Following the above call for 64-bit issue reports here are some findings (I used the latest github firmware/boot/* release):
U-Boot 2018.11 (Jan 01 2019 - 15:29:38 +0100)
DRAM: 896 MiB
RPI 2 Model B (0xa22042)
MMC: [email protected]: 0, [email protected]: 1
Loading Environment from FAT... *** Warning - bad CRC, using default environment
In: serial
Out: vidconsole
Err: vidconsole
Net: No ethernet found.
starting USB...
USB0: scanning bus 0 for devices... Timeout poll on interrupt endpoint
Failed to get keyboard state from device 04d9:1400
3 USB Device(s) found
scanning usb for storage devices... 0 Storage Device(s) found
Hit any key to stop autoboot: 0
U-Boot>
U-Boot> fatload mmc 0:1 ${fdt_addr} bcm2710-rpi-3-b_be.dtb
25485 bytes read in 5 ms (4.9 MiB/s)
U-Boot>
U-Boot> fatload mmc 0:1 ${kernel_addr_r} kernel8_be.img
14067720 bytes read in 593 ms (22.6 MiB/s)
U-Boot>
U-Boot> setenv bootargs earlyprintk console=tty1 console=ttyAMA0,115200 root=/dev/mmcblk0p2 rootfstype=ext4 rootwait
U-Boot>
U-Boot> booti ${kernel_addr_r} - ${fdt_addr}
## Flattened Device Tree blob at 2eff9d00
Booting using the fdt blob at 0x2eff9d00
reserving fdt memory region: addr=0 size=1000
Using Device Tree in place at 000000002eff9d00, end 000000002f00308c
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[ 0.000000] Linux version 4.19.27-v8+ ([email protected]) (gcc version 7.2.0 (Gentoo 7.2.0 p1.1)) #1 SMP PREEMPT Sat Mar 9 16:58:49 CET 2019
[ 0.000000] Machine model: Raspberry Pi 3 Model B
[ 0.000000] cma: Reserved 8 MiB at 0x0000000037800000
[ 0.000000] random: get_random_bytes called from start_kernel+0xb4/0x474 with crng_init=0
[ 0.000000] percpu: Embedded 23 pages/cpu @(____ptrval____) s56792 r8192 d29224 u94208
[ 0.000000] Detected VIPT I-cache on CPU0
[ 0.000000] CPU features: enabling workaround for ARM erratum 843419
[ 0.000000] CPU features: enabling workaround for ARM erratum 845719
[ 0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 225792
[ 0.000000] Kernel command line: earlyprintk console=tty1 console=ttyAMA0,115200 root=/dev/mmcblk0p2 rootfstype=ext4 rootwait
[ 0.000000] Dentry cache hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.000000] Memory: 875960K/917504K available (7806K kernel code, 874K rwdata, 2336K rodata, 2688K init, 918K bss, 33352K reserved, 8192K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] ftrace: allocating 26244 entries in 103 pages
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] Tasks RCU enabled.
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] arch_timer: cp15 timer(s) running at 19.20MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[ 0.000008] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.000282] Console: colour dummy device 80x25
[ 0.000819] console [tty1] enabled
[ 0.000949] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=19200)
[ 0.001009] pid_max: default: 32768 minimum: 301
[ 0.001451] Mount-cache hash table entries: 2048 (order: 2, 16384 bytes)
[ 0.001510] Mountpoint-cache hash table entries: 2048 (order: 2, 16384 bytes)
[ 0.002913] Disabling memory control group subsystem
[ 0.009166] ASID allocator initialised with 32768 entries
[ 0.011157] rcu: Hierarchical SRCU implementation.
[ 0.016250] smp: Bringing up secondary CPUs ...
[ 0.024514] Detected VIPT I-cache on CPU1
[ 0.024593] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[ 0.032634] Detected VIPT I-cache on CPU2
[ 0.032686] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[ 0.040783] Detected VIPT I-cache on CPU3
[ 0.040829] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[ 0.041036] smp: Brought up 1 node, 4 CPUs
[ 0.041188] SMP: Total of 4 processors activated.
[ 0.041224] CPU features: detected: 32-bit EL0 Support
[ 0.044150] CPU: All CPU(s) started at EL2
[ 0.044226] alternatives: patching kernel code
[ 0.046104] devtmpfs: initialized
[ 0.061965] Enabled cp15_barrier support
[ 0.062034] Enabled setend support
[ 0.062654] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns
[ 0.062719] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.063523] pinctrl core: initialized pinctrl subsystem
[ 0.064363] NET: Registered protocol family 16
[ 0.070781] cpuidle: using governor menu
[ 0.071219] vdso: 2 pages (1 code @ (____ptrval____), 1 data @ (____ptrval____))
[ 0.071266] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.076465] DMA: preallocated 256 KiB pool for atomic allocations
[ 0.076674] Serial: AMBA PL011 UART driver
[ 0.081568] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[ 0.124851] bcm2835-dma 3f007000.dma: DMA legacy API manager at (____ptrval____), dmachans=0x1
[ 0.127364] SCSI subsystem initialized
[ 0.127747] usbcore: registered new interface driver usbfs
[ 0.127848] usbcore: registered new interface driver hub
[ 0.128028] usbcore: registered new device driver usb
[ 0.129492] raspberrypi-firmware soc:firmware: Request 0x00000001 returned status 0x01000080
[ 0.130507] raspberrypi-firmware soc:firmware: Request 0x00000003 returned status 0x01000080
[ 0.131525] raspberrypi-firmware soc:firmware: Request 0x00030046 returned status 0x01000080
[ 0.133372] clocksource: Switched to clocksource arch_sys_counter
[ 0.257529] VFS: Disk quotas dquot_6.6.0
[ 0.257687] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.257941] FS-Cache: Loaded
[ 0.258390] CacheFiles: Loaded
[ 0.272106] NET: Registered protocol family 2
[ 0.273207] tcp_listen_portaddr_hash hash table entries: 512 (order: 1, 8192 bytes)
[ 0.273285] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.273499] TCP bind hash table entries: 8192 (order: 5, 131072 bytes)
[ 0.273742] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.274044] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.274125] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.274537] NET: Registered protocol family 1
[ 0.275591] RPC: Registered named UNIX socket transport module.
[ 0.275628] RPC: Registered udp transport module.
[ 0.275658] RPC: Registered tcp transport module.
