So I've got two Raspberry Pi 3b+ running, One running MotionEyeOS, and one running OctoPi, and my issue is exactly the same on both.
If I connect them via ethernet to a switch, they're able to connect and I can SSH into them. If I try to let them run over wifi, they cannot connect to my network and I have no access to them.
Both the SSID and password for the network are correct, and both rPis can connect to wifi if using Raspian (NOOBs on one, vanilla raspian on the other) and connecting them to this wireless network via network settings in those operating systems. My dilemma is I need the actual installs of both of these. CLI installed version running on raspian doesn't give me features I need specifically in MotionEyeOS like Fast network camera.
Both OSes (motioneyeOS and OctoPi) support WPA supplicant files and were configured properly with WPA/2 configs, and the proper region selected.
TL;DR: WPA supplicant isn't working, SSID and password are correct, can't figure out the issue is.
Anyone have suggestions?
Thanks in advance.
