2bdkid
Boot hang after "random: crng init done"
Sun Mar 25, 2018 11:51 pm
I pulled branch rpi-4.9.y from www.github.com/raspberrypi/linux and cross compiled the bcmrpi3 target for arm64. I copied over the kernel and *.dtb files into the boot directory. I also copied bootcode.bin, *.dat, and *.elf from www.github.com/raspberrypi/firmware into /boot. When the system boots, it stops at "random: crng init done" and will not continue. I found some other articles saying it was a power issue or sd card issue, but I built the system on a second sd card and had the same results. I'm thinking it's a kernel issue so would anyone know which kernel to try next?
2bdkid
Re: Boot hang after "random: crng init done"
Wed Mar 28, 2018 3:29 am
Solution: press enter and the prompt appears.
Can't believe it took me this long...
tkninja
Thu Apr 05, 2018 9:07 pm
By the way, this happens to me, too. You don't have to press Enter to get the prompt, however: just enter in a command, if Raspian automatically logs you in.
SoNic67
Thu May 17, 2018 11:27 am
In my case, pressing enter key or any command does nothing. It just moves the text on the screen one line up.
Roken
Thu May 17, 2018 7:38 pm
I was getting this when experimenting with NFS boot - and it usually meant that the system couldn't find rootfs.
Check cmdline.txt
Headless PI. OMG, someone cut it's head off. Oh, hang on. it didn't have one to start with.
doomkin
Fri Aug 10, 2018 12:48 am
At boot, the kernel waits for mouse movements to initialize the random number generator.
Kernel messages on boot:
sudo dmesg | less
The problem:
kernel: random: crng init done
The solution:
sudo apt install haveged
sudo systemctl enable haveged
nana199685
Fri Dec 14, 2018 11:55 am
sudo dmesg | less
The problem:
The solution:
i meet the same problem that the screen stop at "random: crng init done"
i did modify my cmdline.txt before i reboot
but now i can't type any command you mentioned.
when i type something and press enter
it just wraps and happen nothing
i have check my power that was normal
please help me.QQ
PhilE
Fri Dec 14, 2018 2:08 pm
The fact that the message says "crng init done" suggests the fault is with something else it is trying to start afterwards. Try with "initcall_debug=1" on in cmdline.txt, and then see what the last few messages say.
You say:
Can you remember what you changed, and have you tried changing it back?
Tmpod
Thu Dec 27, 2018 10:32 am
I have the exact same problem. I'm using raspbian lite and I started getting a kernal panic saying that it could not mount root fs onto
unknown-block(179, 2)
. After some searching I found a stackoverflow post that suggested changing something in the cmdline.txt file. So I did. And now I'm getting this. I've tried setting
initcall_debug=1
and no more messages seem to appear. The boot still hangs on
crng init done
. Here's cmdfile.txt copied and pasted
dwc_otg.lpm_enable=0 console=serial0,115200 console=tty1 root=PARTUUID=27504eef-06 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait initcall_debug=1
(what u changed was that last 06 digit at the end of the root part, that was previously 02)
Thanks in advance
PhilE
Sun Dec 30, 2018 6:54 pm
Try using the old method for specifying a root fs, i.e. the name of the block device on which it appears:
... root=/dev/mmcblk0p2 ...
To get more debug output you probably also need to add something like "loglevel=8'.
rin67630
Tue Jan 08, 2019 4:13 pm
/quote]
Ugh! that seem a valid explanation: I am running headless and HAVE NO MOUSE NOR KEYBOARD.
Pluging a mouse releases the boot process. But that is'nt the purpose of a headless machine!
Installing haveged works!
terwik231
Fri Mar 29, 2019 4:10 pm
I have the same issue, how do you edit that cmdline.txt file? I can`t leave boot screen
Fri Mar 29, 2019 6:03 pm
You can edit cmdline.txt with your SDCard or USB device inserted into a Windows machine. Just DO NOT accept any requests where Windows will try to help you to reformat the drive - just say "NO!".
Note: Having anything remotely humorous in your signature is completely banned on this forum. Wear a tinfoil hat and you'll get a ban.
This is a doctor free zone.
Ty13r
Sat Apr 20, 2019 4:53 pm
Hello world,
i have the same trouble trying installing Kally on my PI 3 B+.
I change my cmdline.txt like this :
i use this img "kali-linux-2019.1-rpi3-nexmon-64" flashing buy "balenaEtcher" after being format by SD Card formatter.
My Sd card is : scanDisk Ultra 16GB micro SD HC1
I tryed to press enter / move my moose / nothing happened. I don't find anything working on internet.
Tks !
Return to “Linux Kernel”
