sdastari
Raspbian source code image
Tue Apr 16, 2019 3:27 pm
Hey, I am trying to add my custom audio filters to the raspbian source code image. But I am unable to find the entire raspbian source code image. Is there a way to install entire raspbian source code or should I install it as kernel and packages. Please help me in getting the source files in either ways. Thank you in advance.
k-pi
Re: Raspbian source code image
Tue Apr 16, 2019 5:45 pm
Raspbian is based on Debian - if you want source code, I'd suggest looking on their web site, (under ARM), you may find what you are looking for - else, can you explain in more detail what code exactly you are looking for. 8-)
Tue Apr 16, 2019 6:24 pm
https://github.com/raspberrypi
davesteele
Tue Apr 16, 2019 6:51 pm
I believe that you are asking "How can I package my software for inclusion with the Raspbian repository".
The answer is to submit it (https://wiki.debian.org/Packaging) to Debian. For the most part, Raspbian packages flow from that.
sdastari
Wed Apr 17, 2019 5:18 pm
Thank you all for replying. I found my required files in the kernel. Thanks again. :)
Return to “Raspberry Pi OS”
