castalla
Rpi-update
Thu Aug 09, 2012 11:59 am
Can somebody explain when and why it's appropriate to run rpi-update?
dom
Re: Rpi-update
Thu Aug 09, 2012 12:34 pm
rpi-update gets you the latest experimental firmware. It is usually fine, but occasionally may have regressions.
You should run rpi-update regularly if you want to help with testing, and are happy to encounter bugs and submit bug reports.
You might want want to run rpi-udpate if you are having a specific issue that a forum post, or commit messages on guithub suggests has been recently fixed.
The changes from rpi-updates will appear with an apt-get update eventually, if there are no reports of regressions from the rpi-update testers. Most users should just use this.
Montala
Re: Rpi-update
Thu Aug 09, 2012 12:38 pm
Thanks 'dom' but could I just clarify one point please... if I run rpi-update, is there any point in 'running' apt-get update and apt-get upgrade afterwards, or will rpi-upgrade already have downloaded and installed all the latest updates etc for me?
Thanks! :)
dom
Re: Rpi-update
Thu Aug 09, 2012 12:43 pm
Montala wrote:Thanks 'dom' but could I just clarify one point please... if I run rpi-update, is there any point in 'running' apt-get update and apt-get upgrade afterwards, or will rpi-upgrade already have downloaded and installed all the latest updates etc for me?
Thanks! :)
"apt-get upgrade" is a standard linux command that updates your debian distribution. So if there are bug fixes in software packages that have been installed with "apt-get install" (or any of the initially installed packages), this will update them.
rpi-update only updates the raspberry pi specific files ("the firmware", or files in /boot, /opt/vc, and /lib/modules).
So if you want the very latest of everything, you run both rpi-update and apt-get update && apt-get upgrade.
Montala
Re: Rpi-update
Thu Aug 09, 2012 12:48 pm
Thank you for such a prompt and helpful reply.
I had in fact being doing exactly that, but I just wanted to make sure that I wasn't duplicating anything.
castalla
Re: Rpi-update
Thu Aug 09, 2012 12:54 pm
Very useful - thanks.
ComputerJock
Re: Rpi-update
Fri Aug 10, 2012 2:44 am
dom wrote:rpi-update gets you the latest experimental firmware. It is usually fine, but occasionally may have regressions.
I've just done the rpi-update and have sound issues. aplay will no longer play sound -- or at least I can't hear it. amixer/alsamixer terminate with errors. hello_audio does work tho.
So, for a complete beginner, where should this error be reported. You mentioned "gethub". Can you provide a url? Thank you.
ComputerJock
Re: Rpi-update
Fri Aug 10, 2012 3:26 am
ComputerJock wrote: I've just done the rpi-update and have sound issues. aplay will no longer play sound -- or at least I can't hear it. amixer/alsamixer terminate with errors. hello_audio does work tho.
Update: Very sorry... False alarm... I finally figured out that I had to do alsamixer -c 0 and I discovered that it was set to mute after my rpi-update. Apologies to all.
KingToAD
Re: Rpi-update
Sun Aug 12, 2012 7:57 pm
hi, I'm new to all this but I have the original raspbian image on my sd card. By using the update and upgrade commands will this update it to the new image (july's one) or do i need to format the sd card and start again?
Return to “Beginners”
Who is online
Users browsing this forum: nosoup and 38 guests
