Faruk
Chromium-Browser does not work from crontab -e
Wed Jan 23, 2019 1:54 pm
Hello
I work for do kiosk with raspberry pi. If rpi connect to internet, chrome shows page from internet But if there is not internet connection on pi, chrome shows the page I previously saved(page.html). I create shell script for check internet connection(online or offline status control). And I want run this shell script every hours check for net connection. I use 'crontab -e' for run this shell script. Also I created log file and I can see error message here. Shell script when start from 'crontab -e' I see this error my log file:
 --disable-quic --enable-tcp-fast-open --disable-gpu-compositing --ppapi-flash-path=/usr/lib/chromium-browser/libpepflashplayer.so --ppapi-flash-args=enable_stagevideo_auto=0 --ppapi-flash-version=
 [1861:1861:0123/142106.028318:ERROR:browser_main_loop.cc(670)] Failed to put Xlib intothreaded mode.
 (chromium-browser:1861): Gtk-WARNING **:cannot open display:
My script(check.sh):
#!/bin/sh
wget -q --spider http://google.com
if [ $? -eq 0 ]; then
	killall chromium-browser
	chromium-browser --noerrdialogs http://www.google.com --disable-translate --window-size=1920,1120 --window-position=0,930
else
	chromium-browser /home/pi/Downloads/page.html --window-size=1920,1120 --window-position=0,930
fi
exit
My crontab -e file:
#m h dom mon dow command
13 14 * * * /home/pi/check.sh >> /home/pi/Desktop/log.txt 2>&1
I searched this error. I tried suggestions(e.g.'DISPLAY=:0.0') but result didn't change. Any suggestion different for solution?
Note: I did 'sudo chmod +x check.sh ' and runned on console it is work good.
Re: Chromium-Browser does not work from crontab -e
Wed Jan 23, 2019 8:37 pm
You can't start GUI programs from cron.
Add a line item to /home/pi/.config/lxsession/LXDE-pi/autostart to get the browser started when the GUI comes up active.
@lxpanel --profile LXDE-pi
@pcmanfm --desktop --profile LXDE-pi
@xscreensaver -no-splash
@point-rpi
@/bin/bash /home/pi/check.sh
Faruk
Thu Jan 24, 2019 4:50 am
So how to control every hour from autostart file. Should the control mechanism be in the sh file?
Faruk
Thu Jan 24, 2019 5:41 am
Additionally tried python script.
#!/usr/bin/env python
import requests
import os
import webbrowser
import time
url='www.google.com'
url2='/home/pi/Downloads/page.html'
netflg=True
def internet_on():
    while True:
        try:
            response = requests.get('https://www.google.com/')
            netflg=True
            print(netflg)
            chrome_path='/usr/bin/chromium-browser %s'
            webbrowser.get(chrome_path).open(url)
            loop()
            return True
        except:
            netflg=False
            print(netflg)
            webbrowser.get(chrome_path).open(url2)
            loop()
            return False
def loop():
    time.sleep(10)
    internet_on()
internet_on()
and started this script from /home/pi/.config/lxsession/LXDE-pi/autostart. I used
@/usr/bin/python /home/pi/Desktop/2.py
This time chrome not open every ten second, it starts just one time. When run the script manually, it is work but when I autostart, script has wrong something. Also I check
ps aux | grep 2.py
and script is running.
Thu Jan 24, 2019 7:20 am
You can't do it from cron. One possible way may be with https://docs.python.org/3/library/sched.html
Faruk
Thu Jan 24, 2019 7:58 am
Ok. Finally what is wrong other way. Why python script just work one time?
DirkS
Thu Jan 24, 2019 10:36 am
That's unrelated to your original request. Please use 1 issue per topic. That also gives you a better chance of getting a meaningful response.
Start a new topic for this in the Python section
bls
Contact: Twitter
Sat Jan 26, 2019 7:11 pm
One approach that would work is to use a systemd-based service. I created a service file /usr/lib/systemd/user/xload.service containing:
[Unit]
Description=xload
[Service]
ExecStart=/usr/bin/xload -display myhost.mydomain.com:1
And when I started the service with: systemd start --user xload.service xload displayed on my X windows screen.
You can have as much, or more control with systemd services than with cron, which is really time-based. If you want to restart the browser on a regular basis, the service can be made restartable, and you can have a cron job that runs on a time-schedule to kill the browser, causing systemd to restart it.
Pi tools:
Free your network from your router's DHCP/DNS and run it on a Pi:https://github.com/gitbls/ndm
Quickly and easily build customized-just-for-you SD Cards: https://github.com/gitbls/sdm
Easy strongSwan VPN installer/manager: https://github.com/gitbls/pistrong
Lightweight Virtual VNC Config: https://github.com/gitbls/RPiVNCHowTo
Return to “Advanced users”
