I have been working on a project where I'm collecting data from the AD8232 ECG sensor in my raspberry pi 3. As it is an analog sensor I am using MCP3008 as an ADC converter. My problem is I am not getting proper ECG signal shape. I understand the ECG signal is noisy and I need to filter it for further analysis. But the raw ECG signal is not like an ECG signal at all. I was wondering to generate a 200Hz ECG signal what should my SPI speed? I'm using spidev. I checked with SPI speed from 2000hz to 20MHz but got the similar distorted signal. In my code, I set the sampling frequency 200Hz. Can anyone help me with possible issues and fixes?
Thanks,
Row
SPI speed and ADC sampling rate
- Attachments
- image (1).png (157.8 KiB) Viewed 942 times
- mikronauts
- Contact: Website
Re: SPI speed and ADC sampling rate
You need to post your code so we can see what you are doing. Use code tags so the indentation is not lost.
Most likely causes:
- you are not sampling at precise intervals
- you are not reading the voltage correctly
(sensor output range vs adc input range)
- your voltage reference is not stable
Most likely causes:
rmunny wrote: ↑Fri May 03, 2019 9:15 amHello,
Thanks,
Row
http://Mikronauts.com - home of EZasPi, RoboPi, Pi Rtc Dio and Pi Jumper @Mikronauts on Twitter
Advanced Robotics, I/O expansion and prototyping boards for the Raspberry Pi
Thanks a lot for your response. Here is my data acquisition code portion:
Following is part of my main code (In the main I have other codes like filtering, plotting and storing the data in files here I am only adding related code with data acquisition):
Please let me know what you think.
from spidev import SpiDev
from time import sleep
#Create SPI
spi = 0
def init_spi():
spi = SpiDev()
spi.open(0, 0)
spi.max_speed_hz = 1300000 #1350000
return spi
def read_adc(adc_num, num_samples=500, sample_freq=500): #I am actually setting 200Hz sampling rate
spi= init_spi()
data = []
t = 1.0/sample_freq
# read SPI data from the MCP3008
if adc_num > 7 or adc_num < 0:
return -1
while (num_samples):
r = spi.xfer2([1, 8 + adc_num << 4, 0])
data.append(((r[1] & 3) << 8) + r[2])
sleep(t)
num_samples = num_samples - 1
return data
sample_freq = 200
num_samples = 2000
if __name__ == "__main__":
while ( count < how_many_times):
raw_data = read_adc(adc_num=0, num_samples=num_samples, sample_freq=sample_freq)
save_data(raw_data, "raw_data.txt")
- mikronauts
- Contact: Website
You are most welcome.
Python is an interpreted language, with garbage collection, and not well suited to regular, precisely timed sampling.
Writing your app in C would make the timing more predictable.
You can improve your python code somewhat by:
- use an integer array (not list) for storing the samples, see
https://docs.python.org/3/library/array.html
- figure out how long the sampling code takes in microseconds, and subtracting from your timing delay, or use a timed intertupt instead
rmunny wrote: ↑Sun May 05, 2019 12:39 amThanks a lot for your response. Here is my data acquisition code portion:Following is part of my main code (In the main I have other codes like filtering, plotting and storing the data in files here I am only adding related code with data acquisition):Code: Select all
from spidev import SpiDev from time import sleep #Create SPI spi = 0 def init_spi(): spi = SpiDev() spi.open(0, 0) spi.max_speed_hz = 1300000 #1350000 return spi def read_adc(adc_num, num_samples=500, sample_freq=500): #I am actually setting 200Hz sampling rate spi= init_spi() data = [] t = 1.0/sample_freq # read SPI data from the MCP3008 if adc_num > 7 or adc_num < 0: return -1 while (num_samples): r = spi.xfer2([1, 8 + adc_num << 4, 0]) data.append(((r[1] & 3) << 8) + r[2]) sleep(t) num_samples = num_samples - 1 return data
Please let me know what you think.Code: Select all
sample_freq = 200 num_samples = 2000 if __name__ == "__main__": while ( count < how_many_times): raw_data = read_adc(adc_num=0, num_samples=num_samples, sample_freq=sample_freq) save_data(raw_data, "raw_data.txt")