[ 0.275688] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.277474] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.278010] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[ 0.280612] Initialise system trusted keyrings
[ 0.281047] workingset: timestamp_bits=46 max_order=18 bucket_order=0
[ 0.293833] FS-Cache: Netfs 'nfs' registered for caching
[ 0.295068] NFS: Registering the id_resolver key type
[ 0.295160] Key type id_resolver registered
[ 0.295191] Key type id_legacy registered
[ 0.299261] Key type asymmetric registered
[ 0.299304] Asymmetric key parser 'x509' registered
[ 0.299452] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
[ 0.299752] io scheduler noop registered
[ 0.299786] io scheduler deadline registered
[ 0.300041] io scheduler cfq registered (default)
[ 0.300078] io scheduler mq-deadline registered
[ 0.300110] io scheduler kyber registered
[ 0.303956] raspberrypi-firmware soc:firmware: Request 0x00048020 returned status 0x01000080
[ 0.304022] brcmvirt-gpio soc:virtgpio: Failed to set gpiovirtbuf, trying to get err:ffffffea
[ 0.304160] raspberrypi-firmware soc:firmware: Request 0x00040010 returned status 0x01000080
[ 0.304207] brcmvirt-gpio soc:virtgpio: Failed to get gpiovirtbuf
[ 0.304265] brcmvirt-gpio: probe of soc:virtgpio failed with error -22
[ 0.305082] BCM2708FB: allocated DMA memory 0x00000000f7840000
[ 0.305156] BCM2708FB: allocated DMA channel 0
[ 0.305255] raspberrypi-firmware soc:firmware: Request 0x00010006 returned status 0x01000080
[ 0.308691] raspberrypi-firmware soc:firmware: Request 0x00048003 returned status 0x01000080
[ 0.309543] raspberrypi-firmware soc:firmware: Request 0x00048003 returned status 0x01000080
[ 0.309593] bcm2708_fb soc:fb: Failed to allocate GPU framebuffer (-22)
[ 0.309739] bcm2708_fb soc:fb: probe failed, err -22
[ 0.309790] bcm2708_fb: probe of soc:fb failed with error -22
[ 0.311238] raspberrypi-firmware soc:firmware: Request 0x00030030 returned status 0x01000080
[ 0.313509] bcm2835-rng 3f104000.rng: hwrng registered
[ 0.313792] vc-mem: phys_addr:0x00000000 mem_base=0x00000000 mem_size:0x00000000(0 MiB)
[ 0.314748] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
[ 0.315145] cacheinfo: Unable to detect cache hierarchy for CPU 0
[ 0.331777] brd: module loaded
[ 0.348333] loop: module loaded
[ 0.348415] Loading iSCSI transport class v2.0-870.
[ 0.349910] libphy: Fixed MDIO Bus: probed
[ 0.350075] usbcore: registered new interface driver lan78xx
[ 0.350191] usbcore: registered new interface driver smsc95xx
[ 0.350240] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 0.350689] raspberrypi-firmware soc:firmware: Request 0x00028001 returned status 0x01000080
[ 0.351815] usbcore: registered new interface driver usb-storage
[ 0.353141] bcm2835-wdt 3f100000.watchdog: Broadcom BCM2835 watchdog timer
[ 0.353589] raspberrypi-firmware soc:firmware: Request 0x00030007 returned status 0x01000080
[ 0.353640] bcm2835-cpufreq:bcm2835_cpufreq_get_clock:93: Failed to get clock (-22)
[ 0.353742] raspberrypi-firmware soc:firmware: Request 0x00030004 returned status 0x01000080
[ 0.353789] bcm2835-cpufreq:bcm2835_cpufreq_get_clock:93: Failed to get clock (-22)
[ 0.353828] bcm2835-cpufreq: min=0 max=0
[ 0.353952] raspberrypi-firmware soc:firmware: Request 0x00030002 returned status 0x01000080
[ 0.353998] bcm2835-cpufreq:bcm2835_cpufreq_get_clock:93: Failed to get clock (-22)
[ 0.354038] cpufreq: cpufreq_online: ->get() failed
[ 0.354225] raspberrypi-firmware soc:firmware: Request 0x00030007 returned status 0x01000080
[ 0.354271] bcm2835-cpufreq:bcm2835_cpufreq_get_clock:93: Failed to get clock (-22)
[ 0.354397] raspberrypi-firmware soc:firmware: Request 0x00030004 returned status 0x01000080
[ 0.354443] bcm2835-cpufreq:bcm2835_cpufreq_get_clock:93: Failed to get clock (-22)
[ 0.354482] bcm2835-cpufreq: min=0 max=0
[ 0.354595] raspberrypi-firmware soc:firmware: Request 0x00030002 returned status 0x01000080
[ 0.354642] bcm2835-cpufreq:bcm2835_cpufreq_get_clock:93: Failed to get clock (-22)
[ 0.354680] cpufreq: cpufreq_online: ->get() failed
[ 0.354877] raspberrypi-firmware soc:firmware: Request 0x00030007 returned status 0x01000080
[ 0.354924] bcm2835-cpufreq:bcm2835_cpufreq_get_clock:93: Failed to get clock (-22)
[ 0.355009] raspberrypi-firmware soc:firmware: Request 0x00030004 returned status 0x01000080
[ 0.355054] bcm2835-cpufreq:bcm2835_cpufreq_get_clock:93: Failed to get clock (-22)
[ 0.355093] bcm2835-cpufreq: min=0 max=0
[ 0.355203] raspberrypi-firmware soc:firmware: Request 0x00030002 returned status 0x01000080
[ 0.355250] bcm2835-cpufreq:bcm2835_cpufreq_get_clock:93: Failed to get clock (-22)
[ 0.355288] cpufreq: cpufreq_online: ->get() failed
[ 0.355502] raspberrypi-firmware soc:firmware: Request 0x00030007 returned status 0x01000080
[ 0.355549] bcm2835-cpufreq:bcm2835_cpufreq_get_clock:93: Failed to get clock (-22)
[ 0.355648] raspberrypi-firmware soc:firmware: Request 0x00030004 returned status 0x01000080
[ 0.355694] bcm2835-cpufreq:bcm2835_cpufreq_get_clock:93: Failed to get clock (-22)
[ 0.355733] bcm2835-cpufreq: min=0 max=0
[ 0.355829] raspberrypi-firmware soc:firmware: Request 0x00030002 returned status 0x01000080
[ 0.355875] bcm2835-cpufreq:bcm2835_cpufreq_get_clock:93: Failed to get clock (-22)
[ 0.355913] cpufreq: cpufreq_online: ->get() failed
[ 0.356586] sdhci: Secure Digital Host Controller Interface driver
[ 0.356621] sdhci: Copyright(c) Pierre Ossman
[ 0.357231] mmc-bcm2835 3f300000.mmc: could not get clk, deferring probe
[ 0.357890] sdhost-bcm2835 3f202000.mmc: could not get clk, deferring probe
[ 0.358126] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.358808] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.358931] hidraw: raw HID events driver (C) Jiri Kosina
[ 0.359149] usbcore: registered new interface driver usbhid
[ 0.359183] usbhid: USB HID core driver
[ 0.359583] Initializing XFRM netlink socket
[ 0.359653] NET: Registered protocol family 17
[ 0.359833] Key type dns_resolver registered
[ 0.361005] registered taskstats version 1
[ 0.361051] Loading compiled-in X.509 certificates
[ 0.366664] raspberrypi-firmware soc:firmware: Request 0x00030004 returned status 0x01000080
[ 0.374483] uart-pl011 3f201000.serial: cts_event_workaround enabled
[ 0.374637] 3f201000.serial: ttyAMA0 at MMIO 0x3f201000 (irq = 66, base_baud = 0) is a PL011 rev2
[ 1.457591] console [ttyAMA0] enabled
[ 1.463417] bcm2835-aux-uart 3f215040.serial: unable to register 8250 port - -28
[ 1.470915] bcm2835-aux-uart: probe of 3f215040.serial failed with error -28
[ 1.478545] raspberrypi-firmware soc:firmware: Request 0x00028001 returned status 0x01000080
[ 1.488483] mmc-bcm2835 3f300000.mmc: mmc_debug:0 mmc_debug2:0
[ 1.494384] mmc-bcm2835 3f300000.mmc: DMA channel allocated
[ 1.527772] sdhost: log_buf @ (____ptrval____) (f7840000)
[ 1.533569] raspberrypi-firmware soc:firmware: Request 0x00038042 returned status 0x01000080
[ 1.590029] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[ 1.596386] raspberrypi-firmware soc:firmware: Request 0x00028001 returned status 0x01000080
[ 1.626538] raspberrypi-firmware soc:firmware: Request 0x00028001 returned status 0x01000080
[ 1.637552] of_cfs_init
[ 1.642275] of_cfs_init: OK
[ 1.645943] uart-pl011 3f201000.serial: no DMA platform data
[ 1.654293] Waiting for root device /dev/mmcblk0p2...
