Good day everyone
I have designed a can bus board for my application which i based of the PICAN2 schematics .
The board is inteded to be used with a racecar ECU with a 1Mbs CAN bus
- My configuration is correct , when put the Pican on and configure to 1Mbs
==> Perfect communication
- I also modified a cheap module and replaced the Christal from 8 to 16 Mhz as well as modifiying the power for MCP2515 to a seperate 3.3V
https://www.dx.com/p/mcp2515-can-bus-mo ... GztWugzaMo
- When i plug in my own designed Breakout board i receive nothing
When i change the configuration to 500 kbs and plug in my board into my OBD CAN BUS pins i get perfect communication
Therefore my conclusion its something to do with the board but not the settings .
I must add i tried with termination on and termination off but same result
Here is my Schematic:
https://github.com/BastianGschrey/Power ... apture.PNG
Can someone figure out why my board does not want to work at 1Mbs ?
