Hi all
I am a newbie to openmax programming and i downloaded some openmax sample code here:https://github.com/popcornmix/omxplayer and i found that openmax video always keep topmost and covers all x windows on my platform. Is there anyway to render openmax video to an x window?
I checked that there is one flag called OMX_DISPLAY_SET_LAYER and tried to set it to 0, still no luck , x window still being coverred, what does this flag mean?
thanks
- Raspberry Pi Engineer & Forum Moderator
- Location: ZZ9 Plural Z Alpha, aka just outside Cambridge.
Re: OpenMax video covers all X window and keeps topmost
OMX video_render has no concept of X, it just applies an overlay to be composed by the hardware (the pixels don't get written to the framebuffer).
Conversely X has no concept of overlays, therefore composition into an X window on the RGBX framebuffer is a hugely processor intensive operation (format conversion, resize, and blit), and is one of the reasons that so much work has gone into making things like Chromium and VLC perform vaguely reasonably.
OMX_DISPLAY_SET_LAYER does what it says in setting the layer, however you need to appreciate that the framebuffer is on layer -127. You can alter that with a mailbox call, but without alpha being enabled, and something sane in the aplha plane of the framebuffer, it isn't going to help.
You probably want to look at OMX_DISPLAY_SET_DEST_RECT and set dest_rect in your OMX_CONFIG_DISPLAYREGIONTYPE, and also set OMX_DISPLAY_SET_FULLSCREEN and clear fullscreen. You can then move the overlay whereever you want on the screen.
Thanks for your reply! by setting OMX_DISPLAY_SET_DEST_RECT, the video is rendered to part of the screen but it does not solve the issue that the video will cover the x window under it even if i have clicked the x window under it. Is there anyway to solve this?6by9 wrote: ↑Fri Mar 29, 2019 9:39 amOMX video_render has no concept of X, it just applies an overlay to be composed by the hardware (the pixels don't get written to the framebuffer).
Not using video_render. You are not rendering into the window, you are adding an overlay on top of the frame buffer.kingbox1 wrote: ↑Fri Mar 29, 2019 9:51 amThanks for your reply! by setting OMX_DISPLAY_SET_DEST_RECT, the video is rendered to part of the screen but it does not solve the issue that the video will cover the x window under it even if i have clicked the x window under it. Is there anyway to solve this?
You can pull the pixels back to the ARM and blit them actually into the window surface, but as I have said that is CPU and memory bandwidth intensive.
You haven't said what content you're presenting to video_render, but you could look at the Raspbian patches to Chromium or VLC which resize video decode data to exactly the right size for X to "simply" have to do a blit into the appropriate buffer. With a moderately sized window you are still taking a fair hit with the blit. Those patches are using MMAL instead of IL as it is the better supported API and has various features that allow for better performance.
There are rendering paths available via OpenGL to render external content into the frame buffer, but even there there are significant overheads.
Thanks for your patient explanation. I am presenting a decoded h264 stream to video_render. You are mentioning that framebuffer is of layer -127. Can you explain a little bit here about this concept layer? or you can point me some material that i can learn myself, I googled a lot using keywords"framebuffer -127", but i did not find much information about this.6by9 wrote: ↑Fri Mar 29, 2019 10:03 amNot using video_render. You are not rendering into the window, you are adding an overlay on top of the frame buffer.kingbox1 wrote: ↑Fri Mar 29, 2019 9:51 amThanks for your reply! by setting OMX_DISPLAY_SET_DEST_RECT, the video is rendered to part of the screen but it does not solve the issue that the video will cover the x window under it even if i have clicked the x window under it. Is there anyway to solve this?
Imagine layers of graphics in the same way as layers of sheet of paper. The sheet at the bottom is layer -127, the piece of paper above that is -126 etc. Now imagine those sheets of paper are offset from each other, or have areas cut out of them to you can see bits fo the images on the sheets below.. This is sort of how the compositor works. See https://en.wikipedia.org/wiki/Layers_(d ... e_editing) and https://en.wikipedia.org/wiki/Alpha_compositingkingbox1 wrote: ↑Wed Apr 03, 2019 7:40 amThanks for your patient explanation. I am presenting a decoded h264 stream to video_render. You are mentioning that framebuffer is of layer -127. Can you explain a little bit here about this concept layer? or you can point me some material that i can learn myself, I googled a lot using keywords"framebuffer -127", but i did not find much information about this.6by9 wrote: ↑Fri Mar 29, 2019 10:03 amNot using video_render. You are not rendering into the window, you are adding an overlay on top of the frame buffer.kingbox1 wrote: ↑Fri Mar 29, 2019 9:51 amThanks for your reply! by setting OMX_DISPLAY_SET_DEST_RECT, the video is rendered to part of the screen but it does not solve the issue that the video will cover the x window under it even if i have clicked the x window under it. Is there anyway to solve this?