[ 1.698186] mmc0: host does not support reading read-only switch, assuming write-enable
[ 1.706307] mmc0: new SDHC card at address aaaa
[ 1.713450] mmcblk0: mmc0:aaaa SS32G 29.7 GiB
[ 11.746369] mmc0: timeout waiting for hardware interrupt.
[ 11.751799] [5822b48d] REQ< 8fb3bf8 10800
[ 11.755822] [5822b48e] CMD< 5 0
[ 11.758975] [5822b490] FCM< 8fb3bf8 8fb3cc8
[ 11.763170] [5822b7ab] CMD 5 0
[ 11.766323] [5822b7ab] REQ> 8fb3bf8 0
[ 11.769996] [5822b7b8] TSK< 8fb3bf8 0
[ 11.773671] [5822b7bd] TSK> 8fb3bf8 0
[ 11.777345] [5822b7cc] REQ< 8fb3bf8 10800
[ 11.781366] [5822b7cd] CMD< 5 0
[ 11.784517] [5822b7d0] FCM< 8fb3bf8 8fb3cc8
[ 11.788712] [5822bad1] CMD 5 0
[ 11.791863] [5822bad2] REQ> 8fb3bf8 0
[ 11.795537] [5822bade] TSK< 8fb3bf8 0
[ 11.799211] [5822bae4] TSK> 8fb3bf8 0
[ 11.802886] [5822bb10] REQ< 8fb3ad8 10800
[ 11.806907] [5822bb11] CMD< 37 0
[ 11.810145] [5822bb14] FCM< 8fb3ad8 8fb3b98
[ 11.814340] [5822bc2e] RSP 400120 0
[ 11.817926] [5822bc33] FCM> 8fb3ad8 0
[ 11.821600] [5822bc34] CMD 37 0
[ 11.824838] [5822bc35] REQ> 8fb3ad8 0
[ 11.828512] [5822bc41] TSK< 8fb3ad8 0
[ 11.832187] [5822bc47] TSK> 8fb3ad8 0
[ 11.835861] [5822bc57] REQ< 8fb3c28 10800
[ 11.839882] [5822bc58] CMD< 29 0
[ 11.843121] [5822bc5a] FCM< 8fb3c28 8fb3cf8
[ 11.847317] [5822bd71] RSP 40ff8000 0
[ 11.851078] [5822bd77] FCM> 8fb3c28 0
[ 11.854752] [5822bd78] CMD 29 0
[ 11.857990] [5822bd78] REQ> 8fb3c28 0
[ 11.861663] [5822bd85] TSK< 8fb3c28 0
[ 11.865336] [5822bd8b] TSK> 8fb3c28 0
[ 11.869009] [5822bd9e] IOS< 61a80 0
[ 11.872508] [5822c2a0] REQ< 8fb3b58 10800
[ 11.876530] [5822c2a1] CMD< 0 0
[ 11.879683] [5822c2a3] FCM< 8fb3b58 8fb3c18
[ 11.883878] [5822c355] FCM> 8fb3b58 0
[ 11.887552] [5822c356] CMD 0 0
[ 11.890705] [5822c356] REQ> 8fb3b58 0
[ 11.894379] [5822c363] TSK< 8fb3b58 0
[ 11.898053] [5822c369] TSK> 8fb3b58 0
[ 11.901727] [5822cfb1] IOS< 61a80 0
[ 11.905226] [5822d4b6] REQ< 8fb3b68 10800
[ 11.909247] [5822d4b7] CMD< 8 1aa
[ 11.912574] [5822d4ba] FCM< 8fb3b68 8fb3c18
[ 11.916769] [5822d5ed] RSP 1aa 0
[ 11.920095] [5822d5f3] FCM> 8fb3b68 0
[ 11.923768] [5822d5f3] CMD 8 0
[ 11.926919] [5822d5f4] REQ> 8fb3b68 0
[ 11.930592] [5822d601] TSK< 8fb3b68 0
[ 11.934265] [5822d607] TSK> 8fb3b68 0
[ 11.937939] [5822d619] REQ< 8fb39f8 10800
[ 11.941960] [5822d61a] CMD< 37 0
[ 11.945199] [5822d61c] FCM< 8fb39f8 8fb3ab8
[ 11.949394] [5822d74a] RSP 120 0
[ 11.952720] [5822d750] FCM> 8fb39f8 0
[ 11.956394] [5822d751] CMD 37 0
[ 11.959632] [5822d751] REQ> 8fb39f8 0
[ 11.963305] [5822d75e] TSK< 8fb39f8 0
[ 11.966978] [5822d764] TSK> 8fb39f8 0
[ 11.970651] [5822d774] REQ< 8fb3b48 10800
[ 11.974673] [5822d775] CMD< 29 40200000
[ 11.978520] [5822d778] FCM< 8fb3b48 8fb3c18
[ 11.982715] [5822d88c] RSP 40ff8000 0
[ 11.986475] [5822d892] FCM> 8fb3b48 0
[ 11.990148] [5822d893] CMD 29 0
[ 11.993388] [5822d894] REQ> 8fb3b48 0
[ 11.997062] [5822d8a0] TSK< 8fb3b48 0
[ 12.000736] [5822d8a6] TSK> 8fb3b48 0
[ 12.004409] [582309a6] REQ< 8fb39f8 10800
[ 12.008430] [582309a7] CMD< 37 0
[ 12.011668] [582309aa] FCM< 8fb39f8 8fb3ab8
[ 12.015863] [58230ae0] RSP 120 0
[ 12.019189] [58230ae7] FCM> 8fb39f8 0
[ 12.022862] [58230ae8] CMD 37 0
[ 12.026100] [58230ae8] REQ> 8fb39f8 0
[ 12.029774] [58230af5] TSK< 8fb39f8 0
[ 12.033449] [58230afb] TSK> 8fb39f8 0
[ 12.037123] [58230b0c] REQ< 8fb3b48 10800
[ 12.041144] [58230b0d] CMD< 29 40200000
[ 12.044991] [58230b0f] FCM< 8fb3b48 8fb3c18
[ 12.049186] [58230c3e] RSP 40ff8000 0
[ 12.052947] [58230c44] FCM> 8fb3b48 0
[ 12.056619] [58230c45] CMD 29 0
[ 12.059858] [58230c45] REQ> 8fb3b48 0
[ 12.063531] [58230c52] TSK< 8fb3b48 0
[ 12.067205] [58230c57] TSK> 8fb3b48 0
[ 12.070878] [58233d5b] REQ< 8fb39f8 10800
[ 12.074900] [58233d5c] CMD< 37 0
