default_user8
Re: I need somebody to check if these parts are compatible.
Fri Mar 29, 2019 11:52 pm
You're joking right?
Two heads are better than one, unless one's a goat head.
W. H. Heydt
Sat Mar 30, 2019 2:09 am
Well... The display claims to be for--among others--the Pi0. Yes, you'll need so solder in a 2x20 0.1" header to connect the two. Or you can buy a Pi0WH and the headers will already be soldered on the board.
Imperf3kt
Contact: Twitter
Sat Mar 30, 2019 3:36 am
As ridiculously inane as it is for those of use who know, it's not so much so for those who don't.
As such, no, I do not believe they're joking.
My stepfather, for instance, still has trouble knowing whether he can charge his mobile phone with its supplied usb cable, in certain usb ports, no matter how many times I tell him the "u" is short for "universal"
55:55:44:44:4C
52:4C:52:42:41
default_user8
Sat Mar 30, 2019 4:29 am
I'm not trying to be insensitive to anyone's request, however this one seems a little to easy for anyone to figure out. Since the first link is for a pi zero, the second link is for a lcd that the ad states is for a pi zero and shows the screen attached to a pi zero, and the third link is for a GPIO header that the ad states is for a pi zero. So yes i would say these parts are compatible.
Gavinmc42
Sat Mar 30, 2019 10:24 am
Well it is his/her first post.
Mind you Zero's are not the best place to start in Pi world.
And the answer to the question is "yes"
I'm dancing on Rainbows.
noobtopiworld
Sat Mar 30, 2019 4:39 pm
Just wanted to be sure.
default_user8
Sat Mar 30, 2019 9:33 pm
No problem, sorry if i came off as a jackass, don't let that deter you from seeking advice here on this forum. I really don't mind helping people since I've received so much help here I try to give back. Good luck and have fun with your project!
