tmanieropiron
Re: LVDS add-on for Raspberry models with 40pin GPIO
Thu Nov 08, 2018 11:30 am
write to t.maniero at piron dot it
Thank you!
Thomas
dennisc
Mon Feb 25, 2019 10:18 am
Please let me know how to get my email address across to you! Would like to buy one.
aBUGSworstnightmare
Fri Mar 01, 2019 7:14 pm
dennisc wrote: Please let me know how to get my email address across to you! Would like to buy one.
do it in the same way as Thomas did in the post before yours!
Let me know which display you want to connect (either post.the data sheet or a picture of the LVDS mapping) as I need to check if the remaining boards can be used.
dennisc
Mon Mar 04, 2019 7:00 pm
here we go!
xxx _at_ me _dot_ com
dennisc
Tue Mar 05, 2019 8:03 am
here is the datasheet!
aBUGSworstnightmare
Tue Mar 05, 2019 9:02 am
dennisc wrote: here is the datasheet!
Pinout is not what I'm interrested in!
I need to know the LVDS data mapping. So, please check your display spec for some informaton like the one shown below.
Y0= ...R1,R0 LVDs mapping
Your display need to have this mapping as there are no PCBs left which support Y0=..R3,R2 (look at the first post in this treath for seeing the difference).
dennisc
Tue Mar 05, 2019 10:01 am
I think it is the right version!
aBUGSworstnightmare
Tue Mar 05, 2019 10:04 am
yes, mapping is correct. I will let you know the details by e-mail.
have you received my e-mail btw?
aBUGSworstnightmare
dennisc
Tue Mar 05, 2019 10:08 am
made a mistake in writing it...
xxxx _at_ me _dot_ com
sorry!
aBUGSworstnightmare
Tue Mar 05, 2019 10:20 am
Just send an e-mail to <somebodys mail address > with details.
Let me know if you've received it.
aBUGSworstnightmare
Fri Mar 08, 2019 8:54 am
Sharp LQ121S1LG81 timing
#h_active_pixels = 800
#h_sync_polarity = 1
#h_front_porch = 168
#h_sync_pulse = 2
#h_back_porch = 86
#v_active_lines = 600
#v_sync_polarity = 1
#v_front_porch = 43
#v_sync_pulse = 2
#v_back_porch = 21
#v_sync_offset_a = 0
#v_sync_offset_b = 0
#pixel_rep = 0
#frame_rate = 60
#interlaces = 0
#pixel_freq = 40000000
#aspect_ratio = 1
Sharp LQ121S1LG81 connected to LVDS4PI
TomekRST
Wed Mar 13, 2019 10:01 pm
Hi!
Interested in your product. I can’t PM you. Could you send me your email over here: tomtom.mk2 at gmail
Thanks in advance.
Tomek
aBUGSworstnightmare
Thu Mar 14, 2019 5:56 am
Hi!
Thanks in advance.
Tomek
PM function has been disabled on the RPI forum quite a while ago.
Well, I would not call the board 'a product'; it's more a proof-of-concept. Will send e-mail with dot-com domain; let me know in case you did not receive it.
kelroy
Wed May 22, 2019 8:32 pm
Hi!
Thanks in advance.
Tomek
Hi aBUGSworstnightmare, i was reading the whole post and others about dpi to lvds and this inspired me to design one, really thanks to your work man. But i am having a small problem. I really dont know how to obtain the correct dpi_timings and dpi_output_format. Could you help me please?
Or if it's some tutorial/detailed guide to obtain this.
Some photos of my actually job (it's a prototype so i make the things big xD):
Board:
Datasheet:
RGB format, actually i se the jumper to 8.
aBUGSworstnightmare
Thu May 23, 2019 6:04 am
Details on DPI are here https://www.raspberrypi.org/documentati ... /README.md
Your display spec should have all the details to figure out dpi_oitput format. You've posted some of the timing details already, polarity infos should be available from some chart in your dieplay spec.
kelroy
Thu May 23, 2019 9:34 am
Yes, at least i understand the dpi_output_format.
But on the timmings... i just inderstand a few things like the h and v lanes, frame rate.... but the others, i could not figure how to obtain this in base of the datasheet.
Finally i have it working, damm chinesse datasheets... they are really bad.
aBUGSworstnightmare
Thu May 23, 2019 1:49 pm
There should be a chart that explains values from table 3.3.4
There you can see how polarities are etc. And how to interpret the rest
kelroy
Fri May 24, 2019 9:36 am
Yes, finally i made it works. At least was hard but i found this post that explain a bit things and with that and other reads i found a solution.
That its the post i saw: https://timetoexplore.net/blog/video-ti ... 720p-1080p
