pertm84
Memory leak? System "hangs" after some time. (webcamserver)
Mon Mar 04, 2019 11:11 am
Hi
I am quite new to this, but I have managed to set up a raspberry pi using stretch as a webserver for uploading stills to my wunderground account through ftp. UFW, fail2ban, apache etc is all set up and working.
Also, I set the camera to livestream whenever I want. Everything is working, but sometimes the system hangs, and I can't SSH into it. Therefore the only solution is to cut the power and perform a reboot, which makes everything working again.
This is output from top command:
top - 11:57:08 up 7 days, 22:17,  2 users,  load average: 0.43, 0.37, 0.37
Tasks: 148 total,   1 running,  99 sleeping,   0 stopped,   5 zombie
%Cpu(s): 11.1 us,  1.0 sy,  0.0 ni, 87.9 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
KiB Mem :   896672 total,   153296 free,   276868 used,   466508 buff/cache
KiB Swap:   102396 total,   102396 free,        0 used.   514568 avail Mem
I created a script and added to cron for Motion to restart every 30 min (since it is unstable) and also a script for uploading tmp.jpg to my wunderground account every 15min. So Motion is writing jpeg to ram every 15 min, but will this be deleted/overwritten each time? Is this filling up my ram and swap?
I also suspect that the log-files may slow things down, as UFW fills up my log-files with unnecessary lines. I have no idea where to start my fail-search, since I have little experience with linux.
Re: Memory leak? System "hangs" after some time. (webcamserver)
Mon Mar 04, 2019 11:15 am
If you are definitley writing the same file each tim,e then its not using up anything. Same with log files, the size of them should not affect speed.
It might help to get full `top` dumps every 15 minutes or so leading up to the lockup to see if anything is using increasing amounts of memory.
I pressume there is nothing in dmesg giving hints as to why things are going wrong?
pertm84
Mon Mar 04, 2019 11:37 am
Thanks for the quick answer! I'm not quite sure what to look for in dmesg, and everytime I had to do a hard-reset, it looks like the log-files has restarted.What should I look for in dmesg?
Also when I tried to type dmesg, I get:
-bash: dmesg: command not found
I know it must be installed, because when I: sudo apt-get install util-linux
Reading package lists... Done
Building dependency tree
util-linux is already the newest version (2.29.2-1+deb9u1).
0 upgraded, 0 newly installed, 0 to remove and 121 not upgraded.
Also I tried: sudo apt-get install util-linux --reinstall
Then I got:
0 upgraded, 0 newly installed, 1 reinstalled, 0 to remove and 121 not upgraded.
Need to get 895 kB of archives.
After this operation, 0 B of additional disk space will be used.
Get:1 http://raspbian.trivini.no/raspbian stretch/main armhf util-linux armhf 2.29.2-1+deb9u1 [895 kB]
Fetched 895 kB in 2s (307 kB/s)
apt-listchanges: Can't set locale; make sure $LC_* and $LANG are correct!
perl: warning: Setting locale failed.
perl: warning: Please check that your locale settings:
	LANGUAGE = (unset),
	LC_ALL = (unset),
	LC_CTYPE = "UTF-8",
	LANG = (unset)
    are supported and installed on your system.
perl: warning: Falling back to the standard locale ("C").
locale: Cannot set LC_CTYPE to default locale: No such file or directory
locale: Cannot set LC_ALL to default locale: No such file or directory
dpkg: warning: 'tar' not found in PATH or not executable
dpkg: error: 1 expected program not found in PATH or not executable
Note: root's PATH should usually contain /usr/local/sbin, /usr/sbin and /sbin
E: Sub-process /usr/bin/dpkg returned an error code (2)
So I thought I should try to change locale, but it was already setup in raspi-config?
sudo raspi-config
	LANGUAGE = (unset),
	LC_ALL = (unset),
	LC_CTYPE = "UTF-8",
	LANG = (unset)
/usr/bin/locale: Cannot set LC_CTYPE to default locale: No such file or directory
/usr/bin/locale: Cannot set LC_ALL to default locale: No such file or directory
Generating locales (this might take a while)...
  en_US.UTF-8...character map file `UTF-8' not found: No such file or directory
default character map file `ANSI_X3.4-1968' not found: No such file or directory
 done
Generation complete.
	LANGUAGE = (unset),
	LC_ALL = (unset),
	LC_CTYPE = "UTF-8",
	LANG = (unset)
	LANGUAGE = (unset),
	LC_ALL = (unset),
	LC_CTYPE = "UTF-8",
	LANG = (unset)
*** update-locale: Error: invalid locale settings:  LANG=en_US.UTF-8 LC_ALL=en_US.UTF-8 LANGUAGE=en_US.UTF-8
pertm84
Mon Mar 04, 2019 12:17 pm
OK, it seems there is a problem with my locales. I am not able to install the US utf8.
