resolution = (400, 300)
        sleep(2)
        y_data = np.empty((300, 400), dtype=np.uint8)
        y_data = output.array[:300, :400, :1].flatten()
        dark = True
        for i in y_data:
            if y_data[i] > 20:
                dark = False
        print(dark)
I did close window shutter completely to get dark reported, without dark was false:
$ time ./PYA.py
/usr/lib/python2.7/dist-packages/picamera/encoders.py:544: PiCameraResolutionRounded: frame size rounded up from 400x300 to 416x304
Captured 400x300 image
120000
False
real	0m4.846s
user	0m2.049s
sys	0m0.080s
$ time ./PYA.py
120000
True
real	0m4.800s
user	0m1.999s
sys	0m0.070s
Time is not that bad anymore with 400×300.
miky94
Wed Jun 26, 2019 11:19 am
ok thank you, so y_data values are between 0 and 255?
HermannSW
Wed Jun 26, 2019 11:32 am
Yes, 0..255 range. From picamera doc on yuv you can see each pixel taking a byte in Y-plane:
miky94
Sat Jun 29, 2019 1:40 am
I get an error the second time I run camera.capture(output,'yuv')
from time import time
from picamera import PiCamera
from picamera.array import PiYUVArray
import numpy
camera=PiCamera()
output=PiYUVArray(camera)
w=64
h=48
camera.resolution=(w,h)
sleep(2)
t=0
while True:
	t=t+1
	print(t)
	sleep(5)
[email protected]:~/Desktop $ clear ; python camera.py
1
  File "camera.py", line 17, in <module>
  File "/usr/lib/python2.7/dist-packages/picamera/camera.py", line 1421, in capture
    if not encoder.wait(self.CAPTURE_TIMEOUT):
  File "/usr/lib/python2.7/dist-packages/picamera/encoders.py", line 395, in wait
    self.stop()
  File "/usr/lib/python2.7/dist-packages/picamera/encoders.py", line 419, in stop
    self._close_output()
  File "/usr/lib/python2.7/dist-packages/picamera/encoders.py", line 349, in _close_output
    mo.close_stream(output, opened)
  File "/usr/lib/python2.7/dist-packages/picamera/mmalobj.py", line 371, in close_stream
    stream.flush()
  File "/usr/lib/python2.7/dist-packages/picamera/array.py", line 296, in flush
    self.array = bytes_to_yuv(self.getvalue(), self.size or self.camera.resolution)
  File "/usr/lib/python2.7/dist-packages/picamera/array.py", line 93, in bytes_to_yuv
    'Incorrect buffer length for resolution %dx%d' % (width, height))
picamera.exc.PiCameraValueError: Incorrect buffer length for resolution 64x48
miky94
Fri Jul 05, 2019 9:19 pm
I solved using:
output.truncate(0)
I don't know if there are differences with output.seek(0)
is it possible to loop PiYUVArray on a stored image?
Return to “Camera board”
