I had no luck building with qmake, eventually I got it built using cmake. Sort of the usual way, cd into where it is, mkdir build, cd build, but then
cmake ../ -DRTLSDR=ON -DRTLTCP=ON -DINSTALL_UDEV_RULES=ON -DDETACH_KERNEL_DRIVER=ON
But I can't find any signals, maybe there aren't any here. This is listening on VHF frequencies, there's something similar in use on HF/shortwave. https://en.wikipedia.org/wiki/Digital_Radio_Mondiale It sounds like a buzz saw if you run across it. I have gotten those to decode, several years ago. VHF (~170 - 200 MHz) is going to be very local, like 100 miles or so. Here in the US it's well, weird. https://en.wikipedia.org/wiki/Digital_radio Elsewhere it may well work, but searching this forum for qt-dab turned up nothing, plus it's not in the debs. The panel probably isn't supposed to say TextLabel on it, somebody goofed.
If you get it running (make and make install) it puts a ~/.qt-dab.ini file in your home directory, that holds the settings of the GUI widgets on the front panel.
