Lomax
RPi.GPIO: RuntimeError: No access to /dev/mem. Try running as root!
Tue Jan 08, 2019 1:55 pm
On site working, stressed out because I want to demo before end of play - stumped by this absurdity:
sudo python matrix_v2.py
  File "matrix_v2.py", line 126, in <module>
    GPIO.setup(button, GPIO.IN, pull_up_down=GPIO.PUD_UP)
WTF? Anyone?
It all comes gushing forth with
sudo cat /dev/mem
dominic03
Re: RPi.GPIO: RuntimeError: No access to /dev/mem. Try running as root!
Tue Jan 08, 2019 1:59 pm
??? Anyone?
sudo cat /dev/mem
Try:
sudo -i
then run it.
My setup:
Raspberry Pi 3b+ running Raspbian Buster v3.1 (via PINN)
Kingston 32 GB class 10 (U1) SDHC card
pi-top 3 with drivers and pi-topHUB 2.0 or Sceptre E225W 22" 75hz 1080p monitor
Lomax
Tue Jan 08, 2019 2:16 pm
Try:
sudo -i
then run it.
Thanks, already tried that. Found the problem though: I'm using the Adafruit RGB matrix "bonnet", and it seems to hog all the pins if configured first - swapping the init blocks around (GPIO first) seems to have solved it. Confusing error message, but I suppose it makes sense.
Edit: Nope, spoke too soon - it worked once and now I get
  File "matrix_v2.py", line 97, in <module>
    GPIO.add_event_detect(button, GPIO.FALLING, bouncetime=500)
RuntimeError: Failed to add edge detection
"button" = BCM #19 (not using SPI)
Lomax
Thu Jan 10, 2019 10:48 am
Ok, I finally found the problem: a bug was introduced in the RPi.GPIO library v0.6.4, and subsequently fixed in 0.6.5, see https://github.com/RPi-Distro/python-gp ... issues/687 Removing the version shipped by Raspbian and installing via pip pulled in 0.6.5 and the issue went away.
ildomarcarvalho
Mon Feb 04, 2019 12:51 pm
Hello Lomax,
I didn't understand what you do to solve the problem. Could you please give more details?
I solved this problem by adding the user you are using to the gpio group and rebooting the RPI:
sudo adduser your_user gpio
Best Regards,
Lomax
Mon Feb 04, 2019 5:11 pm
I solved the problem by upgrading the RPi.GPIO Python library to v0.6.5 (from v0.6.4, which has this bug). Raspbian ships v0.6.4 so I upgraded via pip.
My user was already a member of the gpio group.
UPDATE: I just installed Raspbian on a new Pi and noticed that apt-get dist-upgrade pulls in RPi.GPIO 0.6.5, which makes this thread rather moot.
