Augusto9
Select a custom area with the mouse - possible?
Tue Jun 04, 2019 6:31 pm
Hi. I'm try to use the pi camera, I'm need to select a "work area" , is it possible?
Thanks in advance!
DirkS
Re: Select a custom area with the mouse - possible?
Tue Jun 04, 2019 6:53 pm
Thanks in advance!
It depends on the software you're using.
But I can't think of Pi camera software that supports mouse selection.
Augusto9
Tue Jun 04, 2019 7:11 pm
Thanks in advance!
I'm on python. I found "ROI (region of interest)" but is only zoom, not a split image, if is not possible with the mouse, is there a way to select area on a "live mode"? Thanks for response!
DirkS
Tue Jun 04, 2019 7:20 pm
Python is not the camera software you're using. It's the programming language that's used by your camera software.
HermannSW
Wed Jun 05, 2019 7:15 am
That is not correct. If you use "-roi" and specify the matching width and height for the mode, there will be no zoom:
raspivid -md 7 -roi 0.25,0.25,0.5,0.5 -w 320 -h 240 ...
You see a zoom because the default values for width and height are 1920(1080) regardless of mode.
https://stamm-wilbrandt.de/en/Raspberry_camera.html
https://stamm-wilbrandt.de/en#raspcatbot
https://github.com/Hermann-SW/raspiraw
https://stamm-wilbrandt.de/github_repo_i420toh264
gordon77
Wed Jun 05, 2019 8:19 am
Thanks in advance!
Can you be more specific what you are trying to do?. Are you trying to crop an image or maybe analyse a specific area?
Return to “Camera board”
