ssh
wpa_supplicant.conf
sudo apt-get update
sudo apt-get upgrade
The following evening i tried to carry on with where I left off, but could not get the Pi to boot. I was getting two quick flashes on the green LED. I plugged the Pi into a monitor and found it was not getting past the rainbow boot screen. I tried the SD card in a Pi Zero v1.3 and got the same issue. I then tried the SD card in. Pi 2 model B v1.1 and it booted fine.
Why does my SD card not work in the older Pi. Does the apt-get upgrade prevent the SD card working in older Pi’s?
Regards,
Keith.
