123aaron
i2c communication with VEML7700 Light sensor help (python)
Mon Nov 20, 2017 10:04 am
I am struggling to communicate with a VEML700 ambient light detector.
I can detect its presence with i2cdetect and it correctly gives address 0x10.
But from here I am having trouble get values from it.
I'm new to i2c communication, but have managed to get a number of other sensors up and running.
The datasheet is a little different to the other sensors I've been using and this is where I am probably stumbling.
The sheet says to write:
Slave addr---Command code---Data byte (LSB)---Data byte (MSB)
read:
Slave addr---Command code---Slave addr---(response) LSB---(response) MSB
How does it translate to, say, the "write_i2c_block_data()" and "read_i2c_block_data" commands?
Any pointers you guy could give me would be greatly appreciated.
Datasheet:
https://www.vishay.com/docs/84286/veml7700.pdf
robidouxj
Re: i2c communication with VEML7700 Light sensor help (python)
Thu Mar 22, 2018 5:18 pm
I had similar struggles. I contacted Vishay and they were very helpful. Now that I've found a solution, I thought I'd go back and share it where I was searching. I hope this sample code helps future users:
import smbus
import time
bus = smbus.SMBus(1)
addr = 0x10
#Write registers
als_conf_0 = 0x00
als_WH = 0x01
als_WL = 0x02
pow_sav = 0x03
#Read registers
als = 0x04
white = 0x05
interrupt = 0x06
# These settings will provide the max range for the sensor (0-120Klx)
# but at the lowest precision:
#              LSB   MSB
confValues = [0x00, 0x13] # 1/8 gain, 25ms IT (Integration Time)
#Reference data sheet Table 1 for configuration settings
interrupt_high = [0x00, 0x00] # Clear values
#Reference data sheet Table 2 for High Threshold
interrupt_low = [0x00, 0x00] # Clear values
#Reference data sheet Table 3 for Low Threshold
power_save_mode = [0x00, 0x00] # Clear values
#Reference data sheet Table 4 for Power Saving Modes
bus.write_i2c_block_data(addr, als_conf_0, confValues)
bus.write_i2c_block_data(addr, als_WH, interrupt_high)
bus.write_i2c_block_data(addr, als_WL, interrupt_low)
bus.write_i2c_block_data(addr, pow_sav, power_save_mode)
while True:
	#The frequency to read the sensor should be set greater than
	# the integration time (and the power saving delay if set).
	# Reading at a faster frequency will not cause an error, but
	# will result in reading the previous data
	time.sleep(.04) # 40ms
	word = bus.read_word_data(addr,als)
	gain = 1.8432 #Gain for 1/8 gain & 25ms IT
	#Reference www.vishay.com/docs/84323/designingveml7700.pdf
	# 'Calculating the LUX Level'
	val = word * gain
	val = round(val,1) #Round value for presentation
	print "Lux: " + str(val) + " lx"
Good luck.
Joe Robidoux
andreraspberry
Mon Dec 24, 2018 12:45 pm
Hi, I used the above code, and it works. thanks Joe Robidoux.
The folowing code I use for VEML6030, is basicaly the same code. I put the correction formula for values above 1000lux.
# this program reads sensor VEML6030 and correct non linearity values above 1000 lux
# original code based on veml7700 example of Joe Robidoux.
import smbus
import time
addr = 0x10
#Write registers
als_conf_0 = 0x00
als_WH = 0x01
als_WL = 0x02
pow_sav = 0x03
#Read registers
als = 0x04
white = 0x05
interrupt = 0x06
# These settings will provide the range for the sensor: (0 - 15099 lx)
# LSB MSB
confValues = [0x00, 0x18] # 1/4 gain, 100ms IT (Integration Time)
#MSB = 00011000 = 18 in hexadecimal ( als gain = 1/4, bits 12:11 = 11 )
#LSB = 00000000 = 00 ( integration time = 100ms, bits 9:6 = 0000 )
while True:
# wordIR = bus.read_word_data(addr,white)
gain = 0.2304 # gain=1/4 and int time=100ms, max lux=15099 lux
#Reference www.vishay.com/docs/84367/designingveml6030.pdf
val = word * gain
#valIR = wordIR * gain
#val = round(val,1)
#valIR = round(valIR,1)
valcorr = (6.0135E-13*val**4)-(9.392E-9*val**3)+(8.1488E-5*val**2)+(1.0023E0*val)
valcorr = round(valcorr,1) #Round corrected value for presentation
print ("Measures: " + str(val) + " Lux" , str(valcorr) + "lux corrected")
Return to “Python”