[ 12.078139] [58233d5f] FCM< 8fb39f8 8fb3ab8
[ 12.082335] [58233e8f] RSP 120 0
[ 12.085660] [58233e95] FCM> 8fb39f8 0
[ 12.089332] [58233e95] CMD 37 0
[ 12.092572] [58233e96] REQ> 8fb39f8 0
[ 12.096246] [58233ea3] TSK< 8fb39f8 0
[ 12.099920] [58233ea8] TSK> 8fb39f8 0
[ 12.103594] [58233eb9] REQ< 8fb3b48 10800
[ 12.107615] [58233eb9] CMD< 29 40200000
[ 12.111463] [58233ebc] FCM< 8fb3b48 8fb3c18
[ 12.115658] [58233ff2] RSP 40ff8000 0
[ 12.119419] [58233ff7] FCM> 8fb3b48 0
[ 12.123093] [58233ff8] CMD 29 0
[ 12.126331] [58233ff9] REQ> 8fb3b48 0
[ 12.130005] [58234005] TSK< 8fb3b48 0
[ 12.133679] [5823400b] TSK> 8fb3b48 0
[ 12.137353] [58237110] REQ< 8fb39f8 10800
[ 12.141374] [58237110] CMD< 37 0
[ 12.144614] [58237113] FCM< 8fb39f8 8fb3ab8
[ 12.148809] [58237244] RSP 120 0
[ 12.152134] [5823724a] FCM> 8fb39f8 0
[ 12.155807] [5823724a] CMD 37 0
[ 12.159046] [5823724b] REQ> 8fb39f8 0
[ 12.162720] [58237258] TSK< 8fb39f8 0
[ 12.166394] [5823725d] TSK> 8fb39f8 0
[ 12.170068] [5823726d] REQ< 8fb3b48 10800
[ 12.174089] [5823726e] CMD< 29 40200000
[ 12.177937] [58237271] FCM< 8fb3b48 8fb3c18
[ 12.182132] [58237384] RSP c0ff8000 0
[ 12.185893] [58237389] FCM> 8fb3b48 0
[ 12.189567] [5823738a] CMD 29 0
[ 12.192806] [5823738b] REQ> 8fb3b48 0
[ 12.196479] [58237397] TSK< 8fb3b48 0
[ 12.200152] [5823739d] TSK> 8fb3b48 0
[ 12.203825] [582373ae] REQ< 8fb3b18 10800
[ 12.207846] [582373af] CMD< 2 0
[ 12.210997] [582373b2] FCM< 8fb3b18 8fb3be8
[ 12.215194] [582375b6] RSP 3534453 53333247
[ 12.219477] [582375bc] FCM> 8fb3b18 0
[ 12.223152] [582375bc] CMD 2 0
[ 12.226305] [582375bd] REQ> 8fb3b18 0
[ 12.229979] [582375ca] TSK< 8fb3b18 0
[ 12.233653] [582375cf] TSK> 8fb3b18 0
[ 12.237327] [582375e9] REQ< 8fb3bb8 10800
[ 12.241348] [582375e9] CMD< 3 0
[ 12.244500] [582375ec] FCM< 8fb3bb8 8fb3c78
[ 12.248695] [58237721] RSP aaaa0520 0
[ 12.252456] [58237726] FCM> 8fb3bb8 0
[ 12.256130] [58237727] CMD 3 0
[ 12.259283] [58237728] REQ> 8fb3bb8 0
[ 12.262957] [58237734] TSK< 8fb3bb8 0
[ 12.266631] [5823773a] TSK> 8fb3bb8 0
[ 12.270305] [5823774c] REQ< 8fb3b58 10800
[ 12.274326] [5823774d] CMD< 9 aaaa0000
[ 12.278087] [58237750] FCM< 8fb3b58 8fb3c28
[ 12.282282] [58237953] RSP 400e0032 5b590000
[ 12.286651] [58237959] FCM> 8fb3b58 0
[ 12.290324] [58237959] CMD 9 0
[ 12.293475] [5823795a] REQ> 8fb3b58 0
[ 12.297149] [58237966] TSK< 8fb3b58 0
[ 12.300823] [5823796c] TSK> 8fb3b58 0
[ 12.304497] [58237980] REQ< 8fb3bc8 10800
[ 12.308519] [58237981] CMD< 7 aaaa0000
[ 12.312279] [58237983] FCM< 8fb3bc8 8fb3c78
[ 12.316473] [58237ab2] RSP 700 0
[ 12.319799] [58237ab7] FCM> 8fb3bc8 0
[ 12.323473] [58237ab8] CMD 7 0
[ 12.326624] [58237ab9] REQ> 8fb3bc8 0
[ 12.330297] [58237ac5] TSK< 8fb3bc8 0
[ 12.333970] [58237acb] TSK> 8fb3bc8 0
[ 12.337643] [58237adc] REQ< 8fb3a28 10801
[ 12.341664] [58237add] CMD< 37 aaaa0000
[ 12.345511] [58237ae0] FCM< 8fb3a28 8fb3ae8
[ 12.349706] [58237c0e] RSP 920 0
[ 12.353033] [58237c13] FCM> 8fb3a28 0
[ 12.356708] [58237c14] CMD 37 0
[ 12.359946] [58237c15] REQ> 8fb3a28 0
[ 12.363619] [58237c22] TSK< 8fb3a28 0
[ 12.367294] [58237c27] TSK> 8fb3a28 0
[ 12.370967] [58237c3a] REQ< 8fb3c08 10801
[ 12.374989] [58237c3b] CMD< 33 0
[ 12.378228] [58237c3e] CMDD 1 8
[ 12.381379] [58237c3f] FCM< 8fb3c08 8fb3bc8
[ 12.385574] [58237d6d] RSP 920 0
[ 12.388900] [58237d6d] FCM> 8fb3c08 0
[ 12.392574] [58237d6e] CMD 33 8
[ 12.395813] [58237d6f] REQ> 8fb3c08 0
[ 12.399487] [9823868e] IRQ< 1 0
[ 12.402638] [9823868f] IRQD 8fb3b80 1
[ 12.406311] [98238691] XFP< 8fb3b80 1
[ 12.409984] [98238696] XFP> 8fb3b80 1
[ 12.413658] [98238697] FDA< 8fb3c08 0
[ 12.417331] [98238699] TCM< 8fb3b80 0
[ 12.421004] [9823869a] WTC< 10801 0
[ 12.424503] [9823869b] WTC> 10801 0
