Everything works fine until mysql setup.
sudo apt install mysql-server php-mysql [works]
then
sudo mysql --user=root
everything go's to hell from here.
DROP USER 'root'@'localhost';
CREATE USER 'root'@'localhost' IDENTIFIED BY 'mypassword';
GRANT ALL PRIVILEGES ON *.* TO 'root'@'localhost'
So anyone have to actual correct way of doing this, because every tutorial i can find is exactingly the same
Re: setting up a lamp is now a nightmare
sudo mysql
GRANT ALL PRIVILEGES ON *.* TO 'admin'@'localhost' IDENTIFIED BY 'mypassword';
mysql -u root -p
mysql -u admin -p
GRANT ALL PRIVILEGES ON *.* TO 'root'@'localhost' IDENTIFIED BY 'mypassword';
GRANT ALL PRIVILEGES ON *.* TO 'root'@'localhost' IDENTIFIED with unix_socket;
Later MariaDB versions will support an "ALTER USER" statement to modify the authentication plugin.
thank you, although still would not let me grant privileges, I was able to install phpmyadmin and took it from there.
Now it is a mess again. I give up with mariondb Simply cannot get it to work on Raspi stretch
The latest LAMP version behaviour has changed with respect to the root user. Did you try my tutorial which I've just rewritten for the latest Stretch and incorporated some comments/fixes from fbe?
viewtopic.php?f=29&t=218354#p1460237 (also see earlier posts on that thread)
Brilliant thank you:) My eyes were starting to bleed.
I spoke to soon, after getting back to it today, I find I have no permissions to do anything.
Sorry, forgot the "grant option" privilege when creating a superuser.
pi@headless-pi:~ $ sudo mysql
Welcome to the MariaDB monitor. Commands end with ; or \g.
Your MariaDB connection id is 2
Server version: 10.1.38-MariaDB-0+deb9u1 Raspbian 9.0
Copyright (c) 2000, 2018, Oracle, MariaDB Corporation Ab and others.
Type 'help;' or '\h' for help. Type '\c' to clear the current input statement.
MariaDB [(none)]> grant all privileges on *.* to 'admin'@'localhost' identified by 'secret' with grant option;
Query OK, 0 rows affected (0.00 sec)
MariaDB [(none)]> exit;
Bye
pi@headless-pi:~ $ mysql -uadmin -p
Enter password:
Your MariaDB connection id is 3
MariaDB [(none)]> grant all privileges on *.* to 'admin2'@'localhost' identified by 'secret' with grant option;
MariaDB [(none)]>