I get:
sudo dpkg-reconfigure locales
	LANGUAGE = "en_US.UTF-8",
	LC_ALL = "en_US.UTF-8",
	LC_CTYPE = "UTF-8",
	LANG = (unset)
locale: Cannot set LC_MESSAGES to default locale: No such file or directory
/usr/bin/locale: Cannot set LC_MESSAGES to default locale: No such file or directory
 done
*** update-locale: Error: invalid locale settings:  LC_ALL=en_US.UTF-8 LANGUAGE=en_US.UTF-8 LANG=en_US.UTF-8
Inside the locale-gen file there is no locale?
#!/bin/sh
set -e
LOCALEGEN=/etc/locale.gen
LOCALES=/usr/share/i18n/locales
USER_LOCALES=/usr/local/share/i18n/locales
if [ -n "$POSIXLY_CORRECT" ]; then
  unset POSIXLY_CORRECT
fi
[ -f $LOCALEGEN ] || exit 0;
[ -s $LOCALEGEN ] || exit 0;
KEEP=
if [ "$1" = '--keep-existing' ]; then
        KEEP=1
fi
if [ -z "$KEEP" ]; then
        # Remove all old locale dir and locale-archive before generating new
        # locale data.
        rm -rf /usr/lib/locale/locale-archive || true
fi
umask 022
is_entry_ok() {
  if [ -n "$locale" -a -n "$charset" ] ; then
    true
  else
    echo "error: Bad entry '$locale $charset'"
    false
  fi
echo "Generating locales (this might take a while)..."
while read locale charset; do \
        case $locale in \#*) continue;; "") continue;; esac; \
        is_entry_ok || continue
        if [ "$KEEP" ] && PERL_BADLANG=0 perl -MPOSIX -e \
            'exit 1 unless setlocale(LC_ALL, $ARGV[0])' "$locale"; then
                continue
        fi
        echo -n "  `echo $locale | sed 's/\([^.\@]*\).*/\1/'`"; \
        echo -n ".$charset"; \
        echo -n `echo $locale | sed 's/\([^\@]*\)\(\@.*\)*/\2/'`; \
        echo -n '...'; \
        if [ -f $USER_LOCALES/$locale ] ; then
            input=$USER_LOCALES/$locale
        elif [ -f $LOCALES/$locale ]; then
            input=$locale
        else
            input=`echo $locale | sed 's/\([^.]*\)[^@]*\(.*\)/\1\2/'`
            if [ -f $USER_LOCALES/$input ]; then
                input=$USER_LOCALES/$input
            fi
        fi
        localedef -i $input -c -f $charset -A /usr/share/locale/locale.alias $locale || :; \
        echo ' done'; \
done < $LOCALEGEN
echo "Generation complete."
Mon Mar 04, 2019 12:33 pm
Very odd that dmesg uis not found - this is installed by default on Raspbian.
You can check /var/log/ssylog* files as an alternative.
pertm84
Mon Mar 04, 2019 1:53 pm
Thanks, I've checked the etc/default/locale:
#  File generated by update-locale
LANG=en_US.UTF-8
# LANGUAGE=en_US.UTF-8
I've also tried all the tips on the internet:
export LC_ALL=en_US.UTF-8
bash: warning: setlocale: LC_ALL: cannot change locale (en_US.UTF-8)
In the syslog, I couldn't see anything particular, some error messages from ddocker, but I've uninstalled that now, maybe that could be what caused it. Now I am all hung up in fixing this locale issue :oops: :roll:
pertm84
Tue Mar 05, 2019 11:44 am
Ok, so I tried looking further into the issue with my hangups, and noticed this using htop:
url to image in case of img fails https://ibb.co/ctV7s3y
So it looks like I have two instances of Motion running? Or am I interpreting the htop wrong?
Tue Mar 05, 2019 12:08 pm
You're interpreting it wrong. I'd guess that pid 7094 spawned pid 7095 to run some subtasks.
This is a doctor free zone.
pertm84
Tue Mar 05, 2019 12:26 pm
Ok, thanks Dougie. At least I can remove that as a probable cause for the hangups ;)
pertm84
Wed Mar 06, 2019 4:14 pm
Ok, so everything worked for 9 days, now I get "Network is unreachable" when I try to SSH into it.
This is driving me nuts, because the raspberry is 515 km away from me. :twisted:
I know the router is working, because I have a wifi smartplug on the same network, which is working.
RaTTuS
Wed Mar 06, 2019 4:25 pm
look at a watchdog timer to reboot your RPI if it goes meh
Covfefe
pertm84
Thu Mar 07, 2019 7:35 am
Thanks for the tip! I am about to give up the Pi though, I think I'll just buy an IP-camera and save a whole-lot-of-work. I'll bring home the Pi and do some research on why it is so unstable, maybe I can find another use for it..
Return to “Camera board”
