Faruk
pigpio error: "no permission to update GPIO"
Sat Jan 12, 2019 1:57 pm
Hello
I work on script so I want control to backlight of LCD screen with PWM(software). It is worked earlier but it does not work now. I commented out bakclight divide and worked on the other modules on software. Now I want use but I took this error. I researched on net but I could not fix this. How can I fix this error? My pwm code divide this:
improt RPi.GPIO as gpio
import pigpio
pi=pigpio.pi()
print (pi.connected)    #Test for pigs t
gpio.setmode(gpio.BCM)
gpio.setwarnings(False)
gpio.setup(33, gpio.IN)  #Pin of DW button
gpio.setup(30, gpio.OUT) #Pin of backlight
gpio.setup(39, gpio.OUT) #Pin of lcd on/off function
#-Backlight and LCD open-#
def screenopen():
    global pi
    global screenflg
    screenflg=False
    print "screen open start"
    try:
        gpio.output(39,1)
        pi.set_PWM_frequency(30,100)
        for i in range(0,155,30):
            pi.set_PWM_dutycycle(30,i)
            time.sleep(0.01)
        print "screen open end"
    except:
        import traceback
        traceback.print_exc()
        prgloop()
Regards
Re: pigpio error: "no permission to update GPIO"
Sat Jan 12, 2019 2:39 pm
What error? You have not shown it.
Try running with sudo like so:
$ sudo python myProg.py
Faruk
Sat Jan 12, 2019 2:52 pm
Error is:"no permission to update GPIO". Return this error. I will try. If I would not work it. I think use new image. Because I try for do this different way but my Rpi reboot itself.
Sat Jan 12, 2019 3:15 pm
You appear to be mixing some pigpio code (which you've imported) with lots RPi.gpio code (which you haven't imported).
I'd recommend you pick one or the other.
Faruk
Mon Jan 14, 2019 5:18 am
I edited my code I forgot first line. Sorry. Also I tried use just GPIO(not pigpio) so my rpi reboot itself when run program. I could not understand why? I researched now.
Faruk
Mon Jan 14, 2019 9:23 am
All of error this:
  File "/home/pi/Petra/PGUI.py", line 166, in updateGUI
    screenclose()
  File "/home/pi/Petra/PGUI.py", line 95, in screenclose
    pi.set_PWM_frequency(30,255)
  File "/usr/local/lib/python2.7/dist-packages/pigpio.py", line 1586, in set_PWM_frequency
    _pigpio_command(self.sl, _PI_CMD_PFS, user_gpio, frequency))
  File "/usr/local/lib/python2.7/dist-packages/pigpio.py", line 975, in _u2i
    raise error(error_text(v))
error: 'no permission to update GPIO'
I could not find any solution.
