I try to reconfigure the MMU beyond what is done in the examples of LdB.
I try to do this by building upon an example of ARMv8 ARM, which can be found
here:
https://static.docs.arm.com/ddi0487/da/ ... v8_arm.pdf
The example is the one in section K7.1.2, fig. K7-11, page 7293.
I find the information in ARMv8 ARM to be conflicting. In fig. K7-11 I can see
the level 3 page descriptor using bits 12-16 for the OA (output address). But
in fig. D5-15, section D5.3.1, page 2445, these bits are used for something
else (field nT and a 4-bit RES0).
Please, tell me which one is correct. The example is more logical, because
bits 12-16 make the OA have the right size, whereas usign them for nT and
RES0 requires quite complex work-arounds.
Regards,
Dumitru
