blackmagicman
Convert Video Input over SATA to HDMI via Raspberry Pi
Thu May 23, 2019 2:05 am
I recently purchased a Blackmagic Pocket Cinema Camera 4k. The camera has no way to output full 4K 60fps footage to an external monitor (the monitor needs an HDMI input). The camera has a USB-C port, but it is not thunderbolt and thus the monitor can't accept it as an input. My only option at this point is to use a CFAST memory card in the camera's memory card slot, which is a poor solution compared to recording directly to my monitor.
Here's my theory. The camera has a CFast port, which I can convert to an eSATA port and input into a raspberry pi. I am wondering if I could use a raspberry pi to receive the video data input from the CFast port over eSATA, convert that video data to an HDMI output, and stream that to an HDMI port, which I could then hook to my monitor.
First question: Am I crazy? I am a bit of a nerd, but my knowledge of raspberry pi is a bit limited, so maybe this is impossible.
Second question: If it is possible, can anyone offer me some guidance on how I might go about doing this?
Re: Convert Video Input over SATA to HDMI via Raspberry Pi
Thu May 23, 2019 4:23 am
https://www.blackmagicdesign.com/uk/pro ... s/W-CIN-12
According to the specification it has HDMI Type A Output so you could "attempt" to feed that into a Raspberry Pi ???
viewtopic.php?f=45&t=238826
viewtopic.php?f=38&t=120702
adieu
Imperf3kt
Thu May 23, 2019 10:27 pm
You say the camera has a USB-C port, so why not use a usb-c to Hdmi adaptor?
55:55:44:44:4C
52:4C:52:42:41
blackmagicman
Sun May 26, 2019 5:40 pm
Thank you for your thoughts, guys. Sorry for my slow reply, I didn't have notifications turned on. :roll:
The HDMI port is not the right generation port to output full resolution. This port will only support 1080p footage (not 4K), which is insufficient for our needs.
The USB-C won't output an actual video feed, it will only write to a drive because the USB-C port isn't a thunderbolt port. Since it's not thunderbolt (according to what I've read) that means it doesn't have the speed to output a live feed to the monitor. I have tried that though. It didn't work. ;)
This is why I thought of the CFAST port which I believe has a throughput sufficient for a live feed if I can convert the data coming out of it.
Sun May 26, 2019 10:08 pm
The Raspberry Pi SBC is HDMi 1080p output, so your holy grail of 4k is not feasible.
The Raspberry Pi does not have an esata input either, and USB is likely be to slow for your purposes.
The Raspberry Pi SBC is good but there are times you have to realise that a different product is suitable...
adieu
blackmagicman
Sun May 26, 2019 10:22 pm
The Raspberry Pi SBC is good but there are times you have to realize that a different product is suitable...
Thank you for your reply. Any recommendations you might have would be appreciated.
Mon May 27, 2019 4:05 am
We do not discuss alternative products here, obviously, but for quality and support:
https://www.hardkernel.com/
adieu
blackmagicman
Mon May 27, 2019 4:07 am
Of course, thanks for the direction though.