[ 12.428002] [9823869d] TCM> 8fb3b80 0
[ 12.431675] [9823869e] FDA> 8fb3c08 0
[ 12.435348] [9823869e] IRQ> 0 0
[ 12.438500] [982386a6] TSK< 8fb3c08 0
[ 12.442174] [982386b2] TSK> 8fb3c08 0
[ 12.445849] [58238dbb] REQ< 8fb3a28 10801
[ 12.449870] [58238dbc] CMD< 37 aaaa0000
[ 12.453717] [58238dbe] FCM< 8fb3a28 8fb3ae8
[ 12.457912] [58238ed3] RSP 920 0
[ 12.461238] [58238ed8] FCM> 8fb3a28 0
[ 12.464912] [58238ed9] CMD 37 0
[ 12.468150] [58238eda] REQ> 8fb3a28 0
[ 12.471824] [58238ee7] TSK< 8fb3a28 0
[ 12.475497] [58238eec] TSK> 8fb3a28 0
[ 12.479170] [58238efd] REQ< 8fb3c08 10801
[ 12.483191] [58238efe] CMD< d 0
[ 12.486341] [58238f01] CMDD 1 40
[ 12.489582] [58238f02] FCM< 8fb3c08 8fb3bc8
[ 12.493777] [58239030] RSP 920 0
[ 12.497102] [58239030] FCM> 8fb3c08 0
[ 12.500775] [58239031] CMD d 40
[ 12.504013] [58239032] REQ> 8fb3c08 0
[ 12.507686] [182392a4] IRQ< 1 0
[ 12.510838] [182392a5] IRQD 8fb3b80 1
[ 12.514511] [182392a6] XFP< 8fb3b80 1
[ 12.518187] [18239670] XFP> 8fb3b80 1
[ 12.521861] [18239670] FDA< 8fb3c08 0
[ 12.525535] [18239671] TCM< 8fb3b80 0
[ 12.529208] [18239672] WTC< 10805 0
[ 12.532708] [1823969e] WTC> 10801 0
[ 12.536206] [1823969f] TCM> 8fb3b80 0
[ 12.539880] [182396a0] FDA> 8fb3c08 0
[ 12.543553] [182396a0] IRQ> 0 0
[ 12.546705] [182396bb] TSK< 8fb3c08 0
[ 12.550379] [182396c7] TSK> 8fb3c08 0
[ 12.554053] [582396df] REQ< 8fb3bd8 10801
[ 12.558075] [582396e0] CMD< 6 fffff0
[ 12.561661] [582396e3] CMDD 1 40
[ 12.564901] [582396e4] FCM< 8fb3bd8 8fb3b98
[ 12.569095] [58239812] RSP 900 0
[ 12.572421] [58239813] FCM> 8fb3bd8 0
[ 12.576093] [58239814] CMD 6 40
[ 12.579332] [58239814] REQ> 8fb3bd8 0
[ 12.583004] [58239c77] IRQ< 1 0
[ 12.586157] [58239c77] IRQD 8fb3b50 1
[ 12.589831] [58239c78] XFP< 8fb3b50 1
[ 12.593505] [5823a03b] XFP> 8fb3b50 1
[ 12.597179] [5823a03c] FDA< 8fb3bd8 0
[ 12.600853] [5823a03d] TCM< 8fb3b50 0
[ 12.604527] [5823a03e] WTC< 10805 0
[ 12.608026] [5823a06c] WTC> 10801 0
[ 12.611525] [5823a06e] TCM> 8fb3b50 0
[ 12.615198] [5823a06e] FDA> 8fb3bd8 0
[ 12.618871] [5823a06f] IRQ> 0 0
[ 12.622024] [5823a082] TSK< 8fb3bd8 0
[ 12.625698] [5823a08b] TSK> 8fb3bd8 0
[ 12.629372] [5823c065] IOS< 17d7840 0
[ 12.633046] [5823f2af] PRD< 352b7470 0
[ 12.636806] [5823f2b1] PRD1 358f0c80 0
[ 12.640566] [5823f2bb] PRD2 1 0
[ 12.643717] [5823f97a] PRD3 351d2608 0
[ 12.647477] [5823f97c] PDM> 352b7470 0
[ 12.651238] [5823f97f] REQ< 352b7330 10801
[ 12.655346] [5823f981] CMD< 12 0
[ 12.658586] [5823f985] CMDD 8 200
[ 12.661911] [5823f986] SDMA 352b7470 358f0c80
[ 12.666280] [5823f989] FCM< 352b7330 352b73f0
[ 12.670649] [5823f98d] RSP 900 0
[ 12.673975] [5823f98d] FCM> 352b7330 0
[ 12.677735] [5823f98f] CMD 12 200
[ 12.681147] [5823f98f] REQ> 352b7330 0
[ 12.684907] [58bcf392] TIM< 0 0
[ 12.688063] mmc0: cmd op 18 arg 0x0 flags 0xb5 - resp 00000900 00000000 00000000 00000000, err 0
[ 12.696870] mmc0: data blocks 8 blksz 200 - err 0
[ 12.701591] mmc0: stop op 12 arg 0x0 flags 0x95 - resp 00000000 00000000 00000000 00000000, err 0
[ 12.710484] mmc0: =========== REGISTER DUMP ===========
[ 12.715721] mmc0: SDCMD 0x00000052
[ 12.719218] mmc0: SDARG 0x00000000
[ 12.722715] mmc0: SDTOUT 0x00bebc20
[ 12.726212] mmc0: SDCDIV 0x00000008
[ 12.729710] mmc0: SDRSP0 0x00000900
[ 12.733207] mmc0: SDRSP1 0x00001269
[ 12.736705] mmc0: SDRSP2 0x7fffffff
[ 12.740202] mmc0: SDRSP3 0x00024037
[ 12.743699] mmc0: SDHSTS 0x00000001
[ 12.747196] mmc0: SDVDD 0x00000001
[ 12.750693] mmc0: SDEDM 0x00010902
[ 12.754190] mmc0: SDHCFG 0x0000040a
[ 12.757687] mmc0: SDHBCT 0x000001c0
[ 12.761184] mmc0: SDHBLC 0x00000008
[ 12.764680] mmc0: ===========================================
[ 23.010365] mmc0: timeout waiting for hardware interrupt.
