Minecraft 1.12.2 + Optfine has sound.
Minecraft 1.12.2 + Forge does not have any sound. I have no idea how to fix it.
Tutorial on my website:
https://html.dynu.net/index.php/how-to- ... on-1-12-2/
Requirements:
Raspberry Pi 2B, 3B or 3A+
Update of OS and preparation for installation:
Update your Raspbian operating system to the latest version.
sudo apt-get install update && sudo apt-get upgrade -y
Disable splashscreen, set GPU memory to 100 MB and if you are using a Raspberry Pi 2B, overclock to 1000 mhz (High).
Save the settings.
Open a new terminal window.
sudo raspi-config
Reboot.
Testing to see if drivers are active:
Open a terminal window:
sudo apt-get -y install libalut0 libalut-dev && sudo apt-get -y install mesa-utils
glxgears
Glxgears should run around 60 fps. If you are getting hugely different values, try re-enabling the GL driver or test with the full KMS driver.
Downloading and installation of Minecraft:
Download:
mkdir ~/Minecraft; mkdir ~/Minecraft/Natives; cd ~/Minecraft && wget https://s3.amazonaws.com/Minecraft.Download/launcher/Minecraft.jar
cd ~/Minecraft && java -jar Minecraft.jar
Click ‘Edit profile’ and select the ‘1.12.2’ release.
Click save, and then play.
The game will output an error and crash. This is completely normal. Exit the launcher.
Downloading libraries:
cd ~/Minecraft/Natives && wget https://www.dropbox.com/s/4oxcvz3ky7a3x6f/liblwjgl.so && wget https://www.dropbox.com/s/m0r8e01jg2og36z/libopenal.so
cd ~/.minecraft/libraries/org/lwjgl/lwjgl/lwjgl/2.9.4-nightly-20150209 && rm lwjgl-2.9.4-nightly-20150209.jar; wget https://www.dropbox.com/s/mj15sz3bub4dmr6/lwjgl-2.9.4-nightly-20150209.jar
Download Forge 14.23.4.2713 installer (This Forge version is specific, some versions don’t work): https://files.minecraftforge.net/
Download Optifine HD_U_C5(Same as Forge, only certain versions work.):
cd ~/Downloads && wget https://www.dropbox.com/s/0mjy5btnyr7v75g/OptiFine_1.12.2_HD_U_C5.jar
cd ~/Minecraft/ && wget https://www.dropbox.com/s/4aj6rr26p0kib0l/runOptifine1_12_2.sh && sudo chmod +x runOptifine1_12_2.sh
Save the file.
Install Optifine.
cd ~/Downloads && java -jar OptiFine_1.12.2_HD_U_C5.jar
To install Forge, skip to “Installing Forge” otherwise stay here if you want to only play Minecraft with Optifine (no other mods).
Run the runOptifine1_12_2.sh script:
cd ~/Minecraft && ./runOptifine1_12_2.sh
Installing Forge(Optional):
Once again. Minecraft with Forge on Raspberry Pi does not output any sound.
Run the Forge Installer:
cd ~/Downloads/ && java -jar forge-1.12.2-14.23.4.2713-installer.jar
Reopen the Minecraft launcher:
Download the Forge script:
cd ~/Minecraft/ && wget https://www.dropbox.com/s/eefleliwpyuwqk3/runForge1.12.sh && chmod +x runForge1.12.sh
Save.
Run Forge.
cd ~/Minecraft/ && ./runForge1.12.sh
Hope you successfully installed Minecraft.
