Hi there,
I have been working on a project to read temperature from a thermocouple using a Gertboard/Rpi.
I have a code written in C which I have tested using function generator to ensure its operation and it does work as I expect.
I have been using LTK001 which is a cold junction compensator and matched amplifier in order to have values my ADC is able to read...
Now, the thing I am confused about at the moment is how I manage to match the outputs from amplifier/compensator to the needs of gertboard
I have an equation in my code that makes my limits operate between 0v and 3.3v. my limits are -65 --> +130. So 0v = -65 and 3.3v = +130.
What I am confused about is how to I work out what mv/degree c I need to produce from my amplifier/compensator circuit for it to match with my gertboard. If that makes sense ?
Thanks, James.
Re: Thermocouple data logger
you might try something like a MAX6675 you read the TC directly in deg C. it interfaces with SPI so easy to hook up. I think there is an I2C version as well if that is more to your liking.
python libs arlready exist to read the chip.
Sorry dont think I explained very well,
This is a project I have been given and due to certain requirements for it I am only allowed to use a type T thermocouple therefore I can't use the MAX amplifiers.
I have my circuit wired up http://www.google.co.uk/imgres?q=ltk001 ... x=80&ty=31 similair to this but replacing the 255k with a 1.56M to give my required gain.
Now my problem isnt noticed at first as when i heat up the thermocouple it shows on the computer the corresponding bits/voltage/temperature and appears to work.
Although, when I put a handheld thermometer next to the thermocouple it tells me for example that I am at 50 degrees c, when the computer believes we are at a maximum of 130 degrees c.
I adjusted the gain of the amplifier with respect to the voltage/temperature i should get at room temp and these are fine but everything else seems to be skewed.
Any ideas?
Any ideas?
You could use a TH7. Thats a board I made with my son (now at uni) last summer.
Its at version 4 and detects loss of thermocouple and applies compensation
in s/w.
It does the cold Jucntion compensation in s/w. So Type T is a matter of finding the right
polynomials. Currently we only implemented `k' because they were easier to find/buy.
Look at the git s/w here and https://www.omega.com/techref/pdf/z198-201.pdf.
If you want to put T type polynomials into the python code feel free to branch off
the git repo https://github.com/robin48gx/TH7
in s/w.
To robin48gx
Could you please let me know where I can purchase TH7 boards? Thanks
robin48gx wrote: You could use a TH7. Thats a board I made with my son (now at uni) last summer.
in s/w.