[ 23.015787] [5822c2a1] CMD< 0 0
[ 23.018939] [5822c2a3] FCM< 8fb3b58 8fb3c18
[ 23.023135] [5822c355] FCM> 8fb3b58 0
[ 23.026808] [5822c356] CMD 0 0
[ 23.029959] [5822c356] REQ> 8fb3b58 0
[ 23.033633] [5822c363] TSK< 8fb3b58 0
[ 23.037306] [5822c369] TSK> 8fb3b58 0
[ 23.040979] [5822cfb1] IOS< 61a80 0
[ 23.044479] [5822d4b6] REQ< 8fb3b68 10800
[ 23.048501] [5822d4b7] CMD< 8 1aa
[ 23.051826] [5822d4ba] FCM< 8fb3b68 8fb3c18
[ 23.056023] [5822d5ed] RSP 1aa 0
[ 23.059348] [5822d5f3] FCM> 8fb3b68 0
[ 23.063021] [5822d5f3] CMD 8 0
[ 23.066175] [5822d5f4] REQ> 8fb3b68 0
[ 23.069849] [5822d601] TSK< 8fb3b68 0
[ 23.073523] [5822d607] TSK> 8fb3b68 0
[ 23.077197] [5822d619] REQ< 8fb39f8 10800
[ 23.081218] [5822d61a] CMD< 37 0
[ 23.084456] [5822d61c] FCM< 8fb39f8 8fb3ab8
[ 23.088651] [5822d74a] RSP 120 0
[ 23.091977] [5822d750] FCM> 8fb39f8 0
[ 23.095650] [5822d751] CMD 37 0
[ 23.098889] [5822d751] REQ> 8fb39f8 0
[ 23.102562] [5822d75e] TSK< 8fb39f8 0
[ 23.106235] [5822d764] TSK> 8fb39f8 0
[ 23.109908] [5822d774] REQ< 8fb3b48 10800
[ 23.113930] [5822d775] CMD< 29 40200000
[ 23.117777] [5822d778] FCM< 8fb3b48 8fb3c18
[ 23.121972] [5822d88c] RSP 40ff8000 0
[ 23.125732] [5822d892] FCM> 8fb3b48 0
[ 23.129405] [5822d893] CMD 29 0
[ 23.132645] [5822d894] REQ> 8fb3b48 0
[ 23.136320] [5822d8a0] TSK< 8fb3b48 0
[ 23.139994] [5822d8a6] TSK> 8fb3b48 0
[ 23.143668] [582309a6] REQ< 8fb39f8 10800
[ 23.147689] [582309a7] CMD< 37 0
[ 23.150927] [582309aa] FCM< 8fb39f8 8fb3ab8
[ 23.155123] [58230ae0] RSP 120 0
[ 23.158448] [58230ae7] FCM> 8fb39f8 0
[ 23.162121] [58230ae8] CMD 37 0
[ 23.165360] [58230ae8] REQ> 8fb39f8 0
[ 23.169034] [58230af5] TSK< 8fb39f8 0
[ 23.172708] [58230afb] TSK> 8fb39f8 0
[ 23.176382] [58230b0c] REQ< 8fb3b48 10800
[ 23.180403] [58230b0d] CMD< 29 40200000
[ 23.184251] [58230b0f] FCM< 8fb3b48 8fb3c18
[ 23.188446] [58230c3e] RSP 40ff8000 0
[ 23.192206] [58230c44] FCM> 8fb3b48 0
[ 23.195880] [58230c45] CMD 29 0
[ 23.199120] [58230c45] REQ> 8fb3b48 0
[ 23.202794] [58230c52] TSK< 8fb3b48 0
[ 23.206468] [58230c57] TSK> 8fb3b48 0
[ 23.210142] [58233d5b] REQ< 8fb39f8 10800
[ 23.214163] [58233d5c] CMD< 37 0
[ 23.217402] [58233d5f] FCM< 8fb39f8 8fb3ab8
[ 23.221598] [58233e8f] RSP 120 0
[ 23.224924] [58233e95] FCM> 8fb39f8 0
[ 23.228597] [58233e95] CMD 37 0
[ 23.231836] [58233e96] REQ> 8fb39f8 0
[ 23.235509] [58233ea3] TSK< 8fb39f8 0
[ 23.239182] [58233ea8] TSK> 8fb39f8 0
[ 23.242856] [58233eb9] REQ< 8fb3b48 10800
[ 23.246878] [58233eb9] CMD< 29 40200000
[ 23.250725] [58233ebc] FCM< 8fb3b48 8fb3c18
[ 23.254920] [58233ff2] RSP 40ff8000 0
[ 23.258681] [58233ff7] FCM> 8fb3b48 0
[ 23.262354] [58233ff8] CMD 29 0
[ 23.265594] [58233ff9] REQ> 8fb3b48 0
[ 23.269268] [58234005] TSK< 8fb3b48 0
[ 23.272942] [5823400b] TSK> 8fb3b48 0
[ 23.276616] [58237110] REQ< 8fb39f8 10800
[ 23.280641] [58237110] CMD< 37 0
[ 23.283879] [58237113] FCM< 8fb39f8 8fb3ab8
[ 23.288074] [58237244] RSP 120 0
[ 23.291401] [5823724a] FCM> 8fb39f8 0
[ 23.295075] [5823724a] CMD 37 0
[ 23.298313] [5823724b] REQ> 8fb39f8 0
[ 23.301987] [58237258] TSK< 8fb39f8 0
[ 23.305660] [5823725d] TSK> 8fb39f8 0
[ 23.309333] [5823726d] REQ< 8fb3b48 10800
[ 23.313357] [5823726e] CMD< 29 40200000
[ 23.317204] [58237271] FCM< 8fb3b48 8fb3c18
[ 23.321401] [58237384] RSP c0ff8000 0
[ 23.325162] [58237389] FCM> 8fb3b48 0
[ 23.328835] [5823738a] CMD 29 0
[ 23.332074] [5823738b] REQ> 8fb3b48 0
[ 23.335747] [58237397] TSK< 8fb3b48 0
[ 23.339420] [5823739d] TSK> 8fb3b48 0
[ 23.343094] [582373ae] REQ< 8fb3b18 10800
[ 23.347115] [582373af] CMD< 2 0
[ 23.350266] [582373b2] FCM< 8fb3b18 8fb3be8
[ 23.354461] [582375b6] RSP 3534453 53333247
[ 23.358743] [582375bc] FCM> 8fb3b18 0
[ 23.362416] [582375bc] CMD 2 0
[ 23.365567] [582375bd] REQ> 8fb3b18 0
[ 23.369241] [582375ca] TSK< 8fb3b18 0
[ 23.372915] [582375cf] TSK> 8fb3b18 0
[ 23.376590] [582375e9] REQ< 8fb3bb8 10800
[ 23.380611] [582375e9] CMD< 3 0
[ 23.383762] [582375ec] FCM< 8fb3bb8 8fb3c78
[ 23.387957] [58237721] RSP aaaa0520 0
[ 23.391717] [58237726] FCM> 8fb3bb8 0
[ 23.395390] [58237727] CMD 3 0
[ 23.398542] [58237728] REQ> 8fb3bb8 0
[ 23.402216] [58237734] TSK< 8fb3bb8 0
[ 23.405890] [5823773a] TSK> 8fb3bb8 0
[ 23.409564] [5823774c] REQ< 8fb3b58 10800
[ 23.413586] [5823774d] CMD< 9 aaaa0000
[ 23.417346] [58237750] FCM< 8fb3b58 8fb3c28
[ 23.421541] [58237953] RSP 400e0032 5b590000
[ 23.425910] [58237959] FCM> 8fb3b58 0
[ 23.429583] [58237959] CMD 9 0
[ 23.432735] [5823795a] REQ> 8fb3b58 0
[ 23.436409] [58237966] TSK< 8fb3b58 0
[ 23.440083] [5823796c] TSK> 8fb3b58 0
[ 23.443757] [58237980] REQ< 8fb3bc8 10800
[ 23.447778] [58237981] CMD< 7 aaaa0000
[ 23.451538] [58237983] FCM< 8fb3bc8 8fb3c78
[ 23.455733] [58237ab2] RSP 700 0
[ 23.459060] [58237ab7] FCM> 8fb3bc8 0
[ 23.462734] [58237ab8] CMD 7 0
[ 23.465885] [58237ab9] REQ> 8fb3bc8 0
[ 23.469559] [58237ac5] TSK< 8fb3bc8 0
[ 23.473232] [58237acb] TSK> 8fb3bc8 0
[ 23.476905] [58237adc] REQ< 8fb3a28 10801
[ 23.480926] [58237add] CMD< 37 aaaa0000
[ 23.484773] [58237ae0] FCM< 8fb3a28 8fb3ae8
[ 23.488968] [58237c0e] RSP 920 0
[ 23.492294] [58237c13] FCM> 8fb3a28 0
[ 23.495967] [58237c14] CMD 37 0
[ 23.499205] [58237c15] REQ> 8fb3a28 0