Yeah, i can understand that layer with higher number appears on top of layer with smaller number. I mean i did not find any material saying that framebuffer's layer number is -127 and i did not find material saying that GPU is presenting the image by compoisting different layersjamesh wrote: ↑Wed Apr 03, 2019 8:45 amImagine layers of graphics in the same way as layers of sheet of paper. The sheet at the bottom is layer -127, the piece of paper above that is -126 etc. Now imagine those sheets of paper are offset from each other, or have areas cut out of them to you can see bits fo the images on the sheets below.. This is sort of how the compositor works. See https://en.wikipedia.org/wiki/Layers_(d ... e_editing) and https://en.wikipedia.org/wiki/Alpha_compositingkingbox1 wrote: ↑Wed Apr 03, 2019 7:40 amThanks for your patient explanation. I am presenting a decoded h264 stream to video_render. You are mentioning that framebuffer is of layer -127. Can you explain a little bit here about this concept layer? or you can point me some material that i can learn myself, I googled a lot using keywords"framebuffer -127", but i did not find much information about this.6by9 wrote: ↑Fri Mar 29, 2019 10:03 am
Not sure there is any specific documenation about that.kingbox1 wrote: ↑Wed Apr 03, 2019 8:52 amYeah, i can understand that layer with higher number appears on top of layer with smaller number. I mean i did not find any material saying that framebuffer's layer number is -127 and i did not find material saying that GPU is presenting the image by compoisting different layersjamesh wrote: ↑Wed Apr 03, 2019 8:45 amImagine layers of graphics in the same way as layers of sheet of paper. The sheet at the bottom is layer -127, the piece of paper above that is -126 etc. Now imagine those sheets of paper are offset from each other, or have areas cut out of them to you can see bits fo the images on the sheets below.. This is sort of how the compositor works. See https://en.wikipedia.org/wiki/Layers_(d ... e_editing) and https://en.wikipedia.org/wiki/Alpha_compositingkingbox1 wrote: ↑Wed Apr 03, 2019 7:40 am
The framebuffer is given the lowest layer, which is -127.
Most GPU's use compositing, in our case the VC4 does real time compositing of multiple bitmaps directly to the output devices all in hardware. Note that in usual linux use that feature is not used, as X by default does all its rendering in sotware. However OMXplayer or the camera apps preview will use the HW compositor as it provides by far the fastest way of getting the image on the display.
Using the beta graphics driver will make better use of the GPU compositor.
Hi jamesjamesh wrote: ↑Wed Apr 03, 2019 9:38 amNot sure there is any specific documenation about that.kingbox1 wrote: ↑Wed Apr 03, 2019 8:52 amYeah, i can understand that layer with higher number appears on top of layer with smaller number. I mean i did not find any material saying that framebuffer's layer number is -127 and i did not find material saying that GPU is presenting the image by compoisting different layersjamesh wrote: ↑Wed Apr 03, 2019 8:45 am
Recently, we got our new pi4 installed with buster image and i found something about graphics is different from what it was on pi3.
Previously, when I play video using openmax on pi3, I noticed that the cursor will be covered by the video. which means that the cursor GPU render layer is lower then openmax video which you explained to me before, however, I noticed that on pi4, the cursor will not be covered by openmax video. So the cursor layer is changed on pi4? Is there anyting else different about graphics on pi4?
thanks
The cursor is now on its own HW layer (in fact, I did do a HW accelerated cursor some years ago that was never merged which had the same effect).kingbox1 wrote: ↑Mon Jul 22, 2019 6:52 amHi jamesjamesh wrote: ↑Wed Apr 03, 2019 9:38 amNot sure there is any specific documenation about that.kingbox1 wrote: ↑Wed Apr 03, 2019 8:52 am
thanks
The graphics on the Pi4 are quite difference - new GPU (VC6), plus lots of work on the FKMS driver, MESA and DRM. However, from an end users point of view, there should be minimal differences.
I experimented with layer <-127 It worked, if the main fb had the alpha channel enabled in config.txt and it was visible via transparent sections in the framebuffer. It was done in Ultibo, but it seems its framebuffer (using standard RPi mailbox interface to create a framebuffer) is also layer #-127The framebuffer is given the lowest layer, which is -127.
(or maybe the fb with alpha enabled is not layerr -127?)
You should be able to find that out if you run `vcgencmd dispmanx_list`. You'll see the various dispmanx parameters used to compose the final video output.
info-beamer hosted - A user and programmer friendly digital signage platform for the Pi: https://info-beamer.com/hosted
