ShiftPlusOne
Re: VLC 3.0 with hardware acceleration
Fri Jan 25, 2019 8:50 am
cjan wrote:
Fri Jan 25, 2019 3:29 am
another dependency issue,
ffmpeg update to stretch version not rpt version, just like previous vlc-306 do.
Thanks. On it.
LTolledo
Thu Jan 31, 2019 10:45 am
Just recently updated/upgraded my RPi3B+ (this unit am using to post to this forum)
After the update/upgrade (which included the update for VLC), I accidentally double clicked a 24-minute .mkv file.
....oh what the heck might as well try it... played in window mode.... while I browse the forum....
...then VLC stopped/closed (crashed?) after about 20 minutes......
....re-watched the .mkv file again in Kodi...and will probably continue to watch in Kodi..
...until the next VLC iteration......
Some people be like:
geigercounter
Re: VLC 3.0 bugs
Wed Feb 20, 2019 12:07 am
gkreidl wrote:
Sun Nov 18, 2018 8:35 am
When using MMAL (overlay) output, the video size is not stretched to fill the screen. A 720p50 video will be displayed in the upper left side using the original size. And it looks even worse when you play SD video. This may not be called a "bug", but it really should be changed.
@gkreidl did you ever find a way to display the video occupying the entire screen with the mmal_vout (overlay) output? I need to play some 720p vidoes on my 1080p tv. Using the vlc zoom option (zoom=2) fills the height, but there is a big black band on the right. I'd like to show the black band equally on both left and right (which omxplayer does out of the box). Is there a way you are aware of to achieve that?
cjan
Wed Feb 20, 2019 3:20 am
vlc got updated, what improved?
test mmal_vout full screen, some can play some can not.
geigercounter
Wed Feb 20, 2019 6:28 pm
Thanks. I am using the latest VLC version on a headless RPi, with mmal_vout (--fullscreen does nothing). Still, the videos are shown at the original resolution in the top left corner, leaving most of the screen black.
grkblood13
Fri Mar 01, 2019 12:31 am
Using @6by9's build instructions, VLC will not playback video. It only enters a "flickering" state where it appears that's it trying to do something and the timeline progresses, but no video is actually displayed. My test bed is a freshly built raspbian Stretch running on a RPI3B+.
For my build I performed the following:
1) uncommented sources in /etc/apt/sources.list
2) sudo apt update
3) sudo apt build-deps vlc
4) git clone https://github.com/RPi-Distro/vlc.git
5) cd vlc
6) ./bootstrap
7) ./configure --build=arm-linux-gnueabihf --prefix=/opt --includedir=${prefix}/include --mandir=${prefix}/share/man --infodir=${prefix}/share/info --sysconfdir=/etc --localstatedir=/var --disable-silent-rules --libdir=${prefix}/lib/arm-linux-gnueabihf --libexecdir=${prefix}/lib/arm-linux-gnueabihf --disable-maintainer-mode --disable-dependency-tracking --config-cache --disable-update-check --enable-fast-install --docdir=/usr/share/doc/vlc --with-binary-version=3.0.3-1-0+deb9u1+rpt1 --enable-a52 --enable-aa --enable-bluray --enable-avahi --enable-caca --enable-chromaprint --enable-chromecast --enable-dbus --enable-dca --enable-dvbpsi --enable-dvdnav --enable-faad --enable-flac --enable-fluidsynth --enable-freerdp --enable-freetype --enable-fribidi --enable-gles2 --enable-gnutls --enable-harfbuzz --enable-jack --enable-kate --enable-libass --enable-libmpeg2 --enable-libxml2 --enable-lirc --enable-live555 --enable-mad --enable-matroska --enable-mod --enable-mpc --enable-mpg123 --enable-mtp --enable-ncurses --enable-notify --enable-ogg --enable-opus --enable-pulse --enable-qt --enable-realrtsp --enable-samplerate --enable-sdl-image --enable-sftp --enable-shine --enable-shout --enable-skins2 --enable-sndio --enable-soxr --enable-speex --enable-svg --enable-svgdec --enable-taglib --enable-theora --enable-twolame --enable-upnp --enable-vdpau --enable-vnc --enable-vorbis --enable-x264 --enable-x265 --enable-zvbi --with-kde-solid=/usr/share/solid/actions/ --disable-aribsub --disable-d3d11va --disable-decklink --disable-directx --disable-dsm --disable-dxva2 --disable-fdkaac --disable-fluidlite --disable-goom --disable-gst-decode --disable-libplacebo --disable-libtar --disable-macosx --disable-macosx-avfoundation --disable-macosx-qtkit --disable-mfx --disable-opencv --disable-projectm --disable-schroedinger --disable-sparkle --disable-srt --disable-telx --disable-vpx --disable-vsxu --disable-wasapi --enable-alsa --enable-dc1394 --enable-dv1394 --enable-linsys --enable-nfs --enable-omxil --enable-udev --enable-v4l2 --disable-wayland --enable-libva --enable-vcd --enable-smbclient --disable-oss --disable-crystalhd --disable-mmx --disable-sse --enable-neon --enable-mmal --disable-altivec
8) make -j3
9) sudo make install
10) /opt/bin/vlc
* browsed to Tools > Preferences > Video > Display Output
* selected "MMAL-based vout plugin for Raspberry Pi"
* selected SAVE and closed player
11) Downloaded "I Am Legend" movie trailer and extracted to ~/Videos/I_Am_Legend.mp4
* source link: https://dvdloc8.com/clip.php?movieid=13599&clipid=4
12) /opt/bin/vlc -vvv /home/pi/Videos/I_Am_Legend.mp4 2>/tmp/out
The following is the generated error log:
https://gist.github.com/grkblood13/47dc ... 9f786e9681
cjan
Fri Mar 01, 2019 1:55 am
no one said this will work.
grkblood13
Fri Mar 01, 2019 3:32 am
No display output works, including "automatic". They all either do the same thing or crash completely.
The only way I am able to get video to play is if I disable hardware decoding from the terminal with vlc --codec="avcodec,none"
This however doesn't playback video in a speed that is watchable at all.
cjan
Fri Mar 01, 2019 5:34 am
why not mmal splitter vout?
grkblood13
Fri Mar 01, 2019 3:58 pm
This was not an option in the VLC interface compiled from the steps I listed. I also tried backing up the the latest 3.0.3 branch from rpi-distro, which didn't have that option either.
ShiftPlusOne
Fri Mar 01, 2019 4:29 pm
Just cloning the repo isn't enough. It's a debian package, so the patch is applied as a part of the debian build process. Otherwise, it's just a vanilla build of upstream VLC. If you want to do it manually, look in ./debian/patches
cjan
Wed Mar 13, 2019 11:44 am
try to enable omxil vout and work :D
cjan
Thu May 23, 2019 10:53 pm
Thanks. On it.
update to 3.2.14, debian version over raspbian again.
6by9
Fri May 24, 2019 1:49 pm
Thanks. On it.
I can't reproduce that.
[email protected]rrypi:~ $ apt-cache policy vlc
vlc:
  Installed: 3.0.6-0+rpt4+deb9u1
  Candidate: 3.0.6-0+rpt4+deb9u1
  Version table:
 *** 3.0.6-0+rpt4+deb9u1 500
        500 http://archive.raspberrypi.org/debian stretch/main armhf Packages
        100 /var/lib/dpkg/status
     3.0.6-0+deb9u1 500
        500 http://raspbian.raspberrypi.org/raspbian stretch/main armhf Packages
Upstream Stretch doesn't list it either https://packages.debian.org/stretch/vlc (same for Buster and Sid too).
So I don't know where you've got a 3.2.14 from. Please post the output from "apt-cache policy vlc".
cjan
Fri May 24, 2019 11:05 pm
@6by9
we are talk about ffmpeg, sorry.
ShiftPlusOne
Fri May 24, 2019 11:33 pm
Ah, I saw VLC when I looked at it as well. Will update when I get a chance.
Return to “Raspbian”
