berry25
AV Connector oxidized
Mon May 18, 2015 4:41 pm
Hello all,
My raspberry bought in 2015..
Audio/Video connector oxidized :(
Anyone have same problem?
Re: Connector oxidized
Mon May 18, 2015 5:18 pm
Mine is quite a bit older, but looks similar
I'm not bothered. I either run it headless or with HDMI.
solar3000
Mon May 18, 2015 5:45 pm
looks like a QC issue.
Can you scrape the contacts inside?
like with a Dremel bit?
Antikythera
spock
Fri Apr 05, 2019 4:14 pm
i have the same problem on all of my raspberry pi 3bs. :( seems to only take 1 year or so.
Notupus
Re: AV Connector oxidized
Fri Apr 05, 2019 7:21 pm
All my pies have this connector corroded but my 3b+ just ain't having it. They are corroded that much that they fail.
mrreality13
Sat Apr 06, 2019 12:14 am
also try DeoxIT 5% Spray Contact Cleaner,i use it to clean vintage stereos from 60/70's
https://www.amazon.com/Hosa-D5S-6-DeoxI ... B00006LVEU
remember ,never approach a computer thinking this will only take a minute
~~pi zero w and a 3b+
Milliways
Sat Apr 06, 2019 3:52 am
It isn't "corrosion" it is oxidation of the cadmium plating, and is quite normal (and harmless).
If you use it it should work, but attempting to "clean" is likely to do more harm than good.
spock
Sat Apr 06, 2019 10:12 am
cadmium plating? :shock: :)
andrum99
Sat Apr 06, 2019 5:56 pm
Corrosion *is* oxidation. And after some googling, I'm rather surprised to find that it is still legal to use cadmium in electronic products, as long as it is below 0.01% or 100ppm by weight. Cadmium is certainly *not* harmless.
Burngate
Sat Apr 06, 2019 6:22 pm
For some reason, I thought it was silver rather than cadmium.
Milliways
Sat Apr 06, 2019 11:33 pm
On reflection, it probably is - the fact remains the discolouration (which is common) does not seem to affect performance, and does not warrant drastic removal action. Simply inserting and removing a plug should be sufficient.
andrum99
Mon Apr 08, 2019 7:58 am
I'm hoping it is silver. I don't know what cadmium oxidation looks like, but it does look like silver tarnishing. I'm going to go with silver :D
Imperf3kt
Mon Apr 08, 2019 8:53 am
I believe, like the other ports on the Pi, it is just steel.
55:55:44:44:4C
52:4C:52:42:41
Mon Apr 08, 2019 8:56 am
If it were regular steel it would rust. It for sure is not stainless steel.
It may well be steel but plated with something. And what that is is the question here.
Burngate
Mon Apr 08, 2019 9:30 am
Probably spring steel coated with silver.
When I was in OBs, we had a rather large number of ¼" jacks - 19" racks full of them.
As you can imagine, the first week in June on the Epsom Downs is not famous for its weather, and anything that could corrode would.
The jack plugs were I believe brass which got cleaned with wire wool. The sockets were cleaned with a plug-shaped device that was mildly abrasive.
