thadaddyy
Kodi PVR
Fri Dec 28, 2018 4:35 am
Hey guys, what is the best hardware/software combo to record live TV in Kodi? I'm in Canada and basically looking for PVR type function.
Re: Kodi PVR
Fri Dec 28, 2018 3:38 pm
How do you receive TV ?
Aerial, Satellite, Internet ?
mikronauts
Re: Kodi PVR
Fri Dec 28, 2018 4:18 pm
Hdhomerun + kodi should do it.
thadaddyy
Re: Kodi PVR
Fri Dec 28, 2018 6:35 pm
I'm getting TV via the internet. For HDhomerun is it best to use the hdhomerun pvr add on in Kodi?
mikronauts
Re: Kodi PVR
Fri Dec 28, 2018 6:53 pm
You wrote tv in canada... I assumed you meant over the air atsc.
No idea on how to record streams.
Re: Kodi PVR
Fri Dec 28, 2018 7:00 pm
https://kodi.wiki/view/PVR/Backend/IPTV
thadaddyy
Re: Kodi PVR
Fri Dec 28, 2018 7:11 pm
Thanks this helps a lot, my only question is to record IPTV can you use the back end software OR hardware or do you need both.
default_user8
Re: Kodi PVR
Fri Dec 28, 2018 8:56 pm
You will need a tuner(HDHomerun) pointed at at backend, typically something like TVheadend. If you used the Libreelec image for kodi tvheadend is already installed you just need to choose which one you want to use and enable it.
Two heads are better than one, unless one's a goat head.
thadaddyy
Re: Kodi PVR
Fri Dec 28, 2018 9:41 pm
Ok thanks that makes sense, yes I'm using Libreelec and I tvheadend is already there. Looks like I'll be in the market for a tuner now!
Re: Kodi PVR
Fri Dec 28, 2018 10:38 pm
https://kodi.wiki/view/Add-on:IPTV_Simple_Client
Should be all you need to watch IPTV ?? have you tried ??
thadaddyy
Re: Kodi PVR
Sat Dec 29, 2018 12:32 am
Oh yeah I've used IPTV Simple Client, it works great for watching IPTV but my issue was recording something from the guide (without a tuner).
Re: Kodi PVR
Sat Dec 29, 2018 5:13 am
YMMV
https://forum.kodi.tv/showthread.php?tid=326896
