I'm having a big trouble to get this to work.
I have a function that I want to put in a thread (or multiprocess). This function requires 3 variables.
One of the variables (var_1) is static and no problem passing it through args in the thread module.
The second variable (var_2) changes during the main program
The last variable (flag) i want to use as a trigger when it gets True in the main program.
The "mental" structure of the program should be:
main.py
import threading
from test import function
import time
global flag, var_2
var_1 = "var_1"
t = threading.Thread(target=function, args=(var_1,))
t.start()
while True:
var_2 = "var_2 (that changes in each while loop"
flag = True
time.sleep(1)
flag = False
def function(var_1):
global var_2, flag
while True:
if flag == True:
print(var_1 + var_2)
Someone guru could help me?