[ 23.502879] [58237c22] TSK< 8fb3a28 0
[ 23.506552] [58237c27] TSK> 8fb3a28 0
[ 23.510226] [58237c3a] REQ< 8fb3c08 10801
[ 23.514247] [58237c3b] CMD< 33 0
[ 23.517485] [58237c3e] CMDD 1 8
[ 23.520636] [58237c3f] FCM< 8fb3c08 8fb3bc8
[ 23.524831] [58237d6d] RSP 920 0
[ 23.528157] [58237d6d] FCM> 8fb3c08 0
[ 23.531831] [58237d6e] CMD 33 8
[ 23.535069] [58237d6f] REQ> 8fb3c08 0
[ 23.538742] [9823868e] IRQ< 1 0
[ 23.541893] [9823868f] IRQD 8fb3b80 1
[ 23.545567] [98238691] XFP< 8fb3b80 1
[ 23.549241] [98238696] XFP> 8fb3b80 1
[ 23.552915] [98238697] FDA< 8fb3c08 0
[ 23.556589] [98238699] TCM< 8fb3b80 0
[ 23.560264] [9823869a] WTC< 10801 0
[ 23.563762] [9823869b] WTC> 10801 0
[ 23.567261] [9823869d] TCM> 8fb3b80 0
[ 23.570935] [9823869e] FDA> 8fb3c08 0
[ 23.574608] [9823869e] IRQ> 0 0
[ 23.577759] [982386a6] TSK< 8fb3c08 0
[ 23.581434] [982386b2] TSK> 8fb3c08 0
[ 23.585108] [58238dbb] REQ< 8fb3a28 10801
[ 23.589130] [58238dbc] CMD< 37 aaaa0000
[ 23.592977] [58238dbe] FCM< 8fb3a28 8fb3ae8
[ 23.597172] [58238ed3] RSP 920 0
[ 23.600498] [58238ed8] FCM> 8fb3a28 0
[ 23.604172] [58238ed9] CMD 37 0
[ 23.607410] [58238eda] REQ> 8fb3a28 0
[ 23.611083] [58238ee7] TSK< 8fb3a28 0
[ 23.614756] [58238eec] TSK> 8fb3a28 0
[ 23.618429] [58238efd] REQ< 8fb3c08 10801
[ 23.622452] [58238efe] CMD< d 0
[ 23.625603] [58238f01] CMDD 1 40
[ 23.628841] [58238f02] FCM< 8fb3c08 8fb3bc8
[ 23.633036] [58239030] RSP 920 0
[ 23.636363] [58239030] FCM> 8fb3c08 0
[ 23.640038] [58239031] CMD d 40
[ 23.643277] [58239032] REQ> 8fb3c08 0
[ 23.646949] [182392a4] IRQ< 1 0
[ 23.650100] [182392a5] IRQD 8fb3b80 1
[ 23.653774] [182392a6] XFP< 8fb3b80 1
[ 23.657448] [18239670] XFP> 8fb3b80 1
[ 23.661123] [18239670] FDA< 8fb3c08 0
[ 23.664797] [18239671] TCM< 8fb3b80 0
[ 23.668471] [18239672] WTC< 10805 0
[ 23.671970] [1823969e] WTC> 10801 0
[ 23.675469] [1823969f] TCM> 8fb3b80 0
[ 23.679142] [182396a0] FDA> 8fb3c08 0
[ 23.682815] [182396a0] IRQ> 0 0
[ 23.685967] [182396bb] TSK< 8fb3c08 0
[ 23.689641] [182396c7] TSK> 8fb3c08 0
[ 23.693315] [582396df] REQ< 8fb3bd8 10801
[ 23.697336] [582396e0] CMD< 6 fffff0
[ 23.700922] [582396e3] CMDD 1 40
[ 23.704160] [582396e4] FCM< 8fb3bd8 8fb3b98
[ 23.708355] [58239812] RSP 900 0
[ 23.711682] [58239813] FCM> 8fb3bd8 0
[ 23.715357] [58239814] CMD 6 40
[ 23.718595] [58239814] REQ> 8fb3bd8 0
[ 23.722268] [58239c77] IRQ< 1 0
[ 23.725419] [58239c77] IRQD 8fb3b50 1
[ 23.729093] [58239c78] XFP< 8fb3b50 1
[ 23.732767] [5823a03b] XFP> 8fb3b50 1
[ 23.736441] [5823a03c] FDA< 8fb3bd8 0
[ 23.740115] [5823a03d] TCM< 8fb3b50 0
[ 23.743789] [5823a03e] WTC< 10805 0
[ 23.747288] [5823a06c] WTC> 10801 0
[ 23.750787] [5823a06e] TCM> 8fb3b50 0
[ 23.754461] [5823a06e] FDA> 8fb3bd8 0
[ 23.758134] [5823a06f] IRQ> 0 0
[ 23.761286] [5823a082] TSK< 8fb3bd8 0
[ 23.764960] [5823a08b] TSK> 8fb3bd8 0
[ 23.768634] [5823c065] IOS< 17d7840 0
[ 23.772308] [5823f2af] PRD< 352b7470 0
[ 23.776068] [5823f2b1] PRD1 358f0c80 0
[ 23.779829] [5823f2bb] PRD2 1 0
[ 23.782980] [5823f97a] PRD3 351d2608 0
[ 23.786741] [5823f97c] PDM> 352b7470 0
[ 23.790501] [5823f97f] REQ< 352b7330 10801
[ 23.794609] [5823f981] CMD< 12 0
[ 23.797847] [5823f985] CMDD 8 200
[ 23.801172] [5823f986] SDMA 352b7470 358f0c80
[ 23.805541] [5823f989] FCM< 352b7330 352b73f0
[ 23.809910] [5823f98d] RSP 900 0
[ 23.813235] [5823f98d] FCM> 352b7330 0
[ 23.816995] [5823f98f] CMD 12 200
[ 23.820409] [5823f98f] REQ> 352b7330 0
[ 23.824168] [58bcf392] TIM< 0 0
[ 23.827319] [58cc93df] FDA< 352b7330 0
[ 23.831079] [58cc93e0] TCM< 352b7470 ffffff92
[ 23.835448] [58cc93e1] CMD< c 0
[ 23.838601] [58cc93e5] FCM< 352b7330 352b7430
[ 23.842971] [58cc93ea] RSP b00 0
[ 23.846297] [58cc93eb] FCM> 352b7330 352b7430
[ 23.850666] [58cc93ed] TCM> 352b7470 0
[ 23.854427] [58cc93ee] FDA> 352b7330 352b7430
[ 23.858796] [58cc9423] TSK< 352b7330 0
[ 23.862557] [58cc9438] TSK> 352b7330 0
[ 23.866317] [58cc944d] REQ< 8f2bbb8 10801
[ 23.870339] [58cc944e] CMD< d aaaa0000
[ 23.874100] [58cc9451] FCM< 8f2bbb8 8f2bc78
[ 23.878295] [58cc9455] RSP 900 0
[ 23.881620] [58cc945b] FCM> 8f2bbb8 0
[ 23.885294] [58cc945c] CMD d 0
[ 23.888445] [58cc945d] REQ> 8f2bbb8 0
[ 23.892118] [58cc946e] TSK< 8f2bbb8 0
[ 23.895791] [58cc9478] TSK> 8f2bbb8 0
[ 23.899464] [58cc94d7] PRD< 352b7470 0
[ 23.903226] [58cc94d9] PRD1 358f0c80 0
[ 23.906986] [58cc94de] PRD2 1 0
[ 23.910138] [58cc94e8] PRD3 351d2708 0
[ 23.913899] [58cc94ea] PDM> 352b7470 0
[ 23.917659] [58cc94ed] REQ< 352b7330 10801
[ 23.921766] [58cc94ee] CMD< 12 0
[ 23.925004] [58cc94f1] CMDD 8 200
[ 23.928330] [58cc94f1] SDMA 352b7470 358f0c80
[ 23.932699] [58cc94f3] FCM< 352b7330 352b73f0
[ 23.937067] [58cc94f7] RSP 900 0
[ 23.940394] [58cc94f7] FCM> 352b7330 0
[ 23.944154] [58cc94f8] CMD 12 200
[ 23.947566] [58cc94f9] REQ> 352b7330 0
[ 23.951327] [5968d3ad] TIM< 0 0
[ 23.954482] mmc0: cmd op 18 arg 0x0 flags 0xb5 - resp 00000900 00000000 00000000 00000000, err 0
[ 23.963289] mmc0: data blocks 8 blksz 200 - err 0
[ 23.968009] mmc0: stop op 12 arg 0x0 flags 0x95 - resp 00000000 00000000 00000000 00000000, err 0
[ 23.976902] mmc0: =========== REGISTER DUMP ===========
[ 23.982140] mmc0: SDCMD 0x00000052
[ 23.985636] mmc0: SDARG 0x00000000
