I set up my Pi to AP mode, and I want to know its wifi speed. Is there an easy way or a script to find out the speed?
thanks
Re: How to test WiFi speed in AP mode?
Best way is to use two machines on the WiFi network and run something like iperf or netstress
This will give you a best possible figure that will go down when you add an application into the mix
Interested to see the result - here the broadband is the limiting device
You asked for speed, this is the answer as seen from a client:
pi@raspi4:~ $ iwconfig
lo no wireless extensions.
wlan0 IEEE 802.11 ESSID:"XXXXXXX"
Mode:Managed Frequency:2.462 GHz Access Point: 74:DA:38:FF:FF:FF
Bit Rate=65 Mb/s Tx-Power=31 dBm
Retry short limit:7 RTS thr:off Fragment thr:off
Power Management:on
Link Quality=44/70 Signal level=-66 dBm
Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0
Tx excessive retries:9044 Invalid misc:0 Missed beacon:0
The road to insanity is paved with static ip addresses
Another performance test is "iperf" which is very simple to use:
sudo apt install iperf
This is a down clocked Pi Zero W
A very quick test is to send large packets with ping:
The Pi Zero W connected over Wifi
ethernet connected Pi Zero
ethernet connected Pi3B+
$ iperf -c piclk
Client connecting to piclk, TCP port 5001
TCP window size: 85.0 KByte (default)
[ 3] local 192.168.0.5 port 52260 connected with 192.168.0.88 port 5001
[ ID] Interval Transfer Bandwidth
[ 3] 0.0-10.7 sec 21.2 MBytes 16.6 Mbits/sec
$ ping -s 65500 -c 4 piclk
PING piclk (192.168.0.88) 65500(65528) bytes of data.
65508 bytes from piclk (192.168.0.88): icmp_seq=1 ttl=64 time=124 ms
65508 bytes from piclk (192.168.0.88): icmp_seq=2 ttl=64 time=66.7 ms
65508 bytes from piclk (192.168.0.88): icmp_seq=3 ttl=64 time=59.8 ms
65508 bytes from piclk (192.168.0.88): icmp_seq=4 ttl=64 time=48.9 ms
--- piclk ping statistics ---
4 packets transmitted, 4 received, 0% packet loss, time 3004ms
rtt min/avg/max/mdev = 48.972/74.982/124.335/29.193 ms
$ ping -s 65500 -c 4 pi0
PING pi0 (192.168.0.112) 65500(65528) bytes of data.
65508 bytes from pi0 (192.168.0.112): icmp_seq=1 ttl=64 time=13.2 ms
65508 bytes from pi0 (192.168.0.112): icmp_seq=2 ttl=64 time=13.2 ms
65508 bytes from pi0 (192.168.0.112): icmp_seq=3 ttl=64 time=13.2 ms
65508 bytes from pi0 (192.168.0.112): icmp_seq=4 ttl=64 time=13.2 ms
--- pi0 ping statistics ---
4 packets transmitted, 4 received, 0% packet loss, time 3003ms
rtt min/avg/max/mdev = 13.212/13.232/13.259/0.083 ms
PING pi (192.168.0.80) 65500(65528) bytes of data.
65508 bytes from pi (192.168.0.80): icmp_seq=1 ttl=64 time=6.07 ms
65508 bytes from pi (192.168.0.80): icmp_seq=2 ttl=64 time=6.04 ms
65508 bytes from pi (192.168.0.80): icmp_seq=3 ttl=64 time=5.58 ms
65508 bytes from pi (192.168.0.80): icmp_seq=4 ttl=64 time=5.58 ms
--- pi ping statistics ---
rtt min/avg/max/mdev = 5.584/5.820/6.072/0.253 ms
