Abuzar
i am working on surveillance robot using Rpi 3 b+ need to good algorithm for self navigation
Wed May 08, 2019 7:04 am
i am working on surveillance robot using Rpi 3 b+ need to good algorithm for self navigation with a particular set of coordinates from GPS module.
It supposed to do the surveillance on its own after receiving the the set of coordinates.
Please suggest me a good algorithm to do task. Thank in advance
Joel_Mckay
Re: i am working on surveillance robot using Rpi 3 b+ need to good algorithm for self navigation
Sun May 12, 2019 2:19 am
Have a look at ROS or MRPT.
You will need to be more specific about the platform, as guidance and navigation are separate classes of problems.
Cheers.
J
LTolledo
Sun May 12, 2019 2:53 am
Do you "need":
1. a guide to make the the algorithm?
2. a full running algorithm ( as in served in a silver platter)?
Some people be like:
PhatFil
Sun May 12, 2019 3:00 am
kiss when forward path is obscured turn right.
ElEscalador
Sun May 12, 2019 3:56 am
Look up A*? Or go with ROS and try gmapping or hector...not really enough info and likely gps alone will not be adequate. There is so much error in sensors that typically a bunch are used and the data fused and vetted. indoor? Outdoor?
Robotics tips, hacks, book extras https://youtube.com/practicalrobotics
LTolledo
Sat May 18, 2019 10:54 am
.... topic on watch list.... possible spam-bot generated content....
Return to “Advanced users”
