balubeto
Smartphone with Ethernet cable
Tue Nov 20, 2018 8:34 am
Hi
I'm looking for a product with Android 8.1.x that allows you to emulate all the features of a LTE Advanced smartphone and install and use all the Google Play Store apps.
This product should be totally and remotely configurated and controlled via LAN (class Giga) from a computer with Windows operating system.
In addition, if connected to a LAN, it should use the Internet connection of the LAN; while, if connected directly via Ethernet to a computer, it should also act as an LTE Advanced modem.
Bye
balubeto
Andyroo
Re: Smartphone with Ethernet cable
Tue Nov 20, 2018 10:13 am
The only Pi based 'phones I have seen are variations on https://shop.sb-components.co.uk/produc ... spberry-pi
It may be a starting point for you.
balubeto
Tue Nov 20, 2018 11:30 am
Very interesting.
Now, do you know any user groups or companies that can build it for me?
Bye
balubeto
Andyroo
Tue Nov 20, 2018 1:42 pm
Going by the kit contents you just plug it together:
PiTalk with Antenna
3.2"/4"/5" LCD Screen
Raspberry Pi 3 Model B+
8GB microSD card preloaded with PiTalk Software
As a guess you would need to add a power supply and your bespoke software but I've never built one (hate mobiles after years of 24x7 call outs).
One other option would be to see if you have a local Raspberry Jam https://www.raspberrypi.org/jam/ or pop a wanted note on viewforum.php?f=61
Return to “Android”