[ 23.989134] mmc0: SDTOUT 0x00bebc20
[ 23.992630] mmc0: SDCDIV 0x00000008
[ 23.996127] mmc0: SDRSP0 0x00000900
[ 23.999624] mmc0: SDRSP1 0x00001269
[ 24.003121] mmc0: SDRSP2 0xffffffff
[ 24.006618] mmc0: SDRSP3 0x0002400f
[ 24.010114] mmc0: SDHSTS 0x00000001
[ 24.013611] mmc0: SDVDD 0x00000001
[ 24.017108] mmc0: SDEDM 0x00010902
[ 24.020605] mmc0: SDHCFG 0x0000040a
[ 24.024102] mmc0: SDHBCT 0x000001c0
[ 24.027598] mmc0: SDHBLC 0x00000008
[ 24.031095] mmc0: ===========================================
[ 24.120651] raspberrypi-firmware soc:firmware: Request 0x00028001 returned status 0x01000080
[ 24.131874] VFS: Cannot open root device "mmcblk0p2" or unknown-block(179,2): error -6
[ 24.139879] Please append a correct "root=" boot option; here are the available partitions:
[ 24.148309] 0100 4096 ram0
[ 24.148321] (driver?)
[ 24.154549] 0101 4096 ram1
[ 24.154561] (driver?)
[ 24.160810] 0102 4096 ram2
[ 24.160822] (driver?)
[ 24.167009] 0103 4096 ram3
[ 24.167020] (driver?)
[ 24.173207] 0104 4096 ram4
[ 24.173218] (driver?)
[ 24.179405] 0105 4096 ram5
[ 24.179416] (driver?)
[ 24.185604] 0106 4096 ram6
[ 24.185615] (driver?)
[ 24.191801] 0107 4096 ram7
[ 24.191814] (driver?)
[ 24.198001] 0108 4096 ram8
[ 24.198012] (driver?)
[ 24.204197] 0109 4096 ram9
[ 24.204208] (driver?)
[ 24.210394] 010a 4096 ram10
[ 24.210406] (driver?)
[ 24.216679] 010b 4096 ram11
[ 24.216690] (driver?)
[ 24.222963] 010c 4096 ram12
[ 24.222975] (driver?)
[ 24.229247] 010d 4096 ram13
[ 24.229258] (driver?)
[ 24.235531] 010e 4096 ram14
[ 24.235542] (driver?)
[ 24.241813] 010f 4096 ram15
[ 24.241825] (driver?)
[ 24.248117] b300 31166976 mmcblk0
[ 24.248129] driver: mmcblk
[ 24.255011] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(179,2)
[ 24.263479] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 4.19.27-v8+ #1
[ 24.269848] Hardware name: Raspberry Pi 3 Model B (DT)
[ 24.275000] Call trace:
[ 24.277470] dump_backtrace+0x0/0x190
[ 24.281148] show_stack+0x24/0x30
[ 24.284480] dump_stack+0x9c/0xd4
[ 24.287808] panic+0x12c/0x28c
[ 24.290878] mount_block_root+0x1b0/0x294
[ 24.294902] mount_root+0x148/0x17c
[ 24.298406] prepare_namespace+0x174/0x1bc
[ 24.302517] kernel_init_freeable+0x370/0x390
[ 24.306889] kernel_init+0x18/0x110
[ 24.310390] ret_from_fork+0x10/0x1c
[ 24.313991] SMP: stopping secondary CPUs
[ 24.317933] Kernel Offset: disabled
[ 24.321434] CPU features: 0x0,24802004
[ 24.325192] Memory Limit: none
[ 24.328274] ---[ end Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(179,2) ]---
Here are the steps I did to compile the 4.19.y kernel (natively on a 64-bit little-endian pi):
- make bcmrpi3_defconfig
- make nconfig
in "Kernel Features" I clicked on
- make -j4 Image V=1
- make -j4 modules V=1
- make -j4 dtbs V=1
- make modules_install
- make dtbs_install
All the above steps completed without problems.
As next I copied arch/arm64/boot/Image and the bcm2710-rpi-3-b.dtb files to the usual place into /boot/.
Then powering on the pi resulted in nothing (blank screen), i.e. the green LED blinked the pattern
___|_|_|_|____|_|_|_|___ ...
which I interpreted as the standard bootloader not understanding what to do with "kernel8.img".
To continue I renamed kernel8.img into kernel8_be.img, bcm2710-rpi-3-b.dtb into bcm2710-rpi-3-b_be.dtb, copied u-boot.img into kernel8.img and powered the pi on again, booted the big-endian kernel manually and then the logs above appeared onto remote kermit-connected UART console.
As a note, to verify raspberry-pi's big-endian support I updated few bzt's bare-metal tutorial examples into big-endian and they all work fine, so the kernel panic above at first sight seems to be only due to some firmware blob or whatever which either cannot be found or is not compatible. Unfortunately if I disable firmware support in 'make nconfig', then the kernel doesn't even get that far, the above log file doesn't show anything after "Starting kernel ...".
It is true that arm big-endian support in linux kernel and gcc is quite solid, and even on raspberry pi we get all the cores up and running, but it looks like there are few minor issues which are hardly raspberry or broadcom closed-source-related:
- The standard bootloader refuses to load kernel8.img if it appears to be big-endian linux kernel (its apparently no problem to load a big-endian bare-metal binary). According to "linux/Documentation/arm64/booting.txt" the big-endian kernel image I tried has this header:
code0 = 0xFFFFC000
code1 = 0x00000000
text_offset = 0x0000000000080000
image_size = 0xFFFFFFFFFFFF8000
flags = 0x000000000000000B
res2 = 0x0000000000000000
res3 = 0x0000000000000000
res4 = 0x0000000000000000
magic = 0x644D5241
res5 = 0x00000000
Is this correct?
- The firmware dependencies: how to get rid of them? For the curious it is enough to run linux in a minimalistic mode, only supporting hardware having open-sourced drivers (mmc, ethernet, etc. etc.). Its no problem not to have proprietary hardware accelerated OpenGL or H264 codec or whatever support. Even without a framebuffer (i.e. working over ethernet or UART-connected console) the pi is a great platform.
Is there any obvious method to complete the boot above?
